1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: m_bsdf.c,v 2.34 2017/05/15 22:50:33 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Shading for materials with BSDFs taken from XML data files |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
#include "ambient.h" |
12 |
#include "source.h" |
13 |
#include "func.h" |
14 |
#include "bsdf.h" |
15 |
#include "random.h" |
16 |
#include "pmapmat.h" |
17 |
18 |
19 |
* Arguments to this material include optional diffuse colors. |
20 |
* String arguments include the BSDF and function files. |
21 |
* A non-zero thickness causes the strange but useful behavior |
22 |
* of translating transmitted rays this distance beneath the surface |
23 |
* (opposite the surface normal) to bypass any intervening geometry. |
24 |
* Translation only affects scattered, non-source-directed samples. |
25 |
* A non-zero thickness has the further side-effect that an unscattered |
26 |
* (view) ray will pass right through our material, making the BSDF |
27 |
* surface invisible and showing the proxied geometry instead. Thickness |
28 |
* has the further effect of turning off reflection on the reverse side so |
29 |
* rays heading in the opposite direction pass unimpeded through the BSDF |
30 |
* surface. A paired surface may be placed on the opposide side of |
31 |
* the detail geometry, less than this thickness away, if a two-way |
32 |
* proxy is desired. Note that the sign of the thickness is important. |
33 |
* A positive thickness hides geometry behind the BSDF surface and uses |
34 |
* front reflectance and transmission properties. A negative thickness |
35 |
* hides geometry in front of the surface when rays hit from behind, |
36 |
* and applies only the transmission and backside reflectance properties. |
37 |
* Reflection is ignored on the hidden side, as those rays pass through. |
38 |
* When thickness is set to zero, shadow rays will be blocked unless |
39 |
* a BTDF has a strong "through" component in the source direction. |
40 |
* A separate test prevents over-counting by dropping specular & ambient |
41 |
* samples that are too close to this "through" direction. The same |
42 |
* restriction applies for the proxy case (thickness != 0). |
43 |
* The "up" vector for the BSDF is given by three variables, defined |
44 |
* (along with the thickness) by the named function file, or '.' if none. |
45 |
* Together with the surface normal, this defines the local coordinate |
46 |
* system for the BSDF. |
47 |
* We do not reorient the surface, so if the BSDF has no back-side |
48 |
* reflectance and none is given in the real arguments, a BSDF surface |
49 |
* with zero thickness will appear black when viewed from behind |
50 |
* unless backface visibility is on, when it becomes invisible. |
51 |
* The diffuse arguments are added to components in the BSDF file, |
52 |
* not multiplied. However, patterns affect this material as a multiplier |
53 |
* on everything except non-diffuse reflection. |
54 |
55 |
* Arguments for MAT_BSDF are: |
56 |
* 6+ thick BSDFfile ux uy uz funcfile transform |
57 |
* 0 |
58 |
* 0|3|6|9 rdf gdf bdf |
