root/radiance/ray/src/rt/m_clip.c
Sat May 4 03:14:04 2019 UTC (5 years ago) by greg
CVS Tags: rad5R3, rad5R4
Diff to previous 2.12
Minor optimization shouldn't affect behavior
Sat Apr 8 00:09:35 2017 UTC (7 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.11: +14 -2 lines
Clarified antimatter behavior in documentation and code comments
Tue Aug 20 21:37:46 2013 UTC (10 years, 9 months ago) by greg
Changes since 2.10: +11 -13 lines
Minor code clean-up
Wed Jul 25 04:12:36 2007 UTC (16 years, 10 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Changes since 2.9: +3 -1 lines
Changes since 2.7: +7 -5 lines
Changes since 2.4: +58 -5 lines
Mon Aug 10 18:38:56 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.3: +5 -6 lines
Mon Feb 12 17:04:08 1996 UTC (28 years, 3 months ago) by greg
fixed problem with redefined modifiers in clip set
Wed Jan 12 16:46:37 1994 UTC (30 years, 4 months ago) by greg
Tue Nov 12 17:08:41 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.2
Tue Feb 21 14:56:19 1989 UTC (35 years, 3 months ago) by greg
Diff to previous 1.1
portability fixes
Thu Feb 2 10:41:26 1989 UTC (35 years, 4 months ago) by greg
