root/radiance/ray/src/rt/m_mirror.c
Revision: 2.10
Committed: Tue Mar 30 16:13:01 2004 UTC (20 years, 1 month ago) by schorsch
Changes since 2.9: +21 -19 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.10 static const char RCSid[] = "$Id: m_mirror.c,v 2.9 2003/02/25 02:47:22 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Routines for mirror material supporting virtual light sources
6     */
7
8 greg 2.9 #include "copyright.h"
9 greg 2.8
10 greg 1.1 #include "ray.h"
11     #include "otypes.h"
12 schorsch 2.10 #include "rtotypes.h"
13 greg 1.1 #include "source.h"
14
15     /*
16     * The real arguments for MAT_MIRROR are simply:
17     *
18     * 3 rrefl grefl brefl
19     *
20     * Additionally, the user may specify a single string argument
21     * which is interpreted as the name of the material to use
22     * instead of the mirror if the ray being considered is not
23     * part of the direct calculation.
24     */
25
26 schorsch 2.10 static int mir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n);
27     static void mirrorproj(MAT4 m, FVECT nv, double offs);
28 greg 2.8
29 greg 1.1 VSMATERIAL mirror_vs = {mir_proj, 1};
30
31
32 schorsch 2.10 extern int
33     m_mirror( /* shade mirrored ray */
34     register OBJREC *m,
35     register RAY *r
36     )
37 greg 1.1 {
38     COLOR mcolor;
39     RAY nr;
40 greg 2.6 int rpure = 1;
41 greg 1.1 register int i;
42     /* check arguments */
43     if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1)
44     objerror(m, USER, "bad number of arguments");
45 greg 1.3 /* check for substitute material */
46     if (m->oargs.nsargs > 0 &&
47     (r->rsrc < 0 || source[r->rsrc].so != r->ro)) {
48 greg 2.4 if (!strcmp(m->oargs.sarg[0], VOIDID)) {
49     raytrans(r);
50     return(1);
51     }
52 gwlarson 2.7 return(rayshade(r, lastmod(objndx(m), m->oargs.sarg[0])));
53 greg 1.1 }
54 greg 1.3 /* check for bad source ray */
55     if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
56 greg 2.3 return(1);
57 greg 1.3
58 greg 1.1 if (r->rod < 0.) /* back is black */
59 greg 2.3 return(1);
60 greg 1.1 /* get modifiers */
61     raytexture(r, m->omod);
62     /* assign material color */
63     setcolor(mcolor, m->oargs.farg[0],
64     m->oargs.farg[1],
65     m->oargs.farg[2]);
66     multcolor(mcolor, r->pcol);
67     /* compute reflected ray */
68     if (r->rsrc >= 0) { /* relayed light source */
69     rayorigin(&nr, r, REFLECTED, 1.);
70     /* ignore textures */
71     for (i = 0; i < 3; i++)
72     nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
73     /* source we're aiming for next */
74 greg 1.2 nr.rsrc = source[r->rsrc].sa.sv.sn;
75 greg 1.1 } else { /* ordinary reflection */
76     FVECT pnorm;
77     double pdot;
78
79     if (rayorigin(&nr, r, REFLECTED, bright(mcolor)) < 0)
80 greg 2.3 return(1);
81 greg 2.6 if (DOT(r->pert,r->pert) > FTINY*FTINY) {
82     pdot = raynormal(pnorm, r); /* use textures */
83     for (i = 0; i < 3; i++)
84     nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i];
85     rpure = 0;
86     }
87 greg 2.2 /* check for penetration */
88 greg 2.6 if (rpure || DOT(nr.rdir, r->ron) <= FTINY)
89 greg 2.2 for (i = 0; i < 3; i++)
90     nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
91 greg 1.1 }
92     rayvalue(&nr);
93     multcolor(nr.rcol, mcolor);
94     addcolor(r->rcol, nr.rcol);
95 greg 2.6 if (rpure && r->ro != NULL && isflat(r->ro->otype))
96     r->rt = r->rot + nr.rt;
97 greg 2.3 return(1);
98 greg 1.1 }
99
100
101 greg 2.8 static int
102 schorsch 2.10 mir_proj( /* compute a mirror's projection */
103     MAT4 pm,
104     register OBJREC *o,
105     SRCREC *s,
106     int n
107     )
108 greg 1.1 {
109 greg 2.5 FVECT nv, sc;
110 greg 1.1 double od;
111 greg 2.5 register int i, j;
112 greg 1.1 /* get surface normal and offset */
113 greg 1.2 od = getplaneq(nv, o);
114 greg 2.5 /* check for extreme point for behind */
115     VCOPY(sc, s->sloc);
116     for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--)
117     if (DOT(nv, s->ss[i]) > 0.)
118     for (j = 0; j < 3; j++)
119     sc[j] += s->ss[i][j];
120     else
121     for (j = 0; j < 3; j++)
122     sc[j] -= s->ss[i][j];
123     if (DOT(sc, nv) <= (s->sflags & SDISTANT ? FTINY : od+FTINY))
124 greg 1.1 return(0);
125     /* everything OK -- compute projection */
126     mirrorproj(pm, nv, od);
127     return(1);
128     }
129
130
131 schorsch 2.10 static void
132     mirrorproj( /* get mirror projection for surface */
133     register MAT4 m,
134     FVECT nv,
135     double offs
136     )
137 greg 1.1 {
138     register int i, j;
139     /* assign matrix */
140     setident4(m);
141 greg 1.2 for (j = 0; j < 3; j++) {
142     for (i = 0; i < 3; i++)
143 greg 1.1 m[i][j] -= 2.*nv[i]*nv[j];
144     m[3][j] = 2.*offs*nv[j];
145 greg 1.2 }
146 greg 1.1 }
