--- ray/src/rt/m_direct.c 1991/11/25 09:51:06 2.2 +++ ray/src/rt/m_direct.c 2003/03/05 16:16:53 2.10 @@ -1,14 +1,13 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: m_direct.c,v 2.10 2003/03/05 16:16:53 greg Exp $"; #endif - /* * Routines for light-redirecting materials and * their associated virtual light sources */ +#include "copyright.h" + #include "ray.h" #include "otypes.h" @@ -32,7 +31,8 @@ static char SCCSid[] = "$SunId$ LBL"; */ -int dir_proj(); +static int dir_proj(); + VSMATERIAL direct1_vs = {dir_proj, 1}; VSMATERIAL direct2_vs = {dir_proj, 2}; @@ -41,13 +41,14 @@ VSMATERIAL direct2_vs = {dir_proj, 2}; getfunc(m, 8, 0xff, 1) ) +int m_direct(m, r) /* shade redirected ray */ register OBJREC *m; register RAY *r; { /* check if source ray */ if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) - return; /* got the wrong guy */ + return(1); /* got the wrong guy */ /* compute first projection */ if (m->otype == MAT_DIRECT1 || (r->rsrc < 0 || source[r->rsrc].sa.sv.pn == 0)) @@ -56,9 +57,11 @@ register RAY *r; if (m->otype == MAT_DIRECT2 && (r->rsrc < 0 || source[r->rsrc].sa.sv.pn == 1)) redirect(m, r, 1); + return(1); } +int redirect(m, r, n) /* compute n'th ray redirection */ OBJREC *m; RAY *r; @@ -66,24 +69,45 @@ int n; { MFUNC *mf; register EPNODE **va; + FVECT nsdir; RAY nr; double coef; register int j; /* set up function */ mf = getdfunc(m); setfunc(m, r); + /* assign direction variable */ + if (r->rsrc >= 0) { + register SRCREC *sp = source + source[r->rsrc].sa.sv.sn; + + if (sp->sflags & SDISTANT) + VCOPY(nsdir, sp->sloc); + else { + for (j = 0; j < 3; j++) + nsdir[j] = sp->sloc[j] - r->rop[j]; + normalize(nsdir); + } + multv3(nsdir, nsdir, funcxf.xfm); + varset("DxA", '=', nsdir[0]/funcxf.sca); + varset("DyA", '=', nsdir[1]/funcxf.sca); + varset("DzA", '=', nsdir[2]/funcxf.sca); + } else { + varset("DxA", '=', 0.0); + varset("DyA", '=', 0.0); + varset("DzA", '=', 0.0); + } /* compute coefficient */ errno = 0; va = mf->ep + 4*n; coef = evalue(va[0]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; if (coef <= FTINY || rayorigin(&nr, r, TRANS, coef) < 0) return(0); va++; /* compute direction */ for (j = 0; j < 3; j++) { nr.rdir[j] = evalue(va[j]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; } if (mf->f != &unitxf) @@ -98,6 +122,8 @@ int n; rayvalue(&nr); scalecolor(nr.rcol, coef); addcolor(r->rcol, nr.rcol); + if (r->ro != NULL && isflat(r->ro->otype)) + r->rt = r->rot + nr.rt; return(1); computerr: objerror(m, WARNING, "compute error"); @@ -105,6 +131,7 @@ computerr: } +static int dir_proj(pm, o, s, n) /* compute a director's projection */ MAT4 pm; OBJREC *o; @@ -137,6 +164,7 @@ int n; olddot = DOT(tr.rdir, nv); if (olddot <= FTINY && olddot >= -FTINY) return(0); /* old dir parallels plane */ + tr.rmax = 0.0; rayorigin(&tr, NULL, PRIMARY, 1.0); if (!(*ofun[o->otype].funp)(o, &tr)) return(0); /* no intersection! */ @@ -144,17 +172,20 @@ int n; m = vsmaterial(o); mf = getdfunc(m); setfunc(m, &tr); + varset("DxA", '=', 0.0); + varset("DyA", '=', 0.0); + varset("DzA", '=', 0.0); errno = 0; va = mf->ep + 4*n; coef = evalue(va[0]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; if (coef <= FTINY) return(0); /* insignificant */ va++; for (i = 0; i < 3; i++) { newdir[i] = evalue(va[i]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; } if (mf->f != &unitxf)
