--- ray/src/rt/m_direct.c 1991/08/06 14:07:06 1.4 +++ ray/src/rt/m_direct.c 1991/11/08 16:34:31 1.7 @@ -36,7 +36,35 @@ int dir_proj(); VSMATERIAL direct1_vs = {dir_proj, 1}; VSMATERIAL direct2_vs = {dir_proj, 2}; +#define fndx(m) ((m)->otype == MAT_DIRECT1 ? 4 : 8) + +static +dir_check(m) /* check arguments and load function file */ +register OBJREC *m; +{ + register FULLXF *mxf; + register int ff; + + ff = fndx(m)+1; + if (ff > m->oargs.nsargs) + objerror(m, USER, "too few arguments"); + if (m->os == NULL) { + mxf = (FULLXF *)malloc(sizeof(FULLXF)); + if (mxf == NULL) + error(SYSTEM, "out of memory in dir_check"); + if (fullxf(mxf, m->oargs.nsargs-ff, m->oargs.sarg+ff) != + m->oargs.nsargs-ff) + objerror(m, USER, "bad transform"); + if (mxf->f.sca < 0.0) + mxf->f.sca = -mxf->f.sca; + if (mxf->b.sca < 0.0) + mxf->b.sca = -mxf->b.sca; + m->os = (char *)mxf; + } +} + + m_direct(m, r) /* shade redirected ray */ register OBJREC *m; register RAY *r; @@ -67,6 +95,7 @@ int n; register int j; /* set up function */ setmap(m, r, &((FULLXF *)m->os)->b); + funcfile(m->oargs.sarg[fndx(m)]); sa = m->oargs.sarg + 4*n; /* compute coefficient */ errno = 0; @@ -112,7 +141,7 @@ int n; double olddot, newdot, od; register int i, j; /* get material arguments */ - m = objptr(o->omod); + m = vsmaterial(o); dir_check(m); sa = m->oargs.sarg + 4*n; /* initialize test ray */ @@ -139,6 +168,7 @@ int n; return(0); /* no intersection! */ /* compute redirection */ setmap(m, &tr, &((FULLXF *)m->os)->b); + funcfile(m->oargs.sarg[fndx(m)]); errno = 0; if (varvalue(sa[0]) <= FTINY) return(0); /* insignificant */ @@ -172,32 +202,4 @@ int n; computerr: objerror(m, WARNING, "projection compute error"); return(0); -} - - -static -dir_check(m) /* check arguments and load function file */ -register OBJREC *m; -{ - register FULLXF *mxf; - register int ff; - - ff = m->otype == MAT_DIRECT1 ? 5 : 9; - if (ff > m->oargs.nsargs) - objerror(m, USER, "too few arguments"); - if (!vardefined(m->oargs.sarg[0])) - loadfunc(m->oargs.sarg[ff-1]); - if (m->os == NULL) { - mxf = (FULLXF *)malloc(sizeof(FULLXF)); - if (mxf == NULL) - error(SYSTEM, "out of memory in dir_check"); - if (fullxf(mxf, m->oargs.nsargs-ff, m->oargs.sarg+ff) != - m->oargs.nsargs-ff) - objerror(m, USER, "bad transform"); - if (mxf->f.sca < 0.0) - mxf->f.sca = -mxf->f.sca; - if (mxf->b.sca < 0.0) - mxf->b.sca = -mxf->b.sca; - m->os = (char *)mxf; - } }
