root/radiance/ray/src/rt/m_mirror.c
Revision: 2.19
Committed: Mon Jun 6 16:22:46 2016 UTC (8 years, 11 months ago) by greg
CVS Tags: rad5R2, rad5R1
Changes since 2.18: +4 -3 lines
Fix to missing indirect contribution discovered by Santiago Torres
2 static const char RCSid[] = "$Id: m_mirror.c,v 2.18 2015/05/26 13:21:07 greg Exp $";
5 * Routines for mirror material supporting virtual light sources
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13 #include "source.h"
14
15 /*
16 * The real arguments for MAT_MIRROR are simply:
17 *
18 * 3 rrefl grefl brefl
19 *
20 * Additionally, the user may specify a single string argument
21 * which is interpreted as the name of the material to use
22 * instead of the mirror if the ray being considered is not
23 * part of the direct calculation.
24 */
25
26 static int mir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n);
27 static void mirrorproj(MAT4 m, FVECT nv, double offs);
28
29 VSMATERIAL mirror_vs = {mir_proj, 1};
30
31
32 int
33 m_mirror( /* shade mirrored ray */
34 OBJREC *m,
35 RAY *r
36 )
37 {
38 COLOR mcolor;
39 RAY nr;
40 int rpure = 1;
41 int i;
42 /* check arguments */
43 if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1)
44 objerror(m, USER, "bad number of arguments");
45 /* check for substitute material */
46 /* but avoid double-counting */
47 if ( m->oargs.nsargs > 0 &&
48 (r->rsrc < 0 || source[r->rsrc].so != r->ro) &&
49 !(r->crtype & (AMBIENT|SPECULAR) && r->rod > 0.) ) {
50 if (!strcmp(m->oargs.sarg[0], VOIDID)) {
51 raytrans(r);
52 return(1);
53 }
54 return(rayshade(r, lastmod(objndx(m), m->oargs.sarg[0])));
55 }
56 /* check for bad source ray */
57 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
58 return(1);
59
60 if (r->rod < 0.) { /* back is black */
61 if (!backvis)
62 raytrans(r); /* unless back visibility is off */
63 return(1);
64 }
65 /* get modifiers */
66 raytexture(r, m->omod);
67 /* assign material color */
68 setcolor(mcolor, m->oargs.farg[0],
69 m->oargs.farg[1],
70 m->oargs.farg[2]);
71 multcolor(mcolor, r->pcol);
72 /* compute reflected ray */
73 if (r->rsrc >= 0) { /* relayed light source */
74 rayorigin(&nr, REFLECTED, r, mcolor);
75 /* ignore textures */
76 for (i = 0; i < 3; i++)
77 nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
78 /* source we're aiming for next */
79 nr.rsrc = source[r->rsrc].sa.sv.sn;
80 } else { /* ordinary reflection */
81 FVECT pnorm;
82 double pdot;
83
84 if (rayorigin(&nr, REFLECTED, r, mcolor) < 0)
85 return(1);
86 if (!(r->crtype & AMBIENT) &&
87 DOT(r->pert,r->pert) > FTINY*FTINY) {
88 pdot = raynormal(pnorm, r); /* use textures */
89 for (i = 0; i < 3; i++)
90 nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i];
91 rpure = 0;
92 }
93 /* check for penetration */
94 if (rpure || DOT(nr.rdir, r->ron) <= FTINY)
95 for (i = 0; i < 3; i++)
96 nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
97 }
98 checknorm(nr.rdir);
99 rayvalue(&nr);
100 multcolor(nr.rcol, nr.rcoef);
101 addcolor(r->rcol, nr.rcol);
102 if (rpure && r->ro != NULL && isflat(r->ro->otype))
103 r->rt = r->rot + nr.rt;
104 return(1);
105 }
106
107
108 static int
109 mir_proj( /* compute a mirror's projection */
110 MAT4 pm,
111 OBJREC *o,
112 SRCREC *s,
113 int n
114 )
115 {
116 double corr = 1.;
117 FVECT nv, sc;
118 double od, offs;
119 int i;
120 /* get surface normal and offset */
121 offs = od = getplaneq(nv, o);
122 if (s->sflags & SDISTANT)
123 offs = 0.;
124 /* check for extreme point behind */
125 if (s->sflags & SCIR) {
126 if (s->sflags & (SFLAT|SDISTANT))
127 corr = 1.12837917; /* correct setflatss() */
128 else
129 corr = 1.0/0.7236; /* correct sphsetsrc() */
130 }
131 VCOPY(sc, s->sloc);
132 for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--)
133 if (DOT(nv, s->ss[i]) > offs)
134 VSUM(sc, sc, s->ss[i], corr);
135 else
136 VSUM(sc, sc, s->ss[i], -corr);
137 if (DOT(sc, nv) <= offs+FTINY)
138 return(0);
139 /* everything OK -- compute projection */
140 mirrorproj(pm, nv, od);
141 return(1);
142 }
143
144
145 static void
146 mirrorproj( /* get mirror projection for surface */
147 MAT4 m,
148 FVECT nv,
149 double offs
150 )
151 {
152 int i, j;
153 /* assign matrix */
154 setident4(m);
155 for (j = 0; j < 3; j++) {
156 for (i = 0; i < 3; i++)
157 m[i][j] -= 2.*nv[i]*nv[j];
158 m[3][j] = 2.*offs*nv[j];
159 }
160 }
