root/radiance/ray/src/rt/m_direct.c
Tue Jul 8 18:25:00 2014 UTC (10 years, 10 months ago) by greg
Changes since 2.14: +8 -8 lines
Sat Jun 9 07:16:47 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.13: +5 -5 lines
Tue Apr 19 01:15:06 2005 UTC (20 years ago) by greg
Changes since 2.12: +6 -5 lines
Changes since 2.11: +21 -20 lines
Sun Jul 27 22:12:03 2003 UTC (21 years, 9 months ago) by schorsch
Wed Mar 5 16:16:53 2003 UTC (22 years, 2 months ago) by greg
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.7: +63 -5 lines
Fri Apr 12 16:49:39 1996 UTC (29 years, 1 month ago) by greg
added isflat() macro and computation of effective ray distance
Thu Sep 7 12:35:21 1995 UTC (29 years, 8 months ago) by greg
Changes since 2.5: +9 -9 lines
made assignment of DxA, DyA, DzA a little more robust
Tue Dec 20 20:18:17 1994 UTC (30 years, 4 months ago) by greg
Wed Jan 12 16:46:39 1994 UTC (31 years, 4 months ago) by greg
Fri May 15 09:29:09 1992 UTC (33 years ago) by greg
Changes since 2.2: +24 -0 lines
added DxA, DyA and DzA variables for finding source direction
Mon Nov 25 09:51:06 1991 UTC (33 years, 5 months ago) by greg
Changes since 2.1: +38 -58 lines
Tue Nov 12 17:10:36 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.7 , to selected 2.5
Fri Nov 8 16:34:31 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.6 , to selected 2.5
Fri Nov 8 14:30:17 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.5: +30 -27 lines
Diff to previous 1.5 , to selected 2.5
fixed bug in call to funcfile()
Thu Aug 8 11:30:05 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.4: +1 -2 lines
Diff to previous 1.4 , to selected 2.5
added contexts to function files
Tue Aug 6 14:07:06 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.3: +28 -7 lines
Diff to previous 1.3 , to selected 2.5
fixed bugs in virtual sources through prisms
Tue Jul 16 17:16:32 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.2: +18 -6 lines
added missing funcfile argument!
Tue Jul 16 15:56:54 1991 UTC (33 years, 10 months ago) by greg
added redirecting materials
Tue Jul 16 15:44:30 1991 UTC (33 years, 10 months ago) by greg
Diff to selected 2.5
