root/radiance/ray/src/rt/m_clip.c
Revision: 2.8
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.7: +7 -5 lines
2 static const char RCSid[] = "$Id: m_clip.c,v 2.7 2003/07/21 22:30:19 schorsch Exp $";
5 * m_clip.c - routine for clipped (cut) objects.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "rtotypes.h"
12
13 /*
14 * Clipping objects permit holes and sections to be taken out
15 * of other objects. The method is simple:
16 *
17 * The argument is the clipped materials;
18 * the first is used to shade upon exit.
19 */
20
21
22 extern int
23 m_clip( /* clip objects from ray */
24 register OBJREC *m,
25 register RAY *r
26 )
27 {
28 OBJECT cset[MAXSET+1], *modset;
29 OBJECT obj, mod;
30 int entering;
31 register int i;
32
33 obj = objndx(m);
34 if ((modset = (OBJECT *)m->os) == NULL) {
35 if (m->oargs.nsargs < 1 || m->oargs.nsargs > MAXSET)
36 objerror(m, USER, "bad # arguments");
37 modset = (OBJECT *)malloc((m->oargs.nsargs+1)*sizeof(OBJECT));
38 if (modset == NULL)
39 error(SYSTEM, "out of memory in m_clip");
40 modset[0] = 0;
41 for (i = 0; i < m->oargs.nsargs; i++) {
42 if (!strcmp(m->oargs.sarg[i], VOIDID))
43 continue;
44 if ((mod = lastmod(obj, m->oargs.sarg[i])) == OVOID) {
45 sprintf(errmsg, "unknown modifier \"%s\"",
46 m->oargs.sarg[i]);
47 objerror(m, WARNING, errmsg);
48 continue;
49 }
50 if (inset(modset, mod)) {
51 objerror(m, WARNING, "duplicate modifier");
52 continue;
53 }
54 insertelem(modset, mod);
55 }
56 m->os = (char *)modset;
57 }
58 if (r->clipset != NULL)
59 setcopy(cset, r->clipset);
60 else
61 cset[0] = 0;
62
63 entering = r->rod > 0.0; /* entering clipped region? */
64
65 for (i = modset[0]; i > 0; i--) {
66 if (entering) {
67 if (!inset(cset, modset[i])) {
68 if (cset[0] >= MAXSET)
69 error(INTERNAL, "set overflow in m_clip");
70 insertelem(cset, modset[i]);
71 }
72 } else {
73 if (inset(cset, modset[i]))
74 deletelem(cset, modset[i]);
75 }
76 }
77 /* compute ray value */
78 r->newcset = cset;
79 if (strcmp(m->oargs.sarg[0], VOIDID)) {
80 int inside = 0;
81 register RAY *rp;
82 /* check for penetration */
83 for (rp = r; rp->parent != NULL; rp = rp->parent)
84 if (!(rp->rtype & RAYREFL) && rp->parent->ro != NULL
85 && inset(modset, rp->parent->ro->omod)) {
86 if (rp->parent->rod > 0.0)
87 inside++;
88 else
89 inside--;
90 }
91 if (inside > 0) { /* we just hit the object */
92 flipsurface(r);
93 return(rayshade(r, lastmod(obj, m->oargs.sarg[0])));
94 }
95 }
96 raytrans(r); /* else transfer ray */
97 return(1);
98 }