59 |
* rdb gdb bdb |
60 |
* rdt gdt bdt |
61 |
62 |
63 |
64 |
* Note that our reverse ray-tracing process means that the positions |
65 |
* of incoming and outgoing vectors may be reversed in our calls |
66 |
* to the BSDF library. This is usually fine, since the bidirectional nature |
67 |
* of the BSDF (that's what the 'B' stands for) means it all works out. |
68 |
69 |
70 |
typedef struct { |
71 |
OBJREC *mp; /* material pointer */ |
72 |
RAY *pr; /* intersected ray */ |
73 |
FVECT pnorm; /* perturbed surface normal */ |
74 |
FVECT vray; /* local outgoing (return) vector */ |
75 |
double sr_vpsa[2]; /* sqrt of BSDF projected solid angle extrema */ |
76 |
RREAL toloc[3][3]; /* world to local BSDF coords */ |
77 |
RREAL fromloc[3][3]; /* local BSDF coords to world */ |
78 |
double thick; /* surface thickness */ |
79 |
COLOR cthru; /* "through" component multiplier */ |
80 |
SDData *sd; /* loaded BSDF data */ |
81 |
COLOR rdiff; /* diffuse reflection */ |
82 |
COLOR tdiff; /* diffuse transmission */ |
83 |
} BSDFDAT; /* BSDF material data */ |
84 |
85 |
#define cvt_sdcolor(cv, svp) ccy2rgb(&(svp)->spec, (svp)->cieY, cv) |
86 |
87 |
/* Compute "through" component color */ |
88 |
static void |
89 |
compute_through(BSDFDAT *ndp) |
90 |
91 |
#define NDIR2CHECK 13 |
92 |
static const float dir2check[NDIR2CHECK][2] = { |
93 |
{0, 0}, |
94 |
{-0.8, 0}, |
95 |
{0, 0.8}, |
96 |
{0, -0.8}, |
97 |
{0.8, 0}, |
98 |
{-0.8, 0.8}, |
99 |
{-0.8, -0.8}, |
100 |
{0.8, 0.8}, |
101 |
{0.8, -0.8}, |
102 |
{-1.6, 0}, |
103 |
{0, 1.6}, |
104 |
{0, -1.6}, |
105 |
{1.6, 0}, |
106 |
107 |
const double peak_over = 2.0; |
108 |
SDSpectralDF *dfp; |
109 |
FVECT pdir; |
110 |
double tomega, srchrad; |
111 |
COLOR vpeak, vsum; |
112 |
int nsum, i; |
113 |
SDError ec; |
114 |
115 |
setcolor(ndp->cthru, .0, .0, .0); /* starting assumption */ |
116 |
117 |
if (ndp->pr->rod > 0) |
118 |
dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb; |
119 |
else |
120 |
dfp = (ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf; |
121 |
122 |
if (dfp == NULL) |
123 |
return; /* no specular transmission */ |
124 |
if (bright(ndp->pr->pcol) <= FTINY) |
125 |
return; /* pattern is black, here */ |
126 |
srchrad = sqrt(dfp->minProjSA); /* else search for peak */ |
127 |
setcolor(vpeak, .0, .0, .0); |
128 |
setcolor(vsum, .0, .0, .0); |
129 |
nsum = 0; |
130 |
for (i = 0; i < NDIR2CHECK; i++) { |
131 |
FVECT tdir; |
132 |
SDValue sv; |
133 |
COLOR vcol; |
134 |
tdir[0] = -ndp->vray[0] + dir2check[i][0]*srchrad; |
135 |
tdir[1] = -ndp->vray[1] + dir2check[i][1]*srchrad; |
136 |
tdir[2] = -ndp->vray[2]; |
137 |
if (normalize(tdir) == 0) |
138 |
continue; |
139 |
ec = SDevalBSDF(&sv, tdir, ndp->vray, ndp->sd); |
140 |
if (ec) |
141 |
goto baderror; |
142 |
cvt_sdcolor(vcol, &sv); |
143 |
addcolor(vsum, vcol); |
144 |
++nsum; |
145 |
if (bright(vcol) > bright(vpeak)) { |
146 |
copycolor(vpeak, vcol); |
147 |
VCOPY(pdir, tdir); |
148 |
149 |
150 |
ec = SDsizeBSDF(&tomega, pdir, ndp->vray, SDqueryMin, ndp->sd); |
151 |
if (ec) |
152 |
goto baderror; |
153 |
if (tomega > 1.5*dfp->minProjSA) |
154 |
