| 1 |
/* Copyright (c) 1995 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Mist volumetric material.
| 9 |
| 10 |
| 11 |
#include "ray.h"
| 12 |
| 13 |
#include "source.h"
| 14 |
| 15 |
| 16 |
* A mist volume is used to specify a region in the scene where a certain
| 17 |
* light source (or sources) is going to contribute to scattering. The
| 18 |
* material can add to the existing global medium, and override any ray
| 19 |
* settings for scattering albedo and eccentricity. Overlapping mist
| 20 |
* regions should agree w.r.t. albedo and eccentricity, and
| 21 |
* should have disjoint source lists.
| 22 |
| 23 |
* A pattern, if used, should compute the line integral of extinction,
| 24 |
* and will modify the first three arguments directly. This will tend
| 25 |
* to invalidate results when there are other objects intersected within
| 26 |
* the mist region.
| 27 |
| 28 |
* The string arguments for MAT_MIST are the identifiers for the important
| 29 |
* light sources, which will be looked up in the source array. The last
| 30 |
* source found matching a name is the one used. A relayed light source
| 31 |
* may be indicated by the relay surface name, followed by a '>' character,
| 32 |
* followed by the relayed source name (which may be another relay).
| 33 |
| 34 |
* Up to five real arguments may be given for MAT_MIST:
| 35 |
| 36 |
* [ext_r ext_g ext_b [albedo [gecc]]]
| 37 |
| 38 |
* The primaries indicate medium extinction per unit length (absorption
| 39 |
* plus scattering), which is added to the global extinction coefficient, set
| 40 |
* by the -me option. The albedo is the ratio of scattering to extinction,
| 41 |
* and is set globally by the -ma option (salbedo) and overridden here.
| 42 |
* The Heyney-Greenstein eccentricity parameter (-mg seccg) indicates how much
| 43 |
* scattering favors the forward direction. A value of 0 means isotropic
| 44 |
* scattering. A value approaching 1 indicates strong forward scattering.
| 45 |
| 46 |
| 47 |
#define RELAYDELIM '>' /* relay delimiter character */
| 48 |
| 49 |
extern COLOR cextinction; /* global coefficient of extinction */
| 50 |
extern double salbedo; /* global scattering albedo */
| 51 |
extern double seccg; /* global scattering eccentricity */
| 52 |
| 53 |
| 54 |
static int
| 55 |
inslist(sl, n) /* return index of source n if it's in list sl */
| 56 |
register int *sl;
| 57 |
register int n;
| 58 |
| 59 |
register int i;
| 60 |
| 61 |
for (i = sl[0]; i > 0; i--)
| 62 |
if (sl[i] == n)
| 63 |
return(i);
| 64 |
return(0);
| 65 |
| 66 |
| 67 |
| 68 |
static int
| 69 |
srcmatch(sp, id) /* check for an id match on a light source */
| 70 |
register SRCREC *sp;
| 71 |
register char *id;
| 72 |
| 73 |
extern char *index();
| 74 |
register char *cp;
| 75 |
/* check for relay sources */
| 76 |
while ((cp = index(id, RELAYDELIM)) != NULL) {
| 77 |
if (!(sp->sflags & SVIRTUAL) || sp->so == NULL)
| 78 |
return(0);
| 79 |
if (strncmp(id, sp->so->oname, cp-id) || sp->so->oname[cp-id])
| 80 |
return(0);
| 81 |
id = cp + 1; /* relay to next */
| 82 |
sp = source + sp->sa.sv.sn;
| 83 |
| 84 |
if (sp->sflags & SVIRTUAL || sp->so == NULL)
| 85 |
return(0);
| 86 |
return(!strcmp(id, sp->so->oname));
| 87 |
| 88 |
| 89 |
| 90 |
static
| 91 |
add2slist(r, sl) /* add source list to ray's */
| 92 |
register RAY *r;
| 93 |
register int *sl;
| 94 |
| 95 |
static int slspare[MAXSLIST+1]; /* in case of emergence */
| 96 |
register int i;
| 97 |
| 98 |
if (sl == NULL || sl[0] == 0) /* nothing to add */
| 99 |
return;
| 100 |
if (r->slights == NULL)
| 101 |
(r->slights = slspare)[0] = 0; /* just once per ray path */
| 102 |
| 103 |
if (!inslist(r->slights, sl[i])) {
