--- ray/src/rt/m_mirror.c 2010/09/26 15:51:15 2.13 +++ ray/src/rt/m_mirror.c 2014/05/10 17:43:01 2.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_mirror.c,v 2.13 2010/09/26 15:51:15 greg Exp $"; +static const char RCSid[] = "$Id: m_mirror.c,v 2.16 2014/05/10 17:43:01 greg Exp $"; #endif /* * Routines for mirror material supporting virtual light sources @@ -29,21 +29,22 @@ static void mirrorproj(MAT4 m, FVECT nv, double off VSMATERIAL mirror_vs = {mir_proj, 1}; -extern int +int m_mirror( /* shade mirrored ray */ - register OBJREC *m, - register RAY *r + OBJREC *m, + RAY *r ) { COLOR mcolor; RAY nr; int rpure = 1; - register int i; + int i; /* check arguments */ if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1) objerror(m, USER, "bad number of arguments"); /* check for substitute material */ - if (m->oargs.nsargs > 0 && + /* but avoid double-counting */ + if (m->oargs.nsargs > 0 && !(r->crtype & (AMBIENT|SPECULAR)) && (r->rsrc < 0 || source[r->rsrc].so != r->ro)) { if (!strcmp(m->oargs.sarg[0], VOIDID)) { raytrans(r); @@ -55,8 +56,11 @@ m_mirror( /* shade mirrored ray */ if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) return(1); - if (r->rod < 0.) /* back is black */ + if (r->rod < 0.) { /* back is black */ + if (!backvis) + raytrans(r); /* unless back visibility is off */ return(1); + } /* get modifiers */ raytexture(r, m->omod); /* assign material color */ @@ -78,7 +82,8 @@ m_mirror( /* shade mirrored ray */ if (rayorigin(&nr, REFLECTED, r, mcolor) < 0) return(1); - if (DOT(r->pert,r->pert) > FTINY*FTINY) { + if (!(r->crtype & AMBIENT) && + DOT(r->pert,r->pert) > FTINY*FTINY) { pdot = raynormal(pnorm, r); /* use textures */ for (i = 0; i < 3; i++) nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i]; @@ -102,7 +107,7 @@ m_mirror( /* shade mirrored ray */ static int mir_proj( /* compute a mirror's projection */ MAT4 pm, - register OBJREC *o, + OBJREC *o, SRCREC *s, int n ) @@ -138,12 +143,12 @@ mir_proj( /* compute a mirror's projection */ static void mirrorproj( /* get mirror projection for surface */ - register MAT4 m, + MAT4 m, FVECT nv, double offs ) { - register int i, j; + int i, j; /* assign matrix */ setident4(m); for (j = 0; j < 3; j++) {
