root/radiance/ray/src/rt/m_mirror.c
Revision: 2.25
Committed: Sat May 31 00:52:54 2025 UTC (8 weeks, 1 day ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.24: +7 -5 lines
perf: Minor optimization to avoid putting unneeded RAY struct on stack
2 static const char RCSid[] = "$Id: m_mirror.c,v 2.24 2025/05/29 16:42:28 greg Exp $";
5 * Routines for mirror material supporting virtual light sources
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "otspecial.h"
13 #include "rtotypes.h"
14 #include "source.h"
15
16 /*
17 * The real arguments for MAT_MIRROR are simply:
18 *
19 * 3 rrefl grefl brefl
20 *
21 * Additionally, the user may specify a single string argument
22 * which is interpreted as the name of the material to use
23 * instead of the mirror if the ray being considered is not
24 * part of the direct calculation.
25 */
26
27 static int mir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n);
28 static void mirrorproj(MAT4 m, FVECT nv, double offs);
29
30 VSMATERIAL mirror_vs = {mir_proj, 1};
31
32
33 int
34 m_mirror( /* shade mirrored ray */
35 OBJREC *m,
36 RAY *r
37 )
38 {
39 /* check arguments */
40 if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1)
41 objerror(m, USER, "bad number of arguments");
42 /* check for substitute material */
43 /* but avoid double-counting */
44 if (m->oargs.nsargs > 0 &&
45 (r->rsrc < 0 || source[r->rsrc].so != r->ro)) {
46 int passOK = (r->rod < 0.) |
47 !(r->crtype & (AMBIENT|SPECULAR));
48 if (strcmp(m->oargs.sarg[0], VOIDID)) {
49 OBJECT altmod = lastmod(objndx(m), m->oargs.sarg[0]);
50 OBJREC *altmat;
51 if (passOK) /* no double-count hazard? */
52 return(rayshade(r, altmod));
53 if (altmod == OVOID || /* else check alternate type */
54 (altmat = findmaterial(objptr(altmod))) == NULL)
55 return(0);
56 if (istransp(altmat)) /* pass "transparent" materials */
57 return(rayshade(r, altmod));
58 } else if (passOK) {
59 raytrans(r); /* "safe" void passage */
60 return(1);
61 }
62 }
63 /* check for bad source ray */
64 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
65 return(1);
66
67 if (r->rod < 0.) { /* back is black */
68 if (!backvis)
69 raytrans(r); /* unless back visibility is off */
70 return(1);
71 }
72 { /* new context for stack memory */
73 SCOLOR mcolor;
74 RAY nr;
75 int rpure = 1;
76 int i;
77 /* get modifiers */
78 raytexture(r, m->omod);
79 /* assign material color */
80 setscolor(mcolor, m->oargs.farg[0],
81 m->oargs.farg[1],
82 m->oargs.farg[2]);
83 smultscolor(mcolor, r->pcol);
84 /* compute reflected ray */
85 if (r->rsrc >= 0) { /* relayed light source */
86 rayorigin(&nr, REFLECTED, r, mcolor);
87 /* ignore textures */
88 for (i = 0; i < 3; i++)
89 nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
90 /* source we're aiming for next */
91 nr.rsrc = source[r->rsrc].sa.sv.sn;
92 } else { /* ordinary reflection */
93 FVECT pnorm;
94 double pdot;
95
96 if (rayorigin(&nr, REFLECTED, r, mcolor) < 0)
97 return(1);
98 if (!(r->crtype & AMBIENT) &&
99 DOT(r->pert,r->pert) > FTINY*FTINY) {
100 pdot = raynormal(pnorm, r); /* use textures */
101 for (i = 0; i < 3; i++)
102 nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i];
103 rpure = 0;
104 }
105 /* check for penetration */
106 if (rpure || DOT(nr.rdir, r->ron) <= FTINY)
107 for (i = 0; i < 3; i++)
108 nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
109 }
110 checknorm(nr.rdir);
111 rayvalue(&nr);
112 smultscolor(nr.rcol, nr.rcoef);
113 copyscolor(r->mcol, nr.rcol);
114 saddscolor(r->rcol, nr.rcol);
115 r->rmt = r->rot;
116 if (rpure && r->ro != NULL && isflat(r->ro->otype))
117 r->rmt += raydistance(&nr);
118 } /* end stack context */
119 return(1);
120 }
121
122
123 static int
124 mir_proj( /* compute a mirror's projection */
125 MAT4 pm,
126 OBJREC *o,
127 SRCREC *s,
128 int n
129 )
130 {
131 double corr = 1.;
132 FVECT nv, sc;
133 double od, offs;
134 int i;
135 /* get surface normal and offset */
136 offs = od = getplaneq(nv, o);
137 if (s->sflags & SDISTANT)
138 offs = 0.;
139 /* check for extreme point behind */
140 if (s->sflags & SCIR) {
141 if (s->sflags & (SFLAT|SDISTANT))
142 corr = 1.12837917; /* correct setflatss() */
143 else
144 corr = 1.0/0.7236; /* correct sphsetsrc() */
145 }
146 VCOPY(sc, s->sloc);
147 for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--)
148 if (DOT(nv, s->ss[i]) > offs)
149 VSUM(sc, sc, s->ss[i], corr);
150 else
151 VSUM(sc, sc, s->ss[i], -corr);
152 if (DOT(sc, nv) <= offs+FTINY)
153 return(0);
154 /* everything OK -- compute projection */
155 mirrorproj(pm, nv, od);
156 return(1);
157 }
158
159
160 static void
161 mirrorproj( /* get mirror projection for surface */
162 MAT4 m,
163 FVECT nv,
164 double offs
165 )
166 {
167 int i, j;
168 /* assign matrix */
169 setident4(m);
170 for (j = 0; j < 3; j++) {
171 for (i = 0; i < 3; i++)
172 m[i][j] -= 2.*nv[i]*nv[j];
173 m[3][j] = 2.*offs*nv[j];
174 }
175 }
