root/radiance/ray/src/rt/m_clip.c
Revision: 2.14
Committed: Thu Apr 4 20:04:11 2024 UTC (16 months ago) by greg
CVS Tags: rad6R0, HEAD
fix: Regression introduced in previous change (almost 5 years ago!)
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.14 static const char RCSid[] = "$Id: m_clip.c,v 2.13 2019/05/04 03:14:04 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * m_clip.c - routine for clipped (cut) objects.
6 greg 2.5 */
7
8 greg 2.6 #include "copyright.h"
9 greg 1.1
10     #include "ray.h"
11 schorsch 2.8 #include "rtotypes.h"
12 greg 1.1
13     /*
14     * Clipping objects permit holes and sections to be taken out
15 greg 2.12 * of other objects.
16 greg 1.1 *
17     * The argument is the clipped materials;
18     * the first is used to shade upon exit.
19 greg 2.12 *
20     * In the simple case of the first argument being "void", we
21     * just add or subtract (depending on whether we're coming or going)
22     * the list of modifiers to the ray's "newcset", which will then
23     * take over for "clipset" on penetration. Any surface modifier
24     * names found in "clipset" will be treated as invisible in raycont().
25     *
26     * In the more complicated case of a non-void material as the
27     * first argument, we have to backtrack up the ray tree to count
28     * the number of times we've penetrated the front side of one of
29     * the surfaces we care about. This relies on outward-facing
30     * surface normals and closed objects, so is somewhat error-prone.
31 greg 1.1 */
32
33
34 greg 2.11 int
35 schorsch 2.8 m_clip( /* clip objects from ray */
36 greg 2.11 OBJREC *m,
37     RAY *r
38 schorsch 2.8 )
39 greg 1.1 {
40     OBJECT cset[MAXSET+1], *modset;
41 gwlarson 2.4 OBJECT obj, mod;
42 greg 1.1 int entering;
43 greg 2.11 int i;
44 greg 1.1
45 gwlarson 2.4 obj = objndx(m);
46 greg 1.1 if ((modset = (OBJECT *)m->os) == NULL) {
47     if (m->oargs.nsargs < 1 || m->oargs.nsargs > MAXSET)
48     objerror(m, USER, "bad # arguments");
49     modset = (OBJECT *)malloc((m->oargs.nsargs+1)*sizeof(OBJECT));
50     if (modset == NULL)
51     error(SYSTEM, "out of memory in m_clip");
52     modset[0] = 0;
53     for (i = 0; i < m->oargs.nsargs; i++) {
54     if (!strcmp(m->oargs.sarg[i], VOIDID))
55     continue;
56 greg 2.3 if ((mod = lastmod(obj, m->oargs.sarg[i])) == OVOID) {
57 greg 1.1 sprintf(errmsg, "unknown modifier \"%s\"",
58     m->oargs.sarg[i]);
59     objerror(m, WARNING, errmsg);
60     continue;
61     }
62     if (inset(modset, mod)) {
63     objerror(m, WARNING, "duplicate modifier");
64     continue;
65     }
66     insertelem(modset, mod);
67     }
68 greg 1.2 m->os = (char *)modset;
69 greg 1.1 }
70 greg 2.10 if (r == NULL)
71     return(0); /* just initializing */
72 greg 1.1 if (r->clipset != NULL)
73     setcopy(cset, r->clipset);
74     else
75     cset[0] = 0;
76
77 greg 2.11 entering = (r->rod > 0.0); /* entering clipped region? */
78 greg 1.1
79 greg 2.11 for (i = modset[0]; i > 0; i--)
80 greg 1.1 if (entering) {
81     if (!inset(cset, modset[i])) {
82     if (cset[0] >= MAXSET)
83     error(INTERNAL, "set overflow in m_clip");
84     insertelem(cset, modset[i]);
85     }
86 greg 2.11 } else if (inset(cset, modset[i]))
87     deletelem(cset, modset[i]);
88
89 greg 1.1 /* compute ray value */
90     r->newcset = cset;
91     if (strcmp(m->oargs.sarg[0], VOIDID)) {
92     int inside = 0;
93 greg 2.11 const RAY *rp;
94 greg 1.1 /* check for penetration */
95     for (rp = r; rp->parent != NULL; rp = rp->parent)
96 greg 2.14 if (!(rp->rtype & RAYREFL) & (rp->parent->ro != NULL)
97 schorsch 2.7 && inset(modset, rp->parent->ro->omod)) {
98 greg 1.1 if (rp->parent->rod > 0.0)
99     inside++;
100     else
101     inside--;
102 schorsch 2.7 }
103 greg 1.1 if (inside > 0) { /* we just hit the object */
104     flipsurface(r);
105 gwlarson 2.4 return(rayshade(r, lastmod(obj, m->oargs.sarg[0])));
106 greg 1.1 }
107     }
108     raytrans(r); /* else transfer ray */
109 greg 2.2 return(1);
110 greg 1.1 }
