root/radiance/ray/src/rt/m_mirror.c
Sat May 10 17:43:01 2014 UTC (10 years ago) by greg
Changes since 2.15: +10 -9 lines
Fixed virtual distance so as not to undermine ambient calculation
Sat Jan 25 18:27:39 2014 UTC (10 years, 3 months ago) by greg
Thu Aug 29 15:37:16 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.13: +3 -2 lines
Fixed double-counting bug in mirror type with secondary material
Sun Sep 26 15:51:15 2010 UTC (13 years, 7 months ago) by greg
Sat Jun 6 02:11:43 2009 UTC (14 years, 11 months ago) by greg
Changes since 2.11: +18 -11 lines
Fixed erroneous "aiming failure" with certain mirrored virtual sources
Tue Apr 19 01:15:06 2005 UTC (19 years ago) by greg
Changes since 2.9: +21 -19 lines
Changes since 2.7: +63 -5 lines
Mon Aug 10 18:37:05 1998 UTC (25 years, 9 months ago) by gwlarson
Fri Sep 15 15:47:29 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.5: +10 -4 lines
added isflat() macro and effective ray distance for mirror reflection
Sat Aug 26 15:15:51 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.4: +13 -4 lines
changed behind test to allow for source sampling
Wed Jul 26 16:53:25 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.3: +5 -2 lines
changed behavior of mirror so that void alternate makes transparent
Wed Jan 12 16:46:41 1994 UTC (30 years, 4 months ago) by greg
Changes since 2.2: +5 -4 lines
Fri Nov 20 12:09:16 1992 UTC (31 years, 5 months ago) by greg
Changes since 2.1: +4 -0 lines
added check for ray penetration
Tue Nov 12 17:10:20 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.3
Thu Jul 18 10:11:20 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.2: +7 -5 lines
fixed logic on substitute materials
Tue Jul 16 15:56:46 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.1: +6 -8 lines
added redirecting materials
Thu Jun 20 13:44:35 1991 UTC (32 years, 10 months ago) by greg
Diff to selected 2.1
