root/Development/ray/src/rt/m_mirror.c
Revision: 2.9
Committed: Tue Feb 25 02:47:22 2003 UTC (22 years, 10 months ago) by greg
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.8 static const char RCSid[] = "$Id$";
3 greg 1.1 #endif
4     /*
5     * Routines for mirror material supporting virtual light sources
6     */
7
8 greg 2.9 #include "copyright.h"
9 greg 2.8
10 greg 1.1 #include "ray.h"
11
12     #include "otypes.h"
13
14     #include "source.h"
15
16     /*
17     * The real arguments for MAT_MIRROR are simply:
18     *
19     * 3 rrefl grefl brefl
20     *
21     * Additionally, the user may specify a single string argument
22     * which is interpreted as the name of the material to use
23     * instead of the mirror if the ray being considered is not
24     * part of the direct calculation.
25     */
26
27
28 greg 2.8 static int mir_proj(), mirrorproj();
29
30 greg 1.1 VSMATERIAL mirror_vs = {mir_proj, 1};
31
32
33 greg 2.8 int
34 greg 1.1 m_mirror(m, r) /* shade mirrored ray */
35     register OBJREC *m;
36     register RAY *r;
37     {
38     COLOR mcolor;
39     RAY nr;
40 greg 2.6 int rpure = 1;
41 greg 1.1 register int i;
42     /* check arguments */
43     if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1)
44     objerror(m, USER, "bad number of arguments");
45 greg 1.3 /* check for substitute material */
46     if (m->oargs.nsargs > 0 &&
47     (r->rsrc < 0 || source[r->rsrc].so != r->ro)) {
48 greg 2.4 if (!strcmp(m->oargs.sarg[0], VOIDID)) {
49     raytrans(r);
50     return(1);
51     }
52 gwlarson 2.7 return(rayshade(r, lastmod(objndx(m), m->oargs.sarg[0])));
53 greg 1.1 }
54 greg 1.3 /* check for bad source ray */
55     if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
56 greg 2.3 return(1);
57 greg 1.3
58 greg 1.1 if (r->rod < 0.) /* back is black */
59 greg 2.3 return(1);
60 greg 1.1 /* get modifiers */
61     raytexture(r, m->omod);
62     /* assign material color */
63     setcolor(mcolor, m->oargs.farg[0],
64     m->oargs.farg[1],
65     m->oargs.farg[2]);
66     multcolor(mcolor, r->pcol);
67     /* compute reflected ray */
68     if (r->rsrc >= 0) { /* relayed light source */
69     rayorigin(&nr, r, REFLECTED, 1.);
70     /* ignore textures */
71     for (i = 0; i < 3; i++)
72     nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
73     /* source we're aiming for next */
74 greg 1.2 nr.rsrc = source[r->rsrc].sa.sv.sn;
75 greg 1.1 } else { /* ordinary reflection */
76     FVECT pnorm;
77     double pdot;
78
79     if (rayorigin(&nr, r, REFLECTED, bright(mcolor)) < 0)
80 greg 2.3 return(1);
81 greg 2.6 if (DOT(r->pert,r->pert) > FTINY*FTINY) {
82     pdot = raynormal(pnorm, r); /* use textures */
83     for (i = 0; i < 3; i++)
84     nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i];
85     rpure = 0;
86     }
87 greg 2.2 /* check for penetration */
88 greg 2.6 if (rpure || DOT(nr.rdir, r->ron) <= FTINY)
89 greg 2.2 for (i = 0; i < 3; i++)
90     nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
91 greg 1.1 }
92     rayvalue(&nr);
93     multcolor(nr.rcol, mcolor);
94     addcolor(r->rcol, nr.rcol);
95 greg 2.6 if (rpure && r->ro != NULL && isflat(r->ro->otype))
96     r->rt = r->rot + nr.rt;
97 greg 2.3 return(1);
98 greg 1.1 }
99
100
101 greg 2.8 static int
102 greg 1.1 mir_proj(pm, o, s, n) /* compute a mirror's projection */
103     MAT4 pm;
104     register OBJREC *o;
105 greg 1.2 SRCREC *s;
106 greg 1.1 int n;
107     {
108 greg 2.5 FVECT nv, sc;
109 greg 1.1 double od;
110 greg 2.5 register int i, j;
111 greg 1.1 /* get surface normal and offset */
112 greg 1.2 od = getplaneq(nv, o);
113 greg 2.5 /* check for extreme point for behind */
114     VCOPY(sc, s->sloc);
115     for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--)
116     if (DOT(nv, s->ss[i]) > 0.)
117     for (j = 0; j < 3; j++)
118     sc[j] += s->ss[i][j];
119     else
120     for (j = 0; j < 3; j++)
121     sc[j] -= s->ss[i][j];
122     if (DOT(sc, nv) <= (s->sflags & SDISTANT ? FTINY : od+FTINY))
123 greg 1.1 return(0);
124     /* everything OK -- compute projection */
125     mirrorproj(pm, nv, od);
126     return(1);
127     }
128
129
130 greg 2.8 static int
131 greg 1.1 mirrorproj(m, nv, offs) /* get mirror projection for surface */
132     register MAT4 m;
133     FVECT nv;
134     double offs;
135     {
136     register int i, j;
137     /* assign matrix */
138     setident4(m);
139 greg 1.2 for (j = 0; j < 3; j++) {
140     for (i = 0; i < 3; i++)
141 greg 1.1 m[i][j] -= 2.*nv[i]*nv[j];
142     m[3][j] = 2.*offs*nv[j];
143 greg 1.2 }
144 greg 1.1 }
