root/radiance/ray/src/rt/m_mirror.c
Revision: 2.13
Committed: Sun Sep 26 15:51:15 2010 UTC (14 years, 7 months ago) by greg
2 static const char RCSid[] = "$Id: m_mirror.c,v 2.12 2009/06/06 02:11:43 greg Exp $";
5 * Routines for mirror material supporting virtual light sources
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13 #include "source.h"
14
15 /*
16 * The real arguments for MAT_MIRROR are simply:
17 *
18 * 3 rrefl grefl brefl
19 *
20 * Additionally, the user may specify a single string argument
21 * which is interpreted as the name of the material to use
22 * instead of the mirror if the ray being considered is not
23 * part of the direct calculation.
24 */
25
26 static int mir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n);
27 static void mirrorproj(MAT4 m, FVECT nv, double offs);
28
29 VSMATERIAL mirror_vs = {mir_proj, 1};
30
31
32 extern int
33 m_mirror( /* shade mirrored ray */
34 register OBJREC *m,
35 register RAY *r
36 )
37 {
38 COLOR mcolor;
39 RAY nr;
40 int rpure = 1;
41 register int i;
42 /* check arguments */
43 if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1)
44 objerror(m, USER, "bad number of arguments");
45 /* check for substitute material */
46 if (m->oargs.nsargs > 0 &&
47 (r->rsrc < 0 || source[r->rsrc].so != r->ro)) {
48 if (!strcmp(m->oargs.sarg[0], VOIDID)) {
49 raytrans(r);
50 return(1);
51 }
52 return(rayshade(r, lastmod(objndx(m), m->oargs.sarg[0])));
53 }
54 /* check for bad source ray */
55 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
56 return(1);
57
58 if (r->rod < 0.) /* back is black */
59 return(1);
60 /* get modifiers */
61 raytexture(r, m->omod);
62 /* assign material color */
63 setcolor(mcolor, m->oargs.farg[0],
64 m->oargs.farg[1],
65 m->oargs.farg[2]);
66 multcolor(mcolor, r->pcol);
67 /* compute reflected ray */
68 if (r->rsrc >= 0) { /* relayed light source */
69 rayorigin(&nr, REFLECTED, r, mcolor);
70 /* ignore textures */
71 for (i = 0; i < 3; i++)
72 nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
73 /* source we're aiming for next */
74 nr.rsrc = source[r->rsrc].sa.sv.sn;
75 } else { /* ordinary reflection */
76 FVECT pnorm;
77 double pdot;
78
79 if (rayorigin(&nr, REFLECTED, r, mcolor) < 0)
80 return(1);
81 if (DOT(r->pert,r->pert) > FTINY*FTINY) {
82 pdot = raynormal(pnorm, r); /* use textures */
83 for (i = 0; i < 3; i++)
84 nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i];
85 rpure = 0;
86 }
87 /* check for penetration */
88 if (rpure || DOT(nr.rdir, r->ron) <= FTINY)
89 for (i = 0; i < 3; i++)
90 nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
91 }
92 checknorm(nr.rdir);
93 rayvalue(&nr);
94 multcolor(nr.rcol, nr.rcoef);
95 addcolor(r->rcol, nr.rcol);
96 if (rpure && r->ro != NULL && isflat(r->ro->otype))
97 r->rt = r->rot + nr.rt;
98 return(1);
99 }
100
101
102 static int
103 mir_proj( /* compute a mirror's projection */
104 MAT4 pm,
105 register OBJREC *o,
106 SRCREC *s,
107 int n
108 )
109 {
110 double corr = 1.;
111 FVECT nv, sc;
112 double od, offs;
113 int i;
114 /* get surface normal and offset */
115 offs = od = getplaneq(nv, o);
116 if (s->sflags & SDISTANT)
117 offs = 0.;
118 /* check for extreme point behind */
119 if (s->sflags & SCIR) {
120 if (s->sflags & (SFLAT|SDISTANT))
121 corr = 1.12837917; /* correct setflatss() */
122 else
123 corr = 1.0/0.7236; /* correct sphsetsrc() */
124 }
125 VCOPY(sc, s->sloc);
126 for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--)
127 if (DOT(nv, s->ss[i]) > offs)
128 VSUM(sc, sc, s->ss[i], corr);
129 else
130 VSUM(sc, sc, s->ss[i], -corr);
131 if (DOT(sc, nv) <= offs+FTINY)
132 return(0);
133 /* everything OK -- compute projection */
134 mirrorproj(pm, nv, od);
135 return(1);
136 }
137
138
139 static void
140 mirrorproj( /* get mirror projection for surface */
141 register MAT4 m,
142 FVECT nv,
143 double offs
144 )
145 {
146 register int i, j;
147 /* assign matrix */
148 setident4(m);
149 for (j = 0; j < 3; j++) {
150 for (i = 0; i < 3; i++)
151 m[i][j] -= 2.*nv[i]*nv[j];
152 m[3][j] = 2.*offs*nv[j];
153 }
154 }
