root/Development/ray/src/rt/m_mirror.c
Revision: 2.25
Committed: Sat May 31 00:52:54 2025 UTC (7 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.24: +7 -5 lines
perf: Minor optimization to avoid putting unneeded RAY struct on stack
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.25 static const char RCSid[] = "$Id: m_mirror.c,v 2.24 2025/05/29 16:42:28 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Routines for mirror material supporting virtual light sources
6     */
7
8 greg 2.9 #include "copyright.h"
9 greg 2.8
10 greg 1.1 #include "ray.h"
11     #include "otypes.h"
12 greg 2.24 #include "otspecial.h"
13 schorsch 2.10 #include "rtotypes.h"
14 greg 1.1 #include "source.h"
15
16     /*
17     * The real arguments for MAT_MIRROR are simply:
18     *
19     * 3 rrefl grefl brefl
20     *
21     * Additionally, the user may specify a single string argument
22     * which is interpreted as the name of the material to use
23     * instead of the mirror if the ray being considered is not
24     * part of the direct calculation.
25     */
26
27 schorsch 2.10 static int mir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n);
28     static void mirrorproj(MAT4 m, FVECT nv, double offs);
29 greg 2.8
30 greg 1.1 VSMATERIAL mirror_vs = {mir_proj, 1};
31
32
33 greg 2.16 int
34 schorsch 2.10 m_mirror( /* shade mirrored ray */
35 greg 2.16 OBJREC *m,
36     RAY *r
37 schorsch 2.10 )
38 greg 1.1 {
39     /* check arguments */
40     if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1)
41     objerror(m, USER, "bad number of arguments");
42 greg 1.3 /* check for substitute material */
43 greg 2.14 /* but avoid double-counting */
44 greg 2.24 if (m->oargs.nsargs > 0 &&
45     (r->rsrc < 0 || source[r->rsrc].so != r->ro)) {
46     int passOK = (r->rod < 0.) |
47     !(r->crtype & (AMBIENT|SPECULAR));
48     if (strcmp(m->oargs.sarg[0], VOIDID)) {
49     OBJECT altmod = lastmod(objndx(m), m->oargs.sarg[0]);
50     OBJREC *altmat;
51     if (passOK) /* no double-count hazard? */
52     return(rayshade(r, altmod));
53     if (altmod == OVOID || /* else check alternate type */
54     (altmat = findmaterial(objptr(altmod))) == NULL)
55     return(0);
56     if (istransp(altmat)) /* pass "transparent" materials */
57     return(rayshade(r, altmod));
58     } else if (passOK) {
59     raytrans(r); /* "safe" void passage */
60 greg 2.4 return(1);
61     }
62 greg 1.1 }
63 greg 1.3 /* check for bad source ray */
64     if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
65 greg 2.3 return(1);
66 greg 1.3
67 greg 2.15 if (r->rod < 0.) { /* back is black */
68     if (!backvis)
69     raytrans(r); /* unless back visibility is off */
70 greg 2.3 return(1);
71 greg 2.15 }
72 greg 2.25 { /* new context for stack memory */
73     SCOLOR mcolor;
74     RAY nr;
75     int rpure = 1;
76     int i;
77 greg 1.1 /* get modifiers */
78     raytexture(r, m->omod);
79     /* assign material color */
80 greg 2.23 setscolor(mcolor, m->oargs.farg[0],
81 greg 1.1 m->oargs.farg[1],
82     m->oargs.farg[2]);
83 greg 2.23 smultscolor(mcolor, r->pcol);
84 greg 1.1 /* compute reflected ray */
85     if (r->rsrc >= 0) { /* relayed light source */
86 greg 2.11 rayorigin(&nr, REFLECTED, r, mcolor);
87 greg 1.1 /* ignore textures */
88     for (i = 0; i < 3; i++)
89     nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
90     /* source we're aiming for next */
91 greg 1.2 nr.rsrc = source[r->rsrc].sa.sv.sn;
92 greg 1.1 } else { /* ordinary reflection */
93     FVECT pnorm;
94     double pdot;
95
96 greg 2.11 if (rayorigin(&nr, REFLECTED, r, mcolor) < 0)
97 greg 2.3 return(1);
98 greg 2.16 if (!(r->crtype & AMBIENT) &&
99     DOT(r->pert,r->pert) > FTINY*FTINY) {
100 greg 2.6 pdot = raynormal(pnorm, r); /* use textures */
101     for (i = 0; i < 3; i++)
102     nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i];
103     rpure = 0;
104     }
105 greg 2.2 /* check for penetration */
106 greg 2.6 if (rpure || DOT(nr.rdir, r->ron) <= FTINY)
107 greg 2.2 for (i = 0; i < 3; i++)
108     nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
109 greg 1.1 }
110 greg 2.13 checknorm(nr.rdir);
111 greg 1.1 rayvalue(&nr);
112 greg 2.23 smultscolor(nr.rcol, nr.rcoef);
113     copyscolor(r->mcol, nr.rcol);
114     saddscolor(r->rcol, nr.rcol);
115 greg 2.21 r->rmt = r->rot;
116 greg 2.6 if (rpure && r->ro != NULL && isflat(r->ro->otype))
117 greg 2.22 r->rmt += raydistance(&nr);
118 greg 2.25 } /* end stack context */
119 greg 2.3 return(1);
120 greg 1.1 }
121
122
123 greg 2.8 static int
124 schorsch 2.10 mir_proj( /* compute a mirror's projection */
125     MAT4 pm,
126 greg 2.16 OBJREC *o,
127 schorsch 2.10 SRCREC *s,
128     int n
129     )
130 greg 1.1 {
131 greg 2.12 double corr = 1.;
132 greg 2.5 FVECT nv, sc;
133 greg 2.12 double od, offs;
134     int i;
135 greg 1.1 /* get surface normal and offset */
136 greg 2.12 offs = od = getplaneq(nv, o);
137     if (s->sflags & SDISTANT)
138     offs = 0.;
139     /* check for extreme point behind */
140     if (s->sflags & SCIR) {
141     if (s->sflags & (SFLAT|SDISTANT))
142     corr = 1.12837917; /* correct setflatss() */
143     else
144     corr = 1.0/0.7236; /* correct sphsetsrc() */
145     }
146 greg 2.5 VCOPY(sc, s->sloc);
147     for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--)
148 greg 2.12 if (DOT(nv, s->ss[i]) > offs)
149     VSUM(sc, sc, s->ss[i], corr);
150 greg 2.5 else
151 greg 2.12 VSUM(sc, sc, s->ss[i], -corr);
152     if (DOT(sc, nv) <= offs+FTINY)
153 greg 1.1 return(0);
154     /* everything OK -- compute projection */
155     mirrorproj(pm, nv, od);
156     return(1);
157     }
158
159
160 schorsch 2.10 static void
161     mirrorproj( /* get mirror projection for surface */
162 greg 2.16 MAT4 m,
163 schorsch 2.10 FVECT nv,
164     double offs
165     )
166 greg 1.1 {
167 greg 2.16 int i, j;
168 greg 1.1 /* assign matrix */
169     setident4(m);
170 greg 1.2 for (j = 0; j < 3; j++) {
171     for (i = 0; i < 3; i++)
172 greg 1.1 m[i][j] -= 2.*nv[i]*nv[j];
173     m[3][j] = 2.*offs*nv[j];
174 greg 1.2 }
175 greg 1.1 }
