root/radiance/ray/src/rt/m_clip.c
Revision: 2.5
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.4: +58 -5 lines
5 * m_clip.c - routine for clipped (cut) objects.
6 */
7
8 /* ====================================================================
9 * The Radiance Software License, Version 1.0
10 *
11 * Copyright (c) 1990 - 2002 The Regents of the University of California,
12 * through Lawrence Berkeley National Laboratory. All rights reserved.
13 *
14 * Redistribution and use in source and binary forms, with or without
15 * modification, are permitted provided that the following conditions
16 * are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 *
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in
23 * the documentation and/or other materials provided with the
24 * distribution.
25 *
26 * 3. The end-user documentation included with the redistribution,
27 * if any, must include the following acknowledgment:
28 * "This product includes Radiance software
29 * (http://radsite.lbl.gov/)
30 * developed by the Lawrence Berkeley National Laboratory
31 * (http://www.lbl.gov/)."
32 * Alternately, this acknowledgment may appear in the software itself,
33 * if and wherever such third-party acknowledgments normally appear.
34 *
35 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
36 * and "The Regents of the University of California" must
37 * not be used to endorse or promote products derived from this
38 * software without prior written permission. For written
39 * permission, please contact [email protected].
40 *
41 * 5. Products derived from this software may not be called "Radiance",
42 * nor may "Radiance" appear in their name, without prior written
43 * permission of Lawrence Berkeley National Laboratory.
44 *
45 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
46 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
47 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
48 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
49 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
50 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
51 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
52 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
53 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
54 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
55 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
56 * SUCH DAMAGE.
57 * ====================================================================
58 *
59 * This software consists of voluntary contributions made by many
60 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
61 * information on Lawrence Berkeley National Laboratory, please see
62 * <http://www.lbl.gov/>.
63 */
64
65 #include "ray.h"
66
67 /*
68 * Clipping objects permit holes and sections to be taken out
69 * of other objects. The method is simple:
70 *
71 * The argument is the clipped materials;
72 * the first is used to shade upon exit.
73 */
74
75
76 int
77 m_clip(m, r) /* clip objects from ray */
78 register OBJREC *m;
79 register RAY *r;
80 {
81 OBJECT cset[MAXSET+1], *modset;
82 OBJECT obj, mod;
83 int entering;
84 register int i;
85
86 obj = objndx(m);
87 if ((modset = (OBJECT *)m->os) == NULL) {
88 if (m->oargs.nsargs < 1 || m->oargs.nsargs > MAXSET)
89 objerror(m, USER, "bad # arguments");
90 modset = (OBJECT *)malloc((m->oargs.nsargs+1)*sizeof(OBJECT));
91 if (modset == NULL)
92 error(SYSTEM, "out of memory in m_clip");
93 modset[0] = 0;
94 for (i = 0; i < m->oargs.nsargs; i++) {
95 if (!strcmp(m->oargs.sarg[i], VOIDID))
96 continue;
97 if ((mod = lastmod(obj, m->oargs.sarg[i])) == OVOID) {
98 sprintf(errmsg, "unknown modifier \"%s\"",
99 m->oargs.sarg[i]);
100 objerror(m, WARNING, errmsg);
101 continue;
102 }
103 if (inset(modset, mod)) {
104 objerror(m, WARNING, "duplicate modifier");
105 continue;
106 }
107 insertelem(modset, mod);
108 }
109 m->os = (char *)modset;
110 }
111 if (r->clipset != NULL)
112 setcopy(cset, r->clipset);
113 else
114 cset[0] = 0;
115
116 entering = r->rod > 0.0; /* entering clipped region? */
117
118 for (i = modset[0]; i > 0; i--) {
119 if (entering) {
120 if (!inset(cset, modset[i])) {
121 if (cset[0] >= MAXSET)
122 error(INTERNAL, "set overflow in m_clip");
123 insertelem(cset, modset[i]);
124 }
125 } else {
126 if (inset(cset, modset[i]))
127 deletelem(cset, modset[i]);
128 }
129 }
130 /* compute ray value */
131 r->newcset = cset;
132 if (strcmp(m->oargs.sarg[0], VOIDID)) {
133 int inside = 0;
134 register RAY *rp;
135 /* check for penetration */
136 for (rp = r; rp->parent != NULL; rp = rp->parent)
137 if (!(rp->rtype & RAYREFL) && rp->parent->ro != NULL
138 && inset(modset, rp->parent->ro->omod))
139 if (rp->parent->rod > 0.0)
140 inside++;
141 else
142 inside--;
143 if (inside > 0) { /* we just hit the object */
144 flipsurface(r);
145 return(rayshade(r, lastmod(obj, m->oargs.sarg[0])));
146 }
147 }
148 raytrans(r); /* else transfer ray */
149 return(1);
150 }
