Minor change should not affect behavior
Implemented view component for BTDFs
Fixed over-counting error introduced in revision 2.31
Fixed issue with indirect under-estimation in proxied BSDF transmitters
Further tweak to make sure we never double-count
Fixed issue with variable-resolution BSDF sampling of direct component
Fixed comments and changed threshold to 0.7% for "through" shadow testing
Made shadow testing work through BSDF's with through component (Thanks to David G-M)
Renamed direct sampling routine for clarity
Corrected double-counting of diffuse contributions
Simplified handling of diffuse components
Had to reinstate ambRayInPmap() macro to avoid over-counting bug
Removed deprecated ambRayInPmap() macro from code
Added missing call to set function context
Added extra checks where projected solid angle is undefined
Fixed bug for BSDF materials included via octree or mesh instances
Further refinements in error testing/reporting
Improved error reporting for illegal orientation vector
Fixed serious bug in transmitting proxy material ambient sampling
Minor optimizations
Improved oversampling check
Further improved sampling method
Minor improvements to direct specular sampling
Vastly improved direct specular sampling
Minor fix to through component calculation
Stratified specular sampling with -ss > 1
Partial implementation of variable-resolution BSDFs
Fixed interface for determining BSDF solid angles
Improved output efficiency by reducing number of calls to fwrite()
Fixed problem with double-counting through component in indirect
Fixed bug in source sampling for proxies
Made BSDF proxy behavior consistent for shadowing, reflection and transmission
Fixes to BSDF including blurring of angle boundaries
Minor changes and fixes -- first working version of BSDF material
Minor fixes and adjustments
