--- ray/src/rt/m_direct.c 1991/07/16 15:44:30 1.1 +++ ray/src/rt/m_direct.c 1991/08/08 11:30:05 1.5 @@ -18,13 +18,13 @@ static char SCCSid[] = "$SunId$ LBL"; /* * The arguments for MAT_DIRECT1 are: * - * 4+ coef1 dx1 dy1 dz1 transform.. + * 5+ coef1 dx1 dy1 dz1 funcfile transform.. * 0 * n A1 A2 .. An * * The arguments for MAT_DIRECT2 are: * - * 8+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 transform.. + * 9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform.. * 0 * n A1 A2 .. An */ @@ -44,6 +44,7 @@ register RAY *r; /* check if source ray */ if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) return; /* got the wrong guy */ + dir_check(m); /* compute first projection */ if (m->otype == MAT_DIRECT1 || (r->rsrc < 0 || source[r->rsrc].sa.sv.pn == 0)) @@ -65,9 +66,7 @@ int n; double coef; register int j; /* set up function */ - setfunc(m, r); - if (m->oargs.nsargs < 4+4*n) - objerror(m, USER, "too few arguments"); + setmap(m, r, &((FULLXF *)m->os)->b); sa = m->oargs.sarg + 4*n; /* compute coefficient */ errno = 0; @@ -80,8 +79,13 @@ int n; errno = 0; for (j = 0; j < 3; j++) nr.rdir[j] = varvalue(sa[j+1]); - if (errno || normalize(nr.rdir) == 0.0) + if (errno) goto computerr; + multv3(nr.rdir, nr.rdir, ((FULLXF *)m->os)->f.xfm); + if (r->rox != NULL) + multv3(nr.rdir, nr.rdir, r->rox->f.xfm); + if (normalize(nr.rdir) == 0.0) + goto computerr; /* compute value */ if (r->rsrc >= 0) nr.rsrc = source[r->rsrc].sa.sv.sn; @@ -109,8 +113,7 @@ int n; register int i, j; /* get material arguments */ m = objptr(o->omod); - if (m->oargs.nsargs < 4+4*n) - objerror(m, USER, "too few arguments"); + dir_check(m); sa = m->oargs.sarg + 4*n; /* initialize test ray */ getmaxdisk(cent, o); @@ -122,7 +125,7 @@ int n; else { for (i = 0; i < 3; i++) { tr.rdir[i] = cent[i] - s->sloc[i]; - tr.rorg[i] = cent[i] - .05*tr.rdir[i]; + tr.rorg[i] = s->sloc[i]; } if (normalize(tr.rdir) == 0.0) return(0); /* at source! */ @@ -135,7 +138,7 @@ int n; if (!(*ofun[o->otype].funp)(o, &tr)) return(0); /* no intersection! */ /* compute redirection */ - setfunc(m, &tr); + setmap(m, &tr, &((FULLXF *)m->os)->b); errno = 0; if (varvalue(sa[0]) <= FTINY) return(0); /* insignificant */ @@ -145,12 +148,14 @@ int n; newdir[i] = varvalue(sa[i+1]); if (errno) goto computerr; + multv3(newdir, newdir, ((FULLXF *)m->os)->f.xfm); + /* normalization unnecessary */ newdot = DOT(newdir, nv); if (newdot <= FTINY && newdot >= -FTINY) return(0); /* new dir parallels plane */ /* everything OK -- compute shear */ for (i = 0; i < 3; i++) - h[i] = tr.rdir[i]/olddot + newdir[i]/newdot; + h[i] = newdir[i]/newdot - tr.rdir[i]/olddot; setident4(pm); for (j = 0; j < 3; j++) { for (i = 0; i < 3; i++) @@ -167,4 +172,31 @@ int n; computerr: objerror(m, WARNING, "projection compute error"); return(0); +} + + +static +dir_check(m) /* check arguments and load function file */ +register OBJREC *m; +{ + register FULLXF *mxf; + register int ff; + + ff = m->otype == MAT_DIRECT1 ? 5 : 9; + if (ff > m->oargs.nsargs) + objerror(m, USER, "too few arguments"); + funcfile(m->oargs.sarg[ff-1]); + if (m->os == NULL) { + mxf = (FULLXF *)malloc(sizeof(FULLXF)); + if (mxf == NULL) + error(SYSTEM, "out of memory in dir_check"); + if (fullxf(mxf, m->oargs.nsargs-ff, m->oargs.sarg+ff) != + m->oargs.nsargs-ff) + objerror(m, USER, "bad transform"); + if (mxf->f.sca < 0.0) + mxf->f.sca = -mxf->f.sca; + if (mxf->b.sca < 0.0) + mxf->b.sca = -mxf->b.sca; + m->os = (char *)mxf; + } }