return; /* not really a peak? */ |
155 |
if ((bright(vpeak) - ndp->sd->tLamb.cieY*(1./PI))*tomega <= .007) |
156 |
return; /* < 0.7% transmission */ |
157 |
for (i = 3; i--; ) /* remove peak from average */ |
158 |
colval(vsum,i) -= colval(vpeak,i); |
159 |
--nsum; |
160 |
if (peak_over*bright(vsum) >= nsum*bright(vpeak)) |
161 |
return; /* not peaky enough */ |
162 |
copycolor(ndp->cthru, vpeak); /* else use it */ |
163 |
scalecolor(ndp->cthru, tomega); |
164 |
multcolor(ndp->cthru, ndp->pr->pcol); /* modify by pattern */ |
165 |
return; |
166 |
baderror: |
167 |
objerror(ndp->mp, USER, transSDError(ec)); |
168 |
#undef NDIR2CHECK |
169 |
170 |
171 |
/* Jitter ray sample according to projected solid angle and specjitter */ |
172 |
static void |
173 |
bsdf_jitter(FVECT vres, BSDFDAT *ndp, double sr_psa) |
174 |
175 |
VCOPY(vres, ndp->vray); |
176 |
if (specjitter < 1.) |
177 |
sr_psa *= specjitter; |
178 |
if (sr_psa <= FTINY) |
179 |
return; |
180 |
vres[0] += sr_psa*(.5 - frandom()); |
181 |
vres[1] += sr_psa*(.5 - frandom()); |
182 |
normalize(vres); |
183 |
184 |
185 |
/* Get BSDF specular for direct component, returning true if OK to proceed */ |
186 |
static int |
187 |
direct_specular_OK(COLOR cval, FVECT ldir, double omega, BSDFDAT *ndp) |
188 |
189 |
int nsamp, ok = 0; |
190 |
FVECT vsrc, vsmp, vjit; |
191 |
double tomega; |
192 |
double sf, tsr, sd[2]; |
193 |
COLOR csmp, cdiff; |
194 |
double diffY; |
195 |
SDValue sv; |
196 |
SDError ec; |
197 |
int i; |
198 |
/* transform source direction */ |
199 |
if (SDmapDir(vsrc, ndp->toloc, ldir) != SDEnone) |
200 |
return(0); |
201 |
/* will discount diffuse portion */ |
202 |
switch ((vsrc[2] > 0)<<1 | (ndp->vray[2] > 0)) { |
203 |
case 3: |
204 |
if (ndp->sd->rf == NULL) |
205 |
return(0); /* all diffuse */ |
206 |
sv = ndp->sd->rLambFront; |
207 |
break; |
208 |
case 0: |
209 |
if (ndp->sd->rb == NULL) |
210 |
211 |
sv = ndp->sd->rLambBack; |
212 |
break; |
213 |
default: |
214 |
if ((ndp->sd->tf == NULL) & (ndp->sd->tb == NULL)) |
215 |
216 |
sv = ndp->sd->tLamb; |
217 |
break; |
218 |
219 |
if (sv.cieY > FTINY) { |
220 |
diffY = sv.cieY *= 1./PI; |
221 |
cvt_sdcolor(cdiff, &sv); |
222 |
} else { |
223 |
diffY = .0; |
224 |
setcolor(cdiff, .0, .0, .0); |
225 |
226 |
/* assign number of samples */ |
227 |
ec = SDsizeBSDF(&tomega, ndp->vray, vsrc, SDqueryMin, ndp->sd); |
228 |
if (ec) |
229 |
goto baderror; |
230 |
/* check indirect over-counting */ |
231 |
if ((ndp->thick != 0 || bright(ndp->cthru) > FTINY) |
232 |
&& ndp->pr->crtype & (SPECULAR|AMBIENT) |
233 |
&& (vsrc[2] > 0) ^ (ndp->vray[2] > 0)) { |
234 |
double dx = vsrc[0] + ndp->vray[0]; |
235 |
double dy = vsrc[1] + ndp->vray[1]; |
236 |
if (dx*dx + dy*dy <= omega+tomega) |
237 |
return(0); |
238 |
239 |
sf = specjitter * ndp->pr->rweight; |
240 |
if (tomega <= .0) |
241 |
nsamp = 1; |
242 |
else if (25.*tomega <= omega) |
243 |
nsamp = 100.*sf + .5; |
244 |
else |
245 |
nsamp = 4.*sf*omega/tomega + .5; |
246 |
nsamp += !nsamp; |
247 |
setcolor(cval, .0, .0, .0); /* sample our source area */ |
248 |
sf = sqrt(omega); |
249 |
tsr = sqrt(tomega); |
