1 |
greg |
1.1 |
#ifndef lint |
2 |
greg |
2.13 |
static const char RCSid[] = "$Id: m_clip.c,v 2.12 2017/04/08 00:09:35 greg Exp $"; |
3 |
greg |
1.1 |
#endif |
4 |
5 |
* m_clip.c - routine for clipped (cut) objects. |
6 |
greg |
2.5 |
7 |
8 |
greg |
2.6 |
#include "copyright.h" |
9 |
greg |
1.1 |
10 |
#include "ray.h" |
11 |
schorsch |
2.8 |
#include "rtotypes.h" |
12 |
greg |
1.1 |
13 |
14 |
* Clipping objects permit holes and sections to be taken out |
15 |
greg |
2.12 |
* of other objects. |
16 |
greg |
1.1 |
17 |
* The argument is the clipped materials; |
18 |
* the first is used to shade upon exit. |
19 |
greg |
2.12 |
20 |
* In the simple case of the first argument being "void", we |
21 |
* just add or subtract (depending on whether we're coming or going) |
22 |
* the list of modifiers to the ray's "newcset", which will then |
23 |
* take over for "clipset" on penetration. Any surface modifier |
24 |
* names found in "clipset" will be treated as invisible in raycont(). |
25 |
26 |
* In the more complicated case of a non-void material as the |
27 |
* first argument, we have to backtrack up the ray tree to count |
28 |
* the number of times we've penetrated the front side of one of |
29 |
* the surfaces we care about. This relies on outward-facing |
30 |
* surface normals and closed objects, so is somewhat error-prone. |
31 |
greg |
1.1 |
32 |
33 |
34 |
greg |
2.11 |
int |
35 |
schorsch |
2.8 |
m_clip( /* clip objects from ray */ |
36 |
greg |
2.11 |
OBJREC *m, |
37 |
RAY *r |
38 |
schorsch |
2.8 |
39 |
greg |
1.1 |
40 |
OBJECT cset[MAXSET+1], *modset; |
41 |
gwlarson |
2.4 |
OBJECT obj, mod; |
42 |
greg |
1.1 |
int entering; |
43 |
greg |
2.11 |
int i; |
44 |
greg |
1.1 |
45 |
gwlarson |
2.4 |
obj = objndx(m); |
46 |
greg |
1.1 |
if ((modset = (OBJECT *)m->os) == NULL) { |
47 |
if (m->oargs.nsargs < 1 || m->oargs.nsargs > MAXSET) |
48 |
objerror(m, USER, "bad # arguments"); |
49 |
modset = (OBJECT *)malloc((m->oargs.nsargs+1)*sizeof(OBJECT)); |
50 |
if (modset == NULL) |
51 |
error(SYSTEM, "out of memory in m_clip"); |
52 |
modset[0] = 0; |
53 |
for (i = 0; i < m->oargs.nsargs; i++) { |
54 |
if (!strcmp(m->oargs.sarg[i], VOIDID)) |
55 |
continue; |
56 |
greg |
2.3 |
if ((mod = lastmod(obj, m->oargs.sarg[i])) == OVOID) { |
57 |
greg |
1.1 |
sprintf(errmsg, "unknown modifier \"%s\"", |
58 |
m->oargs.sarg[i]); |
59 |
objerror(m, WARNING, errmsg); |
60 |
continue; |
61 |
62 |
if (inset(modset, mod)) { |
63 |
objerror(m, WARNING, "duplicate modifier"); |
64 |
continue; |
65 |
66 |
insertelem(modset, mod); |
67 |
68 |
greg |
1.2 |
m->os = (char *)modset; |
69 |
greg |
1.1 |
70 |
greg |
2.10 |
if (r == NULL) |
71 |
return(0); /* just initializing */ |
72 |
greg |
1.1 |
if (r->clipset != NULL) |
73 |
setcopy(cset, r->clipset); |
74 |
else |
75 |
cset[0] = 0; |
76 |
77 |
greg |
2.11 |
entering = (r->rod > 0.0); /* entering clipped region? */ |
78 |
greg |
1.1 |
79 |
greg |
2.11 |
for (i = modset[0]; i > 0; i--) |
80 |
greg |
1.1 |
if (entering) { |
81 |
if (!inset(cset, modset[i])) { |
82 |
if (cset[0] >= MAXSET) |
83 |
error(INTERNAL, "set overflow in m_clip"); |
84 |
insertelem(cset, modset[i]); |
85 |
86 |
greg |
2.11 |
} else if (inset(cset, modset[i])) |
87 |
deletelem(cset, modset[i]); |
88 |
89 |
greg |
1.1 |
/* compute ray value */ |
90 |
r->newcset = cset; |
91 |
if (strcmp(m->oargs.sarg[0], VOIDID)) { |
92 |
int inside = 0; |
93 |
greg |
2.11 |
const RAY *rp; |
94 |
greg |
1.1 |
/* check for penetration */ |
95 |
for (rp = r; rp->parent != NULL; rp = rp->parent) |
96 |
greg |
2.13 |
if ((rp->rtype == RAYREFL) & (rp->parent->ro != NULL) |
97 |
schorsch |
2.7 |
&& inset(modset, rp->parent->ro->omod)) { |
98 |
greg |
1.1 |
if (rp->parent->rod > 0.0) |
99 |
inside++; |
100 |
else |
101 |
inside--; |
102 |
schorsch |
2.7 |
103 |
greg |
1.1 |
if (inside > 0) { /* we just hit the object */ |
104 |
flipsurface(r); |
105 |
gwlarson |
2.4 |
return(rayshade(r, lastmod(obj, m->oargs.sarg[0]))); |
106 |
greg |
1.1 |
107 |
108 |
raytrans(r); /* else transfer ray */ |
109 |
greg |
2.2 |
return(1); |
110 |
greg |
1.1 |
