root/radiance/ray/src/rt/m_mirror.c
Wed Nov 15 18:02:53 2023 UTC (6 months, 2 weeks ago) by greg
Changes since 2.22: +7 -7 lines
Diff to previous 2.22 , to selected 1.1
Tue Jan 21 21:31:58 2020 UTC (4 years, 4 months ago) by greg
CVS Tags: rad5R3, rad5R4
Diff to previous 2.21 , to selected 1.1
Fixed error in reflected distance calculation
Fri Apr 19 19:01:32 2019 UTC (5 years, 1 month ago) by greg
Diff to previous 2.20 , to selected 1.1
Make sure reflected ray distance is not infinite if there's a reflection
Tue Nov 13 19:58:33 2018 UTC (5 years, 6 months ago) by greg
Diff to previous 2.19 , to selected 1.1
Mon Jun 6 16:22:46 2016 UTC (7 years, 11 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.18: +4 -3 lines
Diff to previous 2.18 , to selected 1.1
Fix to missing indirect contribution discovered by Santiago Torres
Tue May 26 13:21:07 2015 UTC (9 years ago) by greg
Changes since 2.17: +1 -7 lines
Diff to previous 2.17 , to selected 1.1
Removed deprecated ambRayInPmap() macro from code
Tue Feb 24 19:39:26 2015 UTC (9 years, 3 months ago) by greg
Changes since 2.16: +7 -1 lines
Diff to previous 2.16 , to selected 1.1
Sat May 10 17:43:01 2014 UTC (10 years ago) by greg
Changes since 2.15: +10 -9 lines
Diff to previous 2.15 , to selected 1.1
Fixed virtual distance so as not to undermine ambient calculation
Sat Jan 25 18:27:39 2014 UTC (10 years, 4 months ago) by greg
Diff to previous 2.14 , to selected 1.1
Thu Aug 29 15:37:16 2013 UTC (10 years, 9 months ago) by greg
Changes since 2.13: +3 -2 lines
Diff to previous 2.13 , to selected 1.1
Fixed double-counting bug in mirror type with secondary material
Sun Sep 26 15:51:15 2010 UTC (13 years, 8 months ago) by greg
Diff to previous 2.12 , to selected 1.1
Sat Jun 6 02:11:43 2009 UTC (14 years, 11 months ago) by greg
Changes since 2.11: +18 -11 lines
Diff to previous 2.11 , to selected 1.1
Fixed erroneous "aiming failure" with certain mirrored virtual sources
Diff to previous 2.10 , to selected 1.1
Changes since 2.9: +21 -19 lines
Diff to previous 2.9 , to selected 1.1
Diff to previous 2.8 , to selected 1.1
Changes since 2.7: +63 -5 lines
Diff to previous 2.7 , to selected 1.1
Mon Aug 10 18:37:05 1998 UTC (25 years, 9 months ago) by gwlarson
Diff to previous 2.6 , to selected 1.1
Fri Sep 15 15:47:29 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.5: +10 -4 lines
Diff to previous 2.5 , to selected 1.1
added isflat() macro and effective ray distance for mirror reflection
Sat Aug 26 15:15:51 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.4: +13 -4 lines
Diff to previous 2.4 , to selected 1.1
changed behind test to allow for source sampling
Wed Jul 26 16:53:25 1995 UTC (28 years, 10 months ago) by greg
Changes since 2.3: +5 -2 lines
Diff to previous 2.3 , to selected 1.1
changed behavior of mirror so that void alternate makes transparent
Wed Jan 12 16:46:41 1994 UTC (30 years, 4 months ago) by greg
Changes since 2.2: +5 -4 lines
Diff to previous 2.2 , to selected 1.1
Fri Nov 20 12:09:16 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.1: +4 -0 lines
Diff to previous 2.1 , to selected 1.1
added check for ray penetration
Tue Nov 12 17:10:20 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 1.1
Thu Jul 18 10:11:20 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.2: +7 -5 lines
Diff to previous 1.2 , to selected 1.1
fixed logic on substitute materials
Tue Jul 16 15:56:46 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.1: +6 -8 lines
Diff to previous 1.1
added redirecting materials
Revision 1.1 - (view) (download) (annotate) - [selected]
Thu Jun 20 13:44:35 1991 UTC (32 years, 11 months ago) by greg
