--- ray/src/rt/m_direct.c 1996/04/12 16:49:39 2.7 +++ ray/src/rt/m_direct.c 2023/11/15 18:02:53 2.17 @@ -1,20 +1,17 @@ -/* Copyright (c) 1994 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: m_direct.c,v 2.17 2023/11/15 18:02:53 greg Exp $"; #endif - /* * Routines for light-redirecting materials and * their associated virtual light sources */ -#include "ray.h" +#include "copyright.h" +#include "ray.h" #include "otypes.h" - +#include "rtotypes.h" #include "source.h" - #include "func.h" /* @@ -31,8 +28,9 @@ static char SCCSid[] = "$SunId$ LBL"; * n A1 A2 .. An */ +static int redirect(OBJREC *m, RAY *r, int n); +static int dir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n); -int dir_proj(); VSMATERIAL direct1_vs = {dir_proj, 1}; VSMATERIAL direct2_vs = {dir_proj, 2}; @@ -41,9 +39,11 @@ VSMATERIAL direct2_vs = {dir_proj, 2}; getfunc(m, 8, 0xff, 1) ) -m_direct(m, r) /* shade redirected ray */ -register OBJREC *m; -register RAY *r; +int +m_direct( /* shade redirected ray */ + OBJREC *m, + RAY *r +) { /* check if source ray */ if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) @@ -60,23 +60,25 @@ register RAY *r; } -redirect(m, r, n) /* compute n'th ray redirection */ -OBJREC *m; -RAY *r; -int n; +static int +redirect( /* compute n'th ray redirection */ + OBJREC *m, + RAY *r, + int n +) { MFUNC *mf; - register EPNODE **va; + EPNODE **va; FVECT nsdir; RAY nr; double coef; - register int j; + int j; /* set up function */ mf = getdfunc(m); setfunc(m, r); /* assign direction variable */ if (r->rsrc >= 0) { - register SRCREC *sp = source + source[r->rsrc].sa.sv.sn; + SRCREC *sp = source + source[r->rsrc].sa.sv.sn; if (sp->sflags & SDISTANT) VCOPY(nsdir, sp->sloc); @@ -98,18 +100,19 @@ int n; errno = 0; va = mf->ep + 4*n; coef = evalue(va[0]); - if (errno) + if ((errno == EDOM) | (errno == ERANGE)) goto computerr; - if (coef <= FTINY || rayorigin(&nr, r, TRANS, coef) < 0) + setscolor(nr.rcoef, coef, coef, coef); + if (rayorigin(&nr, TRANS, r, nr.rcoef) < 0) return(0); va++; /* compute direction */ for (j = 0; j < 3; j++) { nr.rdir[j] = evalue(va[j]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; } - if (mf->f != &unitxf) - multv3(nr.rdir, nr.rdir, mf->f->xfm); + if (mf->fxp != &unitxf) + multv3(nr.rdir, nr.rdir, mf->fxp->xfm); if (r->rox != NULL) multv3(nr.rdir, nr.rdir, r->rox->f.xfm); if (normalize(nr.rdir) == 0.0) @@ -118,10 +121,10 @@ int n; if (r->rsrc >= 0) nr.rsrc = source[r->rsrc].sa.sv.sn; rayvalue(&nr); - scalecolor(nr.rcol, coef); - addcolor(r->rcol, nr.rcol); + smultscolor(nr.rcol, nr.rcoef); + saddscolor(r->rcol, nr.rcol); if (r->ro != NULL && isflat(r->ro->otype)) - r->rt = r->rot + nr.rt; + r->rxt = r->rot + raydistance(&nr); return(1); computerr: objerror(m, WARNING, "compute error"); @@ -129,11 +132,13 @@ computerr: } -dir_proj(pm, o, s, n) /* compute a director's projection */ -MAT4 pm; -OBJREC *o; -SRCREC *s; -int n; +static int +dir_proj( /* compute a director's projection */ + MAT4 pm, + OBJREC *o, + SRCREC *s, + int n +) { RAY tr; OBJREC *m; @@ -141,7 +146,7 @@ int n; EPNODE **va; FVECT cent, newdir, nv, h; double coef, olddot, newdot, od; - register int i, j; + int i, j; /* initialize test ray */ getmaxdisk(cent, o); if (s->sflags & SDISTANT) @@ -162,7 +167,7 @@ int n; if (olddot <= FTINY && olddot >= -FTINY) return(0); /* old dir parallels plane */ tr.rmax = 0.0; - rayorigin(&tr, NULL, PRIMARY, 1.0); + rayorigin(&tr, PRIMARY, NULL, NULL); if (!(*ofun[o->otype].funp)(o, &tr)) return(0); /* no intersection! */ /* compute redirection */ @@ -175,18 +180,18 @@ int n; errno = 0; va = mf->ep + 4*n; coef = evalue(va[0]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; if (coef <= FTINY) return(0); /* insignificant */ va++; for (i = 0; i < 3; i++) { newdir[i] = evalue(va[i]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; } - if (mf->f != &unitxf) - multv3(newdir, newdir, mf->f->xfm); + if (mf->fxp != &unitxf) + multv3(newdir, newdir, mf->fxp->xfm); /* normalization unnecessary */ newdot = DOT(newdir, nv); if (newdot <= FTINY && newdot >= -FTINY) @@ -200,7 +205,7 @@ int n; pm[i][j] += nv[i]*h[j]; pm[3][j] = -od*h[j]; } - if (newdot > 0.0 ^ olddot > 0.0) /* add mirroring */ + if ((newdot > 0.0) ^ (olddot > 0.0)) /* add mirroring */ for (j = 0; j < 3; j++) { for (i = 0; i < 3; i++) pm[i][j] -= 2.*nv[i]*nv[j];
