--- ray/src/rt/m_mirror.c 1995/09/15 15:47:29 2.6 +++ ray/src/rt/m_mirror.c 2010/09/26 15:51:15 2.13 @@ -1,17 +1,15 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: m_mirror.c,v 2.13 2010/09/26 15:51:15 greg Exp $"; #endif - /* * Routines for mirror material supporting virtual light sources */ -#include "ray.h" +#include "copyright.h" +#include "ray.h" #include "otypes.h" - +#include "rtotypes.h" #include "source.h" /* @@ -25,14 +23,17 @@ static char SCCSid[] = "$SunId$ LBL"; * part of the direct calculation. */ +static int mir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n); +static void mirrorproj(MAT4 m, FVECT nv, double offs); -int mir_proj(); VSMATERIAL mirror_vs = {mir_proj, 1}; -m_mirror(m, r) /* shade mirrored ray */ -register OBJREC *m; -register RAY *r; +extern int +m_mirror( /* shade mirrored ray */ + register OBJREC *m, + register RAY *r +) { COLOR mcolor; RAY nr; @@ -48,7 +49,7 @@ register RAY *r; raytrans(r); return(1); } - return(rayshade(r, modifier(m->oargs.sarg[0]))); + return(rayshade(r, lastmod(objndx(m), m->oargs.sarg[0]))); } /* check for bad source ray */ if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) @@ -65,7 +66,7 @@ register RAY *r; multcolor(mcolor, r->pcol); /* compute reflected ray */ if (r->rsrc >= 0) { /* relayed light source */ - rayorigin(&nr, r, REFLECTED, 1.); + rayorigin(&nr, REFLECTED, r, mcolor); /* ignore textures */ for (i = 0; i < 3; i++) nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; @@ -75,7 +76,7 @@ register RAY *r; FVECT pnorm; double pdot; - if (rayorigin(&nr, r, REFLECTED, bright(mcolor)) < 0) + if (rayorigin(&nr, REFLECTED, r, mcolor) < 0) return(1); if (DOT(r->pert,r->pert) > FTINY*FTINY) { pdot = raynormal(pnorm, r); /* use textures */ @@ -88,8 +89,9 @@ register RAY *r; for (i = 0; i < 3; i++) nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; } + checknorm(nr.rdir); rayvalue(&nr); - multcolor(nr.rcol, mcolor); + multcolor(nr.rcol, nr.rcoef); addcolor(r->rcol, nr.rcol); if (rpure && r->ro != NULL && isflat(r->ro->otype)) r->rt = r->rot + nr.rt; @@ -97,27 +99,36 @@ register RAY *r; } -mir_proj(pm, o, s, n) /* compute a mirror's projection */ -MAT4 pm; -register OBJREC *o; -SRCREC *s; -int n; +static int +mir_proj( /* compute a mirror's projection */ + MAT4 pm, + register OBJREC *o, + SRCREC *s, + int n +) { + double corr = 1.; FVECT nv, sc; - double od; - register int i, j; + double od, offs; + int i; /* get surface normal and offset */ - od = getplaneq(nv, o); - /* check for extreme point for behind */ + offs = od = getplaneq(nv, o); + if (s->sflags & SDISTANT) + offs = 0.; + /* check for extreme point behind */ + if (s->sflags & SCIR) { + if (s->sflags & (SFLAT|SDISTANT)) + corr = 1.12837917; /* correct setflatss() */ + else + corr = 1.0/0.7236; /* correct sphsetsrc() */ + } VCOPY(sc, s->sloc); for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--) - if (DOT(nv, s->ss[i]) > 0.) - for (j = 0; j < 3; j++) - sc[j] += s->ss[i][j]; + if (DOT(nv, s->ss[i]) > offs) + VSUM(sc, sc, s->ss[i], corr); else - for (j = 0; j < 3; j++) - sc[j] -= s->ss[i][j]; - if (DOT(sc, nv) <= (s->sflags & SDISTANT ? FTINY : od+FTINY)) + VSUM(sc, sc, s->ss[i], -corr); + if (DOT(sc, nv) <= offs+FTINY) return(0); /* everything OK -- compute projection */ mirrorproj(pm, nv, od); @@ -125,10 +136,12 @@ int n; } -mirrorproj(m, nv, offs) /* get mirror projection for surface */ -register MAT4 m; -FVECT nv; -double offs; +static void +mirrorproj( /* get mirror projection for surface */ + register MAT4 m, + FVECT nv, + double offs +) { register int i, j; /* assign matrix */
