--- ray/src/rt/m_direct.c 2005/04/19 01:15:06 2.13 +++ ray/src/rt/m_direct.c 2023/11/15 18:02:53 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_direct.c,v 2.13 2005/04/19 01:15:06 greg Exp $"; +static const char RCSid[] = "$Id: m_direct.c,v 2.17 2023/11/15 18:02:53 greg Exp $"; #endif /* * Routines for light-redirecting materials and @@ -39,10 +39,10 @@ VSMATERIAL direct2_vs = {dir_proj, 2}; getfunc(m, 8, 0xff, 1) ) -extern int +int m_direct( /* shade redirected ray */ - register OBJREC *m, - register RAY *r + OBJREC *m, + RAY *r ) { /* check if source ray */ @@ -68,17 +68,17 @@ redirect( /* compute n'th ray redirection */ ) { MFUNC *mf; - register EPNODE **va; + EPNODE **va; FVECT nsdir; RAY nr; double coef; - register int j; + int j; /* set up function */ mf = getdfunc(m); setfunc(m, r); /* assign direction variable */ if (r->rsrc >= 0) { - register SRCREC *sp = source + source[r->rsrc].sa.sv.sn; + SRCREC *sp = source + source[r->rsrc].sa.sv.sn; if (sp->sflags & SDISTANT) VCOPY(nsdir, sp->sloc); @@ -102,7 +102,7 @@ redirect( /* compute n'th ray redirection */ coef = evalue(va[0]); if ((errno == EDOM) | (errno == ERANGE)) goto computerr; - setcolor(nr.rcoef, coef, coef, coef); + setscolor(nr.rcoef, coef, coef, coef); if (rayorigin(&nr, TRANS, r, nr.rcoef) < 0) return(0); va++; /* compute direction */ @@ -111,8 +111,8 @@ redirect( /* compute n'th ray redirection */ if (errno == EDOM || errno == ERANGE) goto computerr; } - if (mf->f != &unitxf) - multv3(nr.rdir, nr.rdir, mf->f->xfm); + if (mf->fxp != &unitxf) + multv3(nr.rdir, nr.rdir, mf->fxp->xfm); if (r->rox != NULL) multv3(nr.rdir, nr.rdir, r->rox->f.xfm); if (normalize(nr.rdir) == 0.0) @@ -121,10 +121,10 @@ redirect( /* compute n'th ray redirection */ if (r->rsrc >= 0) nr.rsrc = source[r->rsrc].sa.sv.sn; rayvalue(&nr); - multcolor(nr.rcol, nr.rcoef); - addcolor(r->rcol, nr.rcol); + smultscolor(nr.rcol, nr.rcoef); + saddscolor(r->rcol, nr.rcol); if (r->ro != NULL && isflat(r->ro->otype)) - r->rt = r->rot + nr.rt; + r->rxt = r->rot + raydistance(&nr); return(1); computerr: objerror(m, WARNING, "compute error"); @@ -146,7 +146,7 @@ dir_proj( /* compute a director's projection */ EPNODE **va; FVECT cent, newdir, nv, h; double coef, olddot, newdot, od; - register int i, j; + int i, j; /* initialize test ray */ getmaxdisk(cent, o); if (s->sflags & SDISTANT) @@ -190,8 +190,8 @@ dir_proj( /* compute a director's projection */ if (errno == EDOM || errno == ERANGE) goto computerr; } - if (mf->f != &unitxf) - multv3(newdir, newdir, mf->f->xfm); + if (mf->fxp != &unitxf) + multv3(newdir, newdir, mf->fxp->xfm); /* normalization unnecessary */ newdot = DOT(newdir, nv); if (newdot <= FTINY && newdot >= -FTINY)
