root/radiance/ray/src/rt/m_clip.c
Thu Apr 4 20:04:11 2024 UTC (16 months ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.13 , to selected 2.4
fix: Regression introduced in previous change (almost 5 years ago!)
Sat May 4 03:14:04 2019 UTC (6 years, 3 months ago) by greg
CVS Tags: rad5R3, rad5R4
Minor optimization shouldn't affect behavior
Sat Apr 8 00:09:35 2017 UTC (8 years, 4 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.11: +14 -2 lines
Clarified antimatter behavior in documentation and code comments
Tue Aug 20 21:37:46 2013 UTC (11 years, 11 months ago) by greg
Changes since 2.10: +11 -13 lines
Minor code clean-up
Wed Jul 25 04:12:36 2007 UTC (18 years ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Changes since 2.9: +3 -1 lines
Tue Apr 19 01:15:06 2005 UTC (20 years, 3 months ago) by greg
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.7: +7 -5 lines
Mon Jul 21 22:30:19 2003 UTC (22 years ago) by schorsch
Tue Feb 25 02:47:22 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:28 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.4: +58 -5 lines
Mon Aug 10 18:38:56 1998 UTC (27 years ago) by gwlarson
Changes since 2.3: +5 -6 lines
Mon Feb 12 17:04:08 1996 UTC (29 years, 6 months ago) by greg
fixed problem with redefined modifiers in clip set
Wed Jan 12 16:46:37 1994 UTC (31 years, 7 months ago) by greg
Tue Nov 12 17:08:41 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.2 , to selected 2.4
Tue Feb 21 14:56:19 1989 UTC (36 years, 5 months ago) by greg
Diff to previous 1.1 , to selected 2.4
portability fixes
Thu Feb 2 10:41:26 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 2.4