250 |
for (i = nsamp; i--; ) { |
251 |
VCOPY(vsmp, vsrc); /* jitter query directions */ |
252 |
if (nsamp > 1) { |
253 |
multisamp(sd, 2, (i + frandom())/(double)nsamp); |
254 |
vsmp[0] += (sd[0] - .5)*sf; |
255 |
vsmp[1] += (sd[1] - .5)*sf; |
256 |
if (normalize(vsmp) == 0) { |
257 |
--nsamp; |
258 |
continue; |
259 |
260 |
261 |
bsdf_jitter(vjit, ndp, tsr); |
262 |
/* compute BSDF */ |
263 |
ec = SDevalBSDF(&sv, vjit, vsmp, ndp->sd); |
264 |
if (ec) |
265 |
goto baderror; |
266 |
if (sv.cieY - diffY <= FTINY) { |
267 |
addcolor(cval, cdiff); |
268 |
continue; /* no specular part */ |
269 |
270 |
cvt_sdcolor(csmp, &sv); |
271 |
addcolor(cval, csmp); /* else average it in */ |
272 |
++ok; |
273 |
274 |
if (!ok) { |
275 |
setcolor(cval, .0, .0, .0); |
276 |
return(0); /* no valid specular samples */ |
277 |
278 |
sf = 1./(double)nsamp; |
279 |
scalecolor(cval, sf); |
280 |
/* subtract diffuse contribution */ |
281 |
for (i = 3*(diffY > FTINY); i--; ) |
282 |
if ((colval(cval,i) -= colval(cdiff,i)) < .0) |
283 |
colval(cval,i) = .0; |
284 |
return(1); |
285 |
baderror: |
286 |
287 |
return(0); /* gratis return */ |
288 |
289 |
290 |
/* Compute source contribution for BSDF (reflected & transmitted) */ |
291 |
static void |
292 |
dir_bsdf( |
293 |
COLOR cval, /* returned coefficient */ |
294 |
void *nnp, /* material data */ |
295 |
FVECT ldir, /* light source direction */ |
296 |
double omega /* light source size */ |
297 |
298 |
299 |
BSDFDAT *np = (BSDFDAT *)nnp; |
300 |
double ldot; |
301 |
double dtmp; |
302 |
COLOR ctmp; |
303 |
304 |
305 |
306 |
ldot = DOT(np->pnorm, ldir); |
307 |
if ((-FTINY <= ldot) & (ldot <= FTINY)) |
308 |
return; |
309 |
310 |
if (ldot > 0 && bright(np->rdiff) > FTINY) { |
311 |
312 |
* Compute added diffuse reflected component. |
313 |
314 |
copycolor(ctmp, np->rdiff); |
315 |
dtmp = ldot * omega * (1./PI); |
316 |
scalecolor(ctmp, dtmp); |
317 |
addcolor(cval, ctmp); |
318 |
319 |
if (ldot < 0 && bright(np->tdiff) > FTINY) { |
320 |
321 |
* Compute added diffuse transmission. |
322 |
323 |
copycolor(ctmp, np->tdiff); |
324 |
dtmp = -ldot * omega * (1.0/PI); |
325 |
326 |
327 |
328 |
if (ambRayInPmap(np->pr)) |
329 |
return; /* specular already in photon map */ |
330 |
331 |
* Compute specular scattering coefficient using BSDF. |
332 |
333 |
if (!direct_specular_OK(ctmp, ldir, omega, np)) |
334 |
return; |
335 |
if (ldot < 0) { /* pattern for specular transmission */ |
336 |
multcolor(ctmp, np->pr->pcol); |
337 |
dtmp = -ldot * omega; |
338 |
} else |
339 |
dtmp = ldot * omega; |
340 |
341 |
342 |
343 |
344 |
/* Compute source contribution for BSDF (reflected only) */ |
345 |
static void |
346 |
dir_brdf( |
347 |
348 |
349 |
350 |
351 |
352 |
353 |
354 |
double ldot; |
355 |
double dtmp; |
356 |
COLOR ctmp, ctmp1, ctmp2; |
357 |
358 |
359 |
360 |
361 |
362 |
if (ldot <= FTINY) |
363 |
return; |
364 |
365 |
if (bright(np->rdiff) > FTINY) { |
366 |
367 |
368 |
369 |
370 |
371 |
372 |
373 |
374 |
375 |
376 |
377 |
* Compute specular reflection coefficient using BSDF. |
378 |
379 |
380 |
return; |
381 |
382 |
383 |
384 |
385 |
386 |
