--- ray/src/rt/m_mirror.c 2005/04/19 01:15:06 2.11 +++ ray/src/rt/m_mirror.c 2010/09/26 15:51:15 2.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_mirror.c,v 2.11 2005/04/19 01:15:06 greg Exp $"; +static const char RCSid[] = "$Id: m_mirror.c,v 2.13 2010/09/26 15:51:15 greg Exp $"; #endif /* * Routines for mirror material supporting virtual light sources @@ -89,6 +89,7 @@ m_mirror( /* shade mirrored ray */ for (i = 0; i < 3; i++) nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; } + checknorm(nr.rdir); rayvalue(&nr); multcolor(nr.rcol, nr.rcoef); addcolor(r->rcol, nr.rcol); @@ -106,21 +107,28 @@ mir_proj( /* compute a mirror's projection */ int n ) { + double corr = 1.; FVECT nv, sc; - double od; - register int i, j; + double od, offs; + int i; /* get surface normal and offset */ - od = getplaneq(nv, o); - /* check for extreme point for behind */ + offs = od = getplaneq(nv, o); + if (s->sflags & SDISTANT) + offs = 0.; + /* check for extreme point behind */ + if (s->sflags & SCIR) { + if (s->sflags & (SFLAT|SDISTANT)) + corr = 1.12837917; /* correct setflatss() */ + else + corr = 1.0/0.7236; /* correct sphsetsrc() */ + } VCOPY(sc, s->sloc); for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--) - if (DOT(nv, s->ss[i]) > 0.) - for (j = 0; j < 3; j++) - sc[j] += s->ss[i][j]; + if (DOT(nv, s->ss[i]) > offs) + VSUM(sc, sc, s->ss[i], corr); else - for (j = 0; j < 3; j++) - sc[j] -= s->ss[i][j]; - if (DOT(sc, nv) <= (s->sflags & SDISTANT ? FTINY : od+FTINY)) + VSUM(sc, sc, s->ss[i], -corr); + if (DOT(sc, nv) <= offs+FTINY) return(0); /* everything OK -- compute projection */ mirrorproj(pm, nv, od);
