1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: m_clip.c,v 2.10 2007/07/25 04:12:36 greg Exp $"; |
3 |
#endif |
4 |
5 |
* m_clip.c - routine for clipped (cut) objects. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
#include "rtotypes.h" |
12 |
13 |
14 |
* Clipping objects permit holes and sections to be taken out |
15 |
* of other objects. The method is simple: |
16 |
17 |
* The argument is the clipped materials; |
18 |
* the first is used to shade upon exit. |
19 |
20 |
21 |
22 |
int |
23 |
m_clip( /* clip objects from ray */ |
24 |
OBJREC *m, |
25 |
RAY *r |
26 |
27 |
28 |
OBJECT cset[MAXSET+1], *modset; |
29 |
OBJECT obj, mod; |
30 |
int entering; |
31 |
int i; |
32 |
33 |
obj = objndx(m); |
34 |
if ((modset = (OBJECT *)m->os) == NULL) { |
35 |
if (m->oargs.nsargs < 1 || m->oargs.nsargs > MAXSET) |
36 |
objerror(m, USER, "bad # arguments"); |
37 |
modset = (OBJECT *)malloc((m->oargs.nsargs+1)*sizeof(OBJECT)); |
38 |
if (modset == NULL) |
39 |
error(SYSTEM, "out of memory in m_clip"); |
40 |
modset[0] = 0; |
41 |
for (i = 0; i < m->oargs.nsargs; i++) { |
42 |
if (!strcmp(m->oargs.sarg[i], VOIDID)) |
43 |
continue; |
44 |
if ((mod = lastmod(obj, m->oargs.sarg[i])) == OVOID) { |
45 |
sprintf(errmsg, "unknown modifier \"%s\"", |
46 |
m->oargs.sarg[i]); |
47 |
objerror(m, WARNING, errmsg); |
48 |
continue; |
49 |
50 |
if (inset(modset, mod)) { |
51 |
objerror(m, WARNING, "duplicate modifier"); |
52 |
continue; |
53 |
54 |
insertelem(modset, mod); |
55 |
56 |
m->os = (char *)modset; |
57 |
58 |
if (r == NULL) |
59 |
return(0); /* just initializing */ |
60 |
if (r->clipset != NULL) |
61 |
setcopy(cset, r->clipset); |
62 |
else |
63 |
cset[0] = 0; |
64 |
65 |
entering = (r->rod > 0.0); /* entering clipped region? */ |
66 |
67 |
for (i = modset[0]; i > 0; i--) |
68 |
if (entering) { |
69 |
if (!inset(cset, modset[i])) { |
70 |
if (cset[0] >= MAXSET) |
71 |
error(INTERNAL, "set overflow in m_clip"); |
72 |
insertelem(cset, modset[i]); |
73 |
74 |
} else if (inset(cset, modset[i])) |
75 |
deletelem(cset, modset[i]); |
76 |
77 |
/* compute ray value */ |
78 |
r->newcset = cset; |
79 |
if (strcmp(m->oargs.sarg[0], VOIDID)) { |
80 |
int inside = 0; |
81 |
const RAY *rp; |
82 |
/* check for penetration */ |
83 |
for (rp = r; rp->parent != NULL; rp = rp->parent) |
84 |
if (!(rp->rtype & RAYREFL) && rp->parent->ro != NULL |
85 |
&& inset(modset, rp->parent->ro->omod)) { |
86 |
if (rp->parent->rod > 0.0) |
87 |
inside++; |
88 |
else |
89 |
inside--; |
90 |
91 |
if (inside > 0) { /* we just hit the object */ |
92 |
flipsurface(r); |
93 |
return(rayshade(r, lastmod(obj, m->oargs.sarg[0]))); |
94 |
95 |
96 |
raytrans(r); /* else transfer ray */ |
97 |
return(1); |
98 |