/* Compute source contribution for BSDF (transmitted only) */ |
387 |
static void |
388 |
dir_btdf( |
389 |
390 |
391 |
392 |
393 |
394 |
395 |
396 |
double ldot; |
397 |
double dtmp; |
398 |
COLOR ctmp; |
399 |
400 |
401 |
402 |
403 |
404 |
if (ldot >= -FTINY) |
405 |
return; |
406 |
407 |
if (bright(np->tdiff) > FTINY) { |
408 |
409 |
410 |
411 |
412 |
413 |
414 |
415 |
416 |
417 |
418 |
419 |
420 |
421 |
422 |
return; |
423 |
/* full pattern on transmission */ |
424 |
425 |
426 |
427 |
428 |
429 |
430 |
/* Sample separate BSDF component */ |
431 |
static int |
432 |
sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usepat) |
433 |
434 |
int nstarget = 1; |
435 |
int nsent; |
436 |
SDError ec; |
437 |
SDValue bsv; |
438 |
double xrand; |
439 |
FVECT vsmp; |
440 |
RAY sr; |
441 |
/* multiple samples? */ |
442 |
if (specjitter > 1.5) { |
443 |
nstarget = specjitter*ndp->pr->rweight + .5; |
444 |
nstarget += !nstarget; |
445 |
446 |
/* run through our samples */ |
447 |
for (nsent = 0; nsent < nstarget; nsent++) { |
448 |
if (nstarget == 1) { /* stratify random variable */ |
449 |
xrand = urand(ilhash(dimlist,ndims)+samplendx); |
450 |
451 |
xrand = .5 + specjitter*(xrand-.5); |
452 |
} else { |
453 |
xrand = (nsent + frandom())/(double)nstarget; |
454 |
455 |
SDerrorDetail[0] = '\0'; /* sample direction & coef. */ |
456 |
bsdf_jitter(vsmp, ndp, ndp->sr_vpsa[0]); |
457 |
ec = SDsampComponent(&bsv, vsmp, xrand, dcp); |
458 |
if (ec) |
459 |
460 |
if (bsv.cieY <= FTINY) /* zero component? */ |
461 |
break; |
462 |
/* map vector to world */ |
463 |
if (SDmapDir(sr.rdir, ndp->fromloc, vsmp) != SDEnone) |
464 |
break; |
465 |
/* spawn a specular ray */ |
466 |
if (nstarget > 1) |
467 |
bsv.cieY /= (double)nstarget; |
468 |
cvt_sdcolor(sr.rcoef, &bsv); /* use sample color */ |
469 |
if (usepat) /* apply pattern? */ |
470 |
multcolor(sr.rcoef, ndp->pr->pcol); |
471 |
if (rayorigin(&sr, SPECULAR, ndp->pr, sr.rcoef) < 0) { |
472 |
if (maxdepth > 0) |
473 |
break; |
474 |
continue; /* Russian roulette victim */ |
475 |
476 |
/* need to offset origin? */ |
477 |
if (ndp->thick != 0 && (ndp->pr->rod > 0) ^ (vsmp[2] > 0)) |
478 |
VSUM(sr.rorg, sr.rorg, ndp->pr->ron, -ndp->thick); |
479 |
rayvalue(&sr); /* send & evaluate sample */ |
480 |
multcolor(sr.rcol, sr.rcoef); |
481 |
addcolor(ndp->pr->rcol, sr.rcol); |
482 |
483 |
return(nsent); |
484 |
485 |
486 |
/* Sample non-diffuse components of BSDF */ |
487 |
static int |
488 |
sample_sdf(BSDFDAT *ndp, int sflags) |
489 |
490 |
int n, ntotal = 0; |
491 |
492 |
COLORV *unsc; |
493 |
494 |
if (sflags == SDsampSpT) { |
495 |
unsc = ndp->tdiff; |
496 |
497 |
498 |
else |
499 |
500 |
} else /* sflags == SDsampSpR */ { |
501 |
unsc = ndp->rdiff; |
502 |
503 |
dfp = ndp->sd->rf; |
504 |
else |
505 |
dfp = ndp->sd->rb; |
506 |
507 |
if (dfp == NULL) /* no specular component? */ |
508 |
return(0); |
509 |
/* below sampling threshold? */ |
510 |
if (dfp->maxHemi <= specthresh+FTINY) { |
511 |
if (dfp->maxHemi > FTINY) { /* XXX no color from BSDF */ |
512 |
FVECT vjit; |
513 |
double d; |
514 |
COLOR ctmp; |
515 |
