root/radiance/ray/src/rt/m_mirror.c
Sat May 31 00:52:54 2025 UTC (8 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.24: +7 -5 lines
Diff to previous 2.24
perf: Minor optimization to avoid putting unneeded RAY struct on stack
Thu May 29 16:42:28 2025 UTC (8 weeks, 1 day ago) by greg
Changes since 2.23: +18 -7 lines
Diff to previous 2.23
fix: Updated behavior of "mirror" type to handle indirect transmission, thanks to Jon Sargent
Wed Nov 15 18:02:53 2023 UTC (20 months, 1 week ago) by greg
Changes since 2.22: +7 -7 lines
Diff to previous 2.22
Tue Jan 21 21:31:58 2020 UTC (5 years, 6 months ago) by greg
CVS Tags: rad5R3, rad5R4
Diff to previous 2.21
Fixed error in reflected distance calculation
Fri Apr 19 19:01:32 2019 UTC (6 years, 3 months ago) by greg
Diff to previous 2.20
Make sure reflected ray distance is not infinite if there's a reflection
Tue Nov 13 19:58:33 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 2.19
Mon Jun 6 16:22:46 2016 UTC (9 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.18: +4 -3 lines
Diff to previous 2.18
Fix to missing indirect contribution discovered by Santiago Torres
Tue May 26 13:21:07 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.17: +1 -7 lines
Diff to previous 2.17
Removed deprecated ambRayInPmap() macro from code
Tue Feb 24 19:39:26 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.16: +7 -1 lines
Diff to previous 2.16
Sat May 10 17:43:01 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.15: +10 -9 lines
Diff to previous 2.15
Fixed virtual distance so as not to undermine ambient calculation
Sat Jan 25 18:27:39 2014 UTC (11 years, 6 months ago) by greg
Diff to previous 2.14
Thu Aug 29 15:37:16 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.13: +3 -2 lines
Diff to previous 2.13
Fixed double-counting bug in mirror type with secondary material
Sun Sep 26 15:51:15 2010 UTC (14 years, 10 months ago) by greg
Diff to previous 2.12
Sat Jun 6 02:11:43 2009 UTC (16 years, 1 month ago) by greg
Changes since 2.11: +18 -11 lines
Fixed erroneous "aiming failure" with certain mirrored virtual sources
Tue Apr 19 01:15:06 2005 UTC (20 years, 3 months ago) by greg
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.9: +21 -19 lines
Tue Feb 25 02:47:22 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:28 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.7: +63 -5 lines
Mon Aug 10 18:37:05 1998 UTC (26 years, 11 months ago) by gwlarson
Fri Sep 15 15:47:29 1995 UTC (29 years, 10 months ago) by greg
Changes since 2.5: +10 -4 lines
added isflat() macro and effective ray distance for mirror reflection
Sat Aug 26 15:15:51 1995 UTC (29 years, 11 months ago) by greg
Changes since 2.4: +13 -4 lines
changed behind test to allow for source sampling
Wed Jul 26 16:53:25 1995 UTC (30 years ago) by greg
Changes since 2.3: +5 -2 lines
changed behavior of mirror so that void alternate makes transparent
Wed Jan 12 16:46:41 1994 UTC (31 years, 6 months ago) by greg
Changes since 2.2: +5 -4 lines
Fri Nov 20 12:09:16 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.1: +4 -0 lines
added check for ray penetration
Tue Nov 12 17:10:20 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.3
Thu Jul 18 10:11:20 1991 UTC (34 years ago) by greg
Changes since 1.2: +7 -5 lines
Diff to previous 1.2
fixed logic on substitute materials
Tue Jul 16 15:56:46 1991 UTC (34 years ago) by greg
Changes since 1.1: +6 -8 lines
Diff to previous 1.1
added redirecting materials
Thu Jun 20 13:44:35 1991 UTC (34 years, 1 month ago) by greg
