root/radiance/ray/src/rt/m_clip.c
Revision: 1.1
Committed: Thu Feb 2 10:41:26 1989 UTC (36 years, 5 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * m_clip.c - routine for clipped (cut) objects.
9 *
10 * 3/17/86
11 */
12
13 #include "ray.h"
14
15 /*
16 * Clipping objects permit holes and sections to be taken out
17 * of other objects. The method is simple:
18 *
19 * The argument is the clipped materials;
20 * the first is used to shade upon exit.
21 */
22
23
24 m_clip(m, r) /* clip objects from ray */
25 register OBJREC *m;
26 register RAY *r;
27 {
28 OBJECT cset[MAXSET+1], *modset;
29 int entering;
30 register int i;
31
32 if ((modset = (OBJECT *)m->os) == NULL) {
33 register OBJECT mod;
34
35 if (m->oargs.nsargs < 1 || m->oargs.nsargs > MAXSET)
36 objerror(m, USER, "bad # arguments");
37 modset = (OBJECT *)malloc((m->oargs.nsargs+1)*sizeof(OBJECT));
38 if (modset == NULL)
39 error(SYSTEM, "out of memory in m_clip");
40 modset[0] = 0;
41 for (i = 0; i < m->oargs.nsargs; i++) {
42 if (!strcmp(m->oargs.sarg[i], VOIDID))
43 continue;
44 if ((mod = modifier(m->oargs.sarg[i])) == OVOID) {
45 sprintf(errmsg, "unknown modifier \"%s\"",
46 m->oargs.sarg[i]);
47 objerror(m, WARNING, errmsg);
48 continue;
49 }
50 if (inset(modset, mod)) {
51 objerror(m, WARNING, "duplicate modifier");
52 continue;
53 }
54 insertelem(modset, mod);
55 }
56 (OBJECT *)m->os = modset;
57 }
58 if (r->clipset != NULL)
59 setcopy(cset, r->clipset);
60 else
61 cset[0] = 0;
62
63 entering = r->rod > 0.0; /* entering clipped region? */
64
65 for (i = modset[0]; i > 0; i--) {
66 if (entering) {
67 if (!inset(cset, modset[i])) {
68 if (cset[0] >= MAXSET)
69 error(INTERNAL, "set overflow in m_clip");
70 insertelem(cset, modset[i]);
71 }
72 } else {
73 if (inset(cset, modset[i]))
74 deletelem(cset, modset[i]);
75 }
76 }
77 /* compute ray value */
78 r->newcset = cset;
79 if (strcmp(m->oargs.sarg[0], VOIDID)) {
80 int inside = 0;
81 register RAY *rp;
82 /* check for penetration */
83 for (rp = r; rp->parent != NULL; rp = rp->parent)
84 if (!(rp->rtype & RAYREFL) && rp->parent->ro != NULL
85 && inset(modset, rp->parent->ro->omod))
86 if (rp->parent->rod > 0.0)
87 inside++;
88 else
89 inside--;
90 if (inside > 0) { /* we just hit the object */
91 flipsurface(r);
92 rayshade(r, modifier(m->oargs.sarg[0]));
93 return;
94 }
95 }
96 raytrans(r); /* else transfer ray */
97 }
