--- ray/src/rt/m_clip.c 2013/08/20 21:37:46 2.11 +++ ray/src/rt/m_clip.c 2017/04/08 00:09:35 2.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_clip.c,v 2.11 2013/08/20 21:37:46 greg Exp $"; +static const char RCSid[] = "$Id: m_clip.c,v 2.12 2017/04/08 00:09:35 greg Exp $"; #endif /* * m_clip.c - routine for clipped (cut) objects. @@ -12,10 +12,22 @@ static const char RCSid[] = "$Id: m_clip.c,v 2.11 2013 /* * Clipping objects permit holes and sections to be taken out - * of other objects. The method is simple: + * of other objects. * * The argument is the clipped materials; * the first is used to shade upon exit. + * + * In the simple case of the first argument being "void", we + * just add or subtract (depending on whether we're coming or going) + * the list of modifiers to the ray's "newcset", which will then + * take over for "clipset" on penetration. Any surface modifier + * names found in "clipset" will be treated as invisible in raycont(). + * + * In the more complicated case of a non-void material as the + * first argument, we have to backtrack up the ray tree to count + * the number of times we've penetrated the front side of one of + * the surfaces we care about. This relies on outward-facing + * surface normals and closed objects, so is somewhat error-prone. */