| 104 |
if (r->slights[0] >= MAXSLIST)
| 105 |
error(USER, "scattering source list overflow");
| 106 |
r->slights[++r->slights[0]] = sl[i];
| 107 |
| 108 |
| 109 |
| 110 |
| 111 |
m_mist(m, r) /* process a ray entering or leaving some mist */
| 112 |
OBJREC *m;
| 113 |
register RAY *r;
| 114 |
| 115 |
RAY p;
| 116 |
int *myslist = NULL;
| 117 |
int newslist[MAXSLIST+1];
| 118 |
COLOR mext;
| 119 |
double re, ge, be;
| 120 |
register int i, j;
| 121 |
/* check arguments */
| 122 |
if (m->oargs.nfargs > 5)
| 123 |
objerror(m, USER, "bad arguments");
| 124 |
/* get source indices */
| 125 |
if (m->oargs.nsargs > 0 && (myslist = (int *)m->os) == NULL) {
| 126 |
if (m->oargs.nsargs > MAXSLIST)
| 127 |
objerror(m, USER, "too many sources in list");
| 128 |
myslist = (int *)malloc((m->oargs.nsargs+1)*sizeof(int));
| 129 |
if (myslist == NULL)
| 130 |
goto memerr;
| 131 |
myslist[0] = 0; /* size is first in list */
| 132 |
for (j = 0; j < m->oargs.nsargs; j++) {
| 133 |
i = nsources; /* look up each source id */
| 134 |
while (i--)
| 135 |
if (srcmatch(source+i, m->oargs.sarg[j]))
| 136 |
break;
| 137 |
if (i < 0) {
| 138 |
sprintf(errmsg, "unknown source \"%s\"",
| 139 |
m->oargs.sarg[j]);
| 140 |
objerror(m, WARNING, errmsg);
| 141 |
} else if (inslist(myslist, i)) {
| 142 |
sprintf(errmsg, "duplicate source \"%s\"",
| 143 |
m->oargs.sarg[j]);
| 144 |
| 145 |
} else
| 146 |
myslist[++myslist[0]] = i;
| 147 |
| 148 |
m->os = (char *)myslist;
| 149 |
| 150 |
if (m->oargs.nfargs > 2) { /* compute extinction */
| 151 |
setcolor(mext, m->oargs.farg[0], m->oargs.farg[1],
| 152 |
m->oargs.farg[2]);
| 153 |
raytexture(r, m->omod); /* get modifiers */
| 154 |
multcolor(mext, r->pcol);
| 155 |
} else
| 156 |
setcolor(mext, 0., 0., 0.);
| 157 |
/* start transmitted ray */
| 158 |
if (rayorigin(&p, r, TRANS, 1.) < 0)
| 159 |
return(1);
| 160 |
VCOPY(p.rdir, r->rdir);
| 161 |
p.slights = newslist;
| 162 |
if (r->slights != NULL) /* copy old list if one */
| 163 |
for (j = r->slights[0]; j >= 0; j--)
| 164 |
p.slights[j] = r->slights[j];
| 165 |
else
| 166 |
p.slights[0] = 0;
| 167 |
if (r->rod > 0.) { /* entering ray */
| 168 |
addcolor(p.cext, mext);
| 169 |
if (m->oargs.nfargs > 3)
| 170 |
p.albedo = m->oargs.farg[3];
| 171 |
if (m->oargs.nfargs > 4)
| 172 |
p.gecc = m->oargs.farg[4];
| 173 |
add2slist(&p, myslist); /* add to list */
| 174 |
} else { /* leaving ray */
| 175 |
if (myslist != NULL) { /* delete from list */
| 176 |
for (j = myslist[0]; j > 0; j--)
| 177 |
if (i = inslist(p.slights, myslist[j]))
| 178 |
p.slights[i] = -1;
| 179 |
for (i = 0, j = 1; j <= p.slights[0]; j++)
| 180 |
if (p.slights[j] != -1)
| 181 |
p.slights[++i] = p.slights[j];
| 182 |
if (p.slights[0] - i < myslist[0]) { /* fix old */
| 183 |
addcolor(r->cext, mext);
| 184 |
| 185 |
r->albedo = m->oargs.farg[3];
| 186 |
| 187 |
r->gecc = m->oargs.farg[4];
| 188 |
add2slist(r, myslist);
| 189 |
| 190 |
p.slights[0] = i;
| 191 |
| 192 |
if ((re = colval(r->cext,RED) - colval(mext,RED)) <
| 193 |
colval(cextinction,RED))
| 194 |
re = colval(cextinction,RED);
| 195 |
if ((ge = colval(r->cext,GRN) - colval(mext,GRN)) <
| 196 |
colval(cextinction,GRN))
| 197 |
ge = colval(cextinction,GRN);
| 198 |
if ((be = colval(r->cext,BLU) - colval(mext,BLU)) <
| 199 |
colval(cextinction,BLU))
| 200 |
be = colval(cextinction,BLU);
| 201 |
setcolor(p.cext, re, ge, be);
| 202 |
| 203 |
p.albedo = salbedo;
| 204 |
| 205 |
p.gecc = seccg;
| 206 |
| 207 |
rayvalue(&p); /* calls rayparticipate() */
| 208 |
copycolor(r->rcol, p.rcol); /* return value */
| 209 |
r->rt = r->rot + p.rt;
| 210 |
return(1);
| 211 |
memerr:
| 212 |
error(SYSTEM, "out of memory in m_mist");
| 213 |