bsdf_jitter(vjit, ndp, ndp->sr_vpsa[1]); |
516 |
d = SDdirectHemi(vjit, sflags, ndp->sd); |
517 |
518 |
copycolor(ctmp, ndp->pr->pcol); |
519 |
scalecolor(ctmp, d); |
520 |
} else /* no pattern on reflection */ |
521 |
setcolor(ctmp, d, d, d); |
522 |
addcolor(unsc, ctmp); |
523 |
524 |
return(0); |
525 |
526 |
/* else need to sample */ |
527 |
dimlist[ndims++] = (int)(size_t)ndp->mp; |
528 |
ndims++; |
529 |
for (n = dfp->ncomp; n--; ) { /* loop over components */ |
530 |
dimlist[ndims-1] = n + 9438; |
531 |
ntotal += sample_sdcomp(ndp, &dfp->comp[n], sflags==SDsampSpT); |
532 |
533 |
ndims -= 2; |
534 |
return(ntotal); |
535 |
536 |
537 |
/* Color a ray that hit a BSDF material */ |
538 |
int |
539 |
m_bsdf(OBJREC *m, RAY *r) |
540 |
541 |
int hitfront; |
542 |
COLOR ctmp; |
543 |
SDError ec; |
544 |
FVECT upvec, vtmp; |
545 |
MFUNC *mf; |
546 |
BSDFDAT nd; |
547 |
/* check arguments */ |
548 |
if ((m->oargs.nsargs < 6) | (m->oargs.nfargs > 9) | |
549 |
(m->oargs.nfargs % 3)) |
550 |
objerror(m, USER, "bad # arguments"); |
551 |
/* record surface struck */ |
552 |
hitfront = (r->rod > 0); |
553 |
/* load cal file */ |
554 |
mf = getfunc(m, 5, 0x1d, 1); |
555 |
setfunc(m, r); |
556 |
/* get thickness */ |
557 |
nd.thick = evalue(mf->ep[0]); |
558 |
if ((-FTINY <= nd.thick) & (nd.thick <= FTINY)) |
559 |
nd.thick = .0; |
560 |
/* check backface visibility */ |
561 |
if (!hitfront & !backvis) { |
562 |
raytrans(r); |
563 |
return(1); |
564 |
565 |
/* check other rays to pass */ |
566 |
if (nd.thick != 0 && (r->crtype & SHADOW || |
567 |
!(r->crtype & (SPECULAR|AMBIENT)) || |
568 |
(nd.thick > 0) ^ hitfront)) { |
569 |
raytrans(r); /* hide our proxy */ |
570 |
return(1); |
571 |
572 |
nd.mp = m; |
573 |
nd.pr = r; |
574 |
/* get BSDF data */ |
575 |
nd.sd = loadBSDF(m->oargs.sarg[1]); |
576 |
/* early shadow check */ |
577 |
if (r->crtype & SHADOW && (nd.sd->tf == NULL) & (nd.sd->tb == NULL)) |
578 |
return(1); |
579 |
/* diffuse reflectance */ |
580 |
if (hitfront) { |
581 |
cvt_sdcolor(nd.rdiff, &nd.sd->rLambFront); |
582 |
if (m->oargs.nfargs >= 3) { |
583 |
setcolor(ctmp, m->oargs.farg[0], |
584 |
m->oargs.farg[1], |
585 |
m->oargs.farg[2]); |
586 |
addcolor(nd.rdiff, ctmp); |
587 |
588 |
} else { |
589 |
cvt_sdcolor(nd.rdiff, &nd.sd->rLambBack); |
590 |
if (m->oargs.nfargs >= 6) { |
591 |
setcolor(ctmp, m->oargs.farg[3], |
592 |
m->oargs.farg[4], |
593 |
m->oargs.farg[5]); |
594 |
595 |
596 |
597 |
/* diffuse transmittance */ |
598 |
cvt_sdcolor(nd.tdiff, &nd.sd->tLamb); |
599 |
if (m->oargs.nfargs >= 9) { |
600 |
setcolor(ctmp, m->oargs.farg[6], |
601 |
m->oargs.farg[7], |
602 |
m->oargs.farg[8]); |
603 |
addcolor(nd.tdiff, ctmp); |
604 |
605 |
/* get modifiers */ |
606 |
raytexture(r, m->omod); |
607 |
/* modify diffuse values */ |
608 |
multcolor(nd.rdiff, r->pcol); |
609 |
multcolor(nd.tdiff, r->pcol); |
610 |
/* get up vector */ |
611 |
upvec[0] = evalue(mf->ep[1]); |
612 |
upvec[1] = evalue(mf->ep[2]); |
613 |
upvec[2] = evalue(mf->ep[3]); |
614 |
/* return to world coords */ |
615 |
if (mf->fxp != &unitxf) { |
616 |
multv3(upvec, upvec, mf->fxp->xfm); |
617 |
