--- ray/src/rt/m_direct.c 1994/01/12 16:46:39 2.4 +++ ray/src/rt/m_direct.c 2004/03/30 16:13:01 2.12 @@ -1,20 +1,17 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: m_direct.c,v 2.12 2004/03/30 16:13:01 schorsch Exp $"; #endif - /* * Routines for light-redirecting materials and * their associated virtual light sources */ -#include "ray.h" +#include "copyright.h" +#include "ray.h" #include "otypes.h" - +#include "rtotypes.h" #include "source.h" - #include "func.h" /* @@ -31,8 +28,9 @@ static char SCCSid[] = "$SunId$ LBL"; * n A1 A2 .. An */ +static int redirect(OBJREC *m, RAY *r, int n); +static int dir_proj(MAT4 pm, OBJREC *o, SRCREC *s, int n); -int dir_proj(); VSMATERIAL direct1_vs = {dir_proj, 1}; VSMATERIAL direct2_vs = {dir_proj, 2}; @@ -41,9 +39,11 @@ VSMATERIAL direct2_vs = {dir_proj, 2}; getfunc(m, 8, 0xff, 1) ) -m_direct(m, r) /* shade redirected ray */ -register OBJREC *m; -register RAY *r; +extern int +m_direct( /* shade redirected ray */ + register OBJREC *m, + register RAY *r +) { /* check if source ray */ if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) @@ -60,10 +60,12 @@ register RAY *r; } -redirect(m, r, n) /* compute n'th ray redirection */ -OBJREC *m; -RAY *r; -int n; +static int +redirect( /* compute n'th ray redirection */ + OBJREC *m, + RAY *r, + int n +) { MFUNC *mf; register EPNODE **va; @@ -85,27 +87,27 @@ int n; nsdir[j] = sp->sloc[j] - r->rop[j]; normalize(nsdir); } - if (r->rox != NULL) - multv3(nsdir, nsdir, r->rox->b.xfm); - if (mf->b != &unitxf) - multv3(nsdir, nsdir, mf->b->xfm); - } else - nsdir[0] = nsdir[1] = nsdir[2] = 0.0; - varset("DxA", '=', nsdir[0]); - varset("DyA", '=', nsdir[1]); - varset("DzA", '=', nsdir[2]); + multv3(nsdir, nsdir, funcxf.xfm); + varset("DxA", '=', nsdir[0]/funcxf.sca); + varset("DyA", '=', nsdir[1]/funcxf.sca); + varset("DzA", '=', nsdir[2]/funcxf.sca); + } else { + varset("DxA", '=', 0.0); + varset("DyA", '=', 0.0); + varset("DzA", '=', 0.0); + } /* compute coefficient */ errno = 0; va = mf->ep + 4*n; coef = evalue(va[0]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; if (coef <= FTINY || rayorigin(&nr, r, TRANS, coef) < 0) return(0); va++; /* compute direction */ for (j = 0; j < 3; j++) { nr.rdir[j] = evalue(va[j]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; } if (mf->f != &unitxf) @@ -120,6 +122,8 @@ int n; rayvalue(&nr); scalecolor(nr.rcol, coef); addcolor(r->rcol, nr.rcol); + if (r->ro != NULL && isflat(r->ro->otype)) + r->rt = r->rot + nr.rt; return(1); computerr: objerror(m, WARNING, "compute error"); @@ -127,11 +131,13 @@ computerr: } -dir_proj(pm, o, s, n) /* compute a director's projection */ -MAT4 pm; -OBJREC *o; -SRCREC *s; -int n; +static int +dir_proj( /* compute a director's projection */ + MAT4 pm, + OBJREC *o, + SRCREC *s, + int n +) { RAY tr; OBJREC *m; @@ -159,6 +165,7 @@ int n; olddot = DOT(tr.rdir, nv); if (olddot <= FTINY && olddot >= -FTINY) return(0); /* old dir parallels plane */ + tr.rmax = 0.0; rayorigin(&tr, NULL, PRIMARY, 1.0); if (!(*ofun[o->otype].funp)(o, &tr)) return(0); /* no intersection! */ @@ -172,14 +179,14 @@ int n; errno = 0; va = mf->ep + 4*n; coef = evalue(va[0]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; if (coef <= FTINY) return(0); /* insignificant */ va++; for (i = 0; i < 3; i++) { newdir[i] = evalue(va[i]); - if (errno) + if (errno == EDOM || errno == ERANGE) goto computerr; } if (mf->f != &unitxf) @@ -197,7 +204,7 @@ int n; pm[i][j] += nv[i]*h[j]; pm[3][j] = -od*h[j]; } - if (newdot > 0.0 ^ olddot > 0.0) /* add mirroring */ + if ((newdot > 0.0) ^ (olddot > 0.0)) /* add mirroring */ for (j = 0; j < 3; j++) { for (i = 0; i < 3; i++) pm[i][j] -= 2.*nv[i]*nv[j];
