Fix to missing indirect contribution discovered by Santiago Torres
Removed deprecated ambRayInPmap() macro from code
Fixed virtual distance so as not to undermine ambient calculation
Fixed double-counting bug in mirror type with secondary material
Fixed erroneous "aiming failure" with certain mirrored virtual sources
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added isflat() macro and effective ray distance for mirror reflection
changed behind test to allow for source sampling
changed behavior of mirror so that void alternate makes transparent
added check for ray penetration
fixed logic on substitute materials
added redirecting materials
