--- ray/src/rt/m_direct.c 1991/11/25 09:51:06 2.2 +++ ray/src/rt/m_direct.c 2003/02/22 02:07:28 2.8 @@ -1,14 +1,68 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: m_direct.c,v 2.8 2003/02/22 02:07:28 greg Exp $"; #endif - /* * Routines for light-redirecting materials and * their associated virtual light sources */ +/* ==================================================================== + * The Radiance Software License, Version 1.0 + * + * Copyright (c) 1990 - 2002 The Regents of the University of California, + * through Lawrence Berkeley National Laboratory. All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * + * 3. The end-user documentation included with the redistribution, + * if any, must include the following acknowledgment: + * "This product includes Radiance software + * (http://radsite.lbl.gov/) + * developed by the Lawrence Berkeley National Laboratory + * (http://www.lbl.gov/)." + * Alternately, this acknowledgment may appear in the software itself, + * if and wherever such third-party acknowledgments normally appear. + * + * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" + * and "The Regents of the University of California" must + * not be used to endorse or promote products derived from this + * software without prior written permission. For written + * permission, please contact radiance@radsite.lbl.gov. + * + * 5. Products derived from this software may not be called "Radiance", + * nor may "Radiance" appear in their name, without prior written + * permission of Lawrence Berkeley National Laboratory. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR + * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * ==================================================================== + * + * This software consists of voluntary contributions made by many + * individuals on behalf of Lawrence Berkeley National Laboratory. For more + * information on Lawrence Berkeley National Laboratory, please see + * . + */ + #include "ray.h" #include "otypes.h" @@ -32,7 +86,8 @@ static char SCCSid[] = "$SunId$ LBL"; */ -int dir_proj(); +static int dir_proj(); + VSMATERIAL direct1_vs = {dir_proj, 1}; VSMATERIAL direct2_vs = {dir_proj, 2}; @@ -41,13 +96,14 @@ VSMATERIAL direct2_vs = {dir_proj, 2}; getfunc(m, 8, 0xff, 1) ) +int m_direct(m, r) /* shade redirected ray */ register OBJREC *m; register RAY *r; { /* check if source ray */ if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) - return; /* got the wrong guy */ + return(1); /* got the wrong guy */ /* compute first projection */ if (m->otype == MAT_DIRECT1 || (r->rsrc < 0 || source[r->rsrc].sa.sv.pn == 0)) @@ -56,9 +112,11 @@ register RAY *r; if (m->otype == MAT_DIRECT2 && (r->rsrc < 0 || source[r->rsrc].sa.sv.pn == 1)) redirect(m, r, 1); + return(1); } +int redirect(m, r, n) /* compute n'th ray redirection */ OBJREC *m; RAY *r; @@ -66,12 +124,33 @@ int n; { MFUNC *mf; register EPNODE **va; + FVECT nsdir; RAY nr; double coef; register int j; /* set up function */ mf = getdfunc(m); setfunc(m, r); + /* assign direction variable */ + if (r->rsrc >= 0) { + register SRCREC *sp = source + source[r->rsrc].sa.sv.sn; + + if (sp->sflags & SDISTANT) + VCOPY(nsdir, sp->sloc); + else { + for (j = 0; j < 3; j++) + nsdir[j] = sp->sloc[j] - r->rop[j]; + normalize(nsdir); + } + multv3(nsdir, nsdir, funcxf.xfm); + varset("DxA", '=', nsdir[0]/funcxf.sca); + varset("DyA", '=', nsdir[1]/funcxf.sca); + varset("DzA", '=', nsdir[2]/funcxf.sca); + } else { + varset("DxA", '=', 0.0); + varset("DyA", '=', 0.0); + varset("DzA", '=', 0.0); + } /* compute coefficient */ errno = 0; va = mf->ep + 4*n; @@ -98,6 +177,8 @@ int n; rayvalue(&nr); scalecolor(nr.rcol, coef); addcolor(r->rcol, nr.rcol); + if (r->ro != NULL && isflat(r->ro->otype)) + r->rt = r->rot + nr.rt; return(1); computerr: objerror(m, WARNING, "compute error"); @@ -105,6 +186,7 @@ computerr: } +static int dir_proj(pm, o, s, n) /* compute a director's projection */ MAT4 pm; OBJREC *o; @@ -137,6 +219,7 @@ int n; olddot = DOT(tr.rdir, nv); if (olddot <= FTINY && olddot >= -FTINY) return(0); /* old dir parallels plane */ + tr.rmax = 0.0; rayorigin(&tr, NULL, PRIMARY, 1.0); if (!(*ofun[o->otype].funp)(o, &tr)) return(0); /* no intersection! */ @@ -144,6 +227,9 @@ int n; m = vsmaterial(o); mf = getdfunc(m); setfunc(m, &tr); + varset("DxA", '=', 0.0); + varset("DyA", '=', 0.0); + varset("DzA", '=', 0.0); errno = 0; va = mf->ep + 4*n; coef = evalue(va[0]);
