1 |
/* Copyright (c) 1995 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for mirror material supporting virtual light sources |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include "otypes.h" |
14 |
15 |
#include "source.h" |
16 |
17 |
18 |
* The real arguments for MAT_MIRROR are simply: |
19 |
20 |
* 3 rrefl grefl brefl |
21 |
22 |
* Additionally, the user may specify a single string argument |
23 |
* which is interpreted as the name of the material to use |
24 |
* instead of the mirror if the ray being considered is not |
25 |
* part of the direct calculation. |
26 |
27 |
28 |
29 |
int mir_proj(); |
30 |
VSMATERIAL mirror_vs = {mir_proj, 1}; |
31 |
32 |
33 |
m_mirror(m, r) /* shade mirrored ray */ |
34 |
register OBJREC *m; |
35 |
register RAY *r; |
36 |
37 |
COLOR mcolor; |
38 |
RAY nr; |
39 |
register int i; |
40 |
/* check arguments */ |
41 |
if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1) |
42 |
objerror(m, USER, "bad number of arguments"); |
43 |
/* check for substitute material */ |
44 |
if (m->oargs.nsargs > 0 && |
45 |
(r->rsrc < 0 || source[r->rsrc].so != r->ro)) { |
46 |
if (!strcmp(m->oargs.sarg[0], VOIDID)) { |
47 |
raytrans(r); |
48 |
return(1); |
49 |
50 |
return(rayshade(r, modifier(m->oargs.sarg[0]))); |
51 |
52 |
/* check for bad source ray */ |
53 |
if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) |
54 |
return(1); |
55 |
56 |
if (r->rod < 0.) /* back is black */ |
57 |
return(1); |
58 |
/* get modifiers */ |
59 |
raytexture(r, m->omod); |
60 |
/* assign material color */ |
61 |
setcolor(mcolor, m->oargs.farg[0], |
62 |
m->oargs.farg[1], |
63 |
m->oargs.farg[2]); |
64 |
multcolor(mcolor, r->pcol); |
65 |
/* compute reflected ray */ |
66 |
if (r->rsrc >= 0) { /* relayed light source */ |
67 |
rayorigin(&nr, r, REFLECTED, 1.); |
68 |
/* ignore textures */ |
69 |
for (i = 0; i < 3; i++) |
70 |
nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; |
71 |
/* source we're aiming for next */ |
72 |
nr.rsrc = source[r->rsrc].sa.sv.sn; |
73 |
} else { /* ordinary reflection */ |
74 |
FVECT pnorm; |
75 |
double pdot; |
76 |
77 |
if (rayorigin(&nr, r, REFLECTED, bright(mcolor)) < 0) |
78 |
return(1); |
79 |
pdot = raynormal(pnorm, r); /* use textures */ |
80 |
81 |
nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i]; |
82 |
/* check for penetration */ |
83 |
if (DOT(nr.rdir, r->ron) <= FTINY) |
84 |
85 |
86 |
87 |
rayvalue(&nr); |
88 |
multcolor(nr.rcol, mcolor); |
89 |
addcolor(r->rcol, nr.rcol); |
90 |
return(1); |
91 |
92 |
93 |
94 |
mir_proj(pm, o, s, n) /* compute a mirror's projection */ |
95 |
MAT4 pm; |
96 |
register OBJREC *o; |
97 |
SRCREC *s; |
98 |
int n; |
99 |
100 |
FVECT nv, sc; |
101 |
double od; |
102 |
register int i, j; |
103 |
/* get surface normal and offset */ |
104 |
od = getplaneq(nv, o); |
105 |
/* check for extreme point for behind */ |
106 |
VCOPY(sc, s->sloc); |
107 |
for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--) |
108 |
if (DOT(nv, s->ss[i]) > 0.) |
109 |
for (j = 0; j < 3; j++) |
110 |
sc[j] += s->ss[i][j]; |
111 |
else |
112 |
113 |
sc[j] -= s->ss[i][j]; |
114 |
if (DOT(sc, nv) <= (s->sflags & SDISTANT ? FTINY : od+FTINY)) |
115 |
return(0); |
116 |
/* everything OK -- compute projection */ |
117 |
mirrorproj(pm, nv, od); |
118 |
return(1); |
119 |
120 |
121 |
122 |
mirrorproj(m, nv, offs) /* get mirror projection for surface */ |
123 |
register MAT4 m; |
124 |
FVECT nv; |
125 |
double offs; |
126 |
127 |
128 |
/* assign matrix */ |
129 |
setident4(m); |
130 |
for (j = 0; j < 3; j++) { |
131 |
132 |
m[i][j] -= 2.*nv[i]*nv[j]; |
133 |
m[3][j] = 2.*offs*nv[j]; |
134 |
135 |
