--- ray/src/rt/m_direct.c 2012/06/09 07:16:47 2.14 +++ ray/src/rt/m_direct.c 2014/07/08 18:25:00 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_direct.c,v 2.14 2012/06/09 07:16:47 greg Exp $"; +static const char RCSid[] = "$Id: m_direct.c,v 2.15 2014/07/08 18:25:00 greg Exp $"; #endif /* * Routines for light-redirecting materials and @@ -39,10 +39,10 @@ VSMATERIAL direct2_vs = {dir_proj, 2}; getfunc(m, 8, 0xff, 1) ) -extern int +int m_direct( /* shade redirected ray */ - register OBJREC *m, - register RAY *r + OBJREC *m, + RAY *r ) { /* check if source ray */ @@ -68,17 +68,17 @@ redirect( /* compute n'th ray redirection */ ) { MFUNC *mf; - register EPNODE **va; + EPNODE **va; FVECT nsdir; RAY nr; double coef; - register int j; + int j; /* set up function */ mf = getdfunc(m); setfunc(m, r); /* assign direction variable */ if (r->rsrc >= 0) { - register SRCREC *sp = source + source[r->rsrc].sa.sv.sn; + SRCREC *sp = source + source[r->rsrc].sa.sv.sn; if (sp->sflags & SDISTANT) VCOPY(nsdir, sp->sloc); @@ -146,7 +146,7 @@ dir_proj( /* compute a director's projection */ EPNODE **va; FVECT cent, newdir, nv, h; double coef, olddot, newdot, od; - register int i, j; + int i, j; /* initialize test ray */ getmaxdisk(cent, o); if (s->sflags & SDISTANT)
