| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: m_mirror.c,v 2.10 2004/03/30 16:13:01 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines for mirror material supporting virtual light sources
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "ray.h"
| 11 |
#include "otypes.h"
| 12 |
#include "rtotypes.h"
| 13 |
#include "source.h"
| 14 |
| 15 |
| 16 |
* The real arguments for MAT_MIRROR are simply:
| 17 |
| 18 |
* 3 rrefl grefl brefl
| 19 |
| 20 |
* Additionally, the user may specify a single string argument
| 21 |
* which is interpreted as the name of the material to use
| 22 |
* instead of the mirror if the ray being considered is not
| 23 |
* part of the direct calculation.
| 24 |
| 25 |
| 26 |
static int mir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n);
| 27 |
static void mirrorproj(MAT4 m, FVECT nv, double offs);
| 28 |
| 29 |
VSMATERIAL mirror_vs = {mir_proj, 1};
| 30 |
| 31 |
| 32 |
extern int
| 33 |
m_mirror( /* shade mirrored ray */
| 34 |
register OBJREC *m,
| 35 |
register RAY *r
| 36 |
| 37 |
| 38 |
COLOR mcolor;
| 39 |
RAY nr;
| 40 |
int rpure = 1;
| 41 |
register int i;
| 42 |
/* check arguments */
| 43 |
if (m->oargs.nfargs != 3 || m->oargs.nsargs > 1)
| 44 |
objerror(m, USER, "bad number of arguments");
| 45 |
/* check for substitute material */
| 46 |
if (m->oargs.nsargs > 0 &&
| 47 |
(r->rsrc < 0 || source[r->rsrc].so != r->ro)) {
| 48 |
if (!strcmp(m->oargs.sarg[0], VOIDID)) {
| 49 |
raytrans(r);
| 50 |
return(1);
| 51 |
| 52 |
return(rayshade(r, lastmod(objndx(m), m->oargs.sarg[0])));
| 53 |
| 54 |
/* check for bad source ray */
| 55 |
if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
| 56 |
return(1);
| 57 |
| 58 |
if (r->rod < 0.) /* back is black */
| 59 |
return(1);
| 60 |
/* get modifiers */
| 61 |
raytexture(r, m->omod);
| 62 |
/* assign material color */
| 63 |
setcolor(mcolor, m->oargs.farg[0],
| 64 |
m->oargs.farg[1],
| 65 |
m->oargs.farg[2]);
| 66 |
multcolor(mcolor, r->pcol);
| 67 |
/* compute reflected ray */
| 68 |
if (r->rsrc >= 0) { /* relayed light source */
| 69 |
rayorigin(&nr, REFLECTED, r, mcolor);
| 70 |
/* ignore textures */
| 71 |
for (i = 0; i < 3; i++)
| 72 |
nr.rdir[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
| 73 |
/* source we're aiming for next */
| 74 |
nr.rsrc = source[r->rsrc].sa.sv.sn;
| 75 |
} else { /* ordinary reflection */
| 76 |
FVECT pnorm;
| 77 |
double pdot;
| 78 |
| 79 |
if (rayorigin(&nr, REFLECTED, r, mcolor) < 0)
| 80 |
return(1);
| 81 |
if (DOT(r->pert,r->pert) > FTINY*FTINY) {
| 82 |
pdot = raynormal(pnorm, r); /* use textures */
| 83 |
| 84 |
nr.rdir[i] = r->rdir[i] + 2.*pdot*pnorm[i];
| 85 |
rpure = 0;
| 86 |
| 87 |
/* check for penetration */
| 88 |
if (rpure || DOT(nr.rdir, r->ron) <= FTINY)
| 89 |
| 90 |
| 91 |
| 92 |
rayvalue(&nr);
| 93 |
multcolor(nr.rcol, nr.rcoef);
| 94 |
addcolor(r->rcol, nr.rcol);
| 95 |
if (rpure && r->ro != NULL && isflat(r->ro->otype))
| 96 |
r->rt = r->rot + nr.rt;
| 97 |
return(1);
| 98 |
| 99 |
| 100 |
| 101 |
static int
| 102 |
mir_proj( /* compute a mirror's projection */
| 103 |
MAT4 pm,
| 104 |
register OBJREC *o,
| 105 |
SRCREC *s,
| 106 |
int n
| 107 |
| 108 |
| 109 |
FVECT nv, sc;
| 110 |
double od;
| 111 |
register int i, j;
| 112 |
/* get surface normal and offset */
| 113 |
od = getplaneq(nv, o);
| 114 |
/* check for extreme point for behind */
| 115 |
VCOPY(sc, s->sloc);
| 116 |
for (i = s->sflags & SFLAT ? SV : SW; i >= 0; i--)
| 117 |
if (DOT(nv, s->ss[i]) > 0.)
| 118 |
for (j = 0; j < 3; j++)
| 119 |
sc[j] += s->ss[i][j];
| 120 |
else
| 121 |
| 122 |
sc[j] -= s->ss[i][j];
| 123 |
if (DOT(sc, nv) <= (s->sflags & SDISTANT ? FTINY : od+FTINY))
| 124 |
return(0);
| 125 |
/* everything OK -- compute projection */
| 126 |
mirrorproj(pm, nv, od);
| 127 |
return(1);
| 128 |
| 129 |
| 130 |
| 131 |
static void
| 132 |
mirrorproj( /* get mirror projection for surface */
| 133 |
register MAT4 m,
| 134 |
FVECT nv,
| 135 |
double offs
| 136 |
| 137 |
| 138 |
register int i, j;
| 139 |
/* assign matrix */
| 140 |
setident4(m);
| 141 |
for (j = 0; j < 3; j++) {
| 142 |
| 143 |
m[i][j] -= 2.*nv[i]*nv[j];
| 144 |
m[3][j] = 2.*offs*nv[j];
| 145 |
| 146 |