nd.thick *= mf->fxp->sca; |
618 |
619 |
if (r->rox != NULL) { |
620 |
multv3(upvec, upvec, r->rox->f.xfm); |
621 |
nd.thick *= r->rox->f.sca; |
622 |
623 |
raynormal(nd.pnorm, r); |
624 |
/* compute local BSDF xform */ |
625 |
ec = SDcompXform(nd.toloc, nd.pnorm, upvec); |
626 |
if (!ec) { |
627 |
nd.vray[0] = -r->rdir[0]; |
628 |
nd.vray[1] = -r->rdir[1]; |
629 |
nd.vray[2] = -r->rdir[2]; |
630 |
ec = SDmapDir(nd.vray, nd.toloc, nd.vray); |
631 |
632 |
if (ec) { |
633 |
objerror(m, WARNING, "Illegal orientation vector"); |
634 |
return(1); |
635 |
636 |
compute_through(&nd); /* compute through component */ |
637 |
if (r->crtype & SHADOW) { |
638 |
RAY tr; /* attempt to pass shadow ray */ |
639 |
if (rayorigin(&tr, TRANS, r, nd.cthru) < 0) |
640 |
return(1); /* blocked */ |
641 |
VCOPY(tr.rdir, r->rdir); |
642 |
rayvalue(&tr); /* transmit with scaling */ |
643 |
multcolor(tr.rcol, tr.rcoef); |
644 |
copycolor(r->rcol, tr.rcol); |
645 |
return(1); /* we're done */ |
646 |
647 |
ec = SDinvXform(nd.fromloc, nd.toloc); |
648 |
if (!ec) /* determine BSDF resolution */ |
649 |
ec = SDsizeBSDF(nd.sr_vpsa, nd.vray, NULL, |
650 |
SDqueryMin+SDqueryMax, nd.sd); |
651 |
if (ec) |
652 |
objerror(m, USER, transSDError(ec)); |
653 |
654 |
nd.sr_vpsa[0] = sqrt(nd.sr_vpsa[0]); |
655 |
nd.sr_vpsa[1] = sqrt(nd.sr_vpsa[1]); |
656 |
if (!hitfront) { /* perturb normal towards hit */ |
657 |
nd.pnorm[0] = -nd.pnorm[0]; |
658 |
nd.pnorm[1] = -nd.pnorm[1]; |
659 |
nd.pnorm[2] = -nd.pnorm[2]; |
660 |
661 |
/* sample reflection */ |
662 |
sample_sdf(&nd, SDsampSpR); |
663 |
/* sample transmission */ |
664 |
sample_sdf(&nd, SDsampSpT); |
665 |
/* compute indirect diffuse */ |
666 |
if (bright(nd.rdiff) > FTINY) { /* ambient from reflection */ |
667 |
if (!hitfront) |
668 |
flipsurface(r); |
669 |
copycolor(ctmp, nd.rdiff); |
670 |
multambient(ctmp, r, nd.pnorm); |
671 |
addcolor(r->rcol, ctmp); |
672 |
if (!hitfront) |
673 |
flipsurface(r); |
674 |
675 |
if (bright(nd.tdiff) > FTINY) { /* ambient from other side */ |
676 |
FVECT bnorm; |
677 |
if (hitfront) |
678 |
flipsurface(r); |
679 |
bnorm[0] = -nd.pnorm[0]; |
680 |
bnorm[1] = -nd.pnorm[1]; |
681 |
bnorm[2] = -nd.pnorm[2]; |
682 |
copycolor(ctmp, nd.tdiff); |
683 |
if (nd.thick != 0) { /* proxy with offset? */ |
684 |
VCOPY(vtmp, r->rop); |
685 |
VSUM(r->rop, vtmp, r->ron, nd.thick); |
686 |
multambient(ctmp, r, bnorm); |
687 |
VCOPY(r->rop, vtmp); |
688 |
} else |
689 |
690 |
691 |
if (hitfront) |
692 |
flipsurface(r); |
693 |
694 |
/* add direct component */ |
695 |
if ((bright(nd.tdiff) <= FTINY) & (nd.sd->tf == NULL) & |
696 |
(nd.sd->tb == NULL)) { |
697 |
direct(r, dir_brdf, &nd); /* reflection only */ |
698 |
} else if (nd.thick == 0) { |
699 |
direct(r, dir_bsdf, &nd); /* thin surface scattering */ |
700 |
} else { |
701 |
direct(r, dir_brdf, &nd); /* reflection first */ |
702 |
VCOPY(vtmp, r->rop); /* offset for transmitted */ |
703 |
VSUM(r->rop, vtmp, r->ron, -nd.thick); |
704 |
direct(r, dir_btdf, &nd); /* separate transmission */ |
705 |
706 |
707 |
/* clean up */ |
708 |
SDfreeCache(nd.sd); |
709 |
return(1); |
710 |
