1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: m_bsdf.c,v 2.22 2012/09/02 15:33:15 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Shading for materials with BSDFs taken from XML data files |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
#include "ambient.h" |
12 |
#include "source.h" |
13 |
#include "func.h" |
14 |
#include "bsdf.h" |
15 |
#include "random.h" |
16 |
17 |
18 |
* Arguments to this material include optional diffuse colors. |
19 |
* String arguments include the BSDF and function files. |
20 |
* A non-zero thickness causes the strange but useful behavior |
21 |
* of translating transmitted rays this distance beneath the surface |
22 |
* (opposite the surface normal) to bypass any intervening geometry. |
23 |
* Translation only affects scattered, non-source-directed samples. |
24 |
* A non-zero thickness has the further side-effect that an unscattered |
25 |
* (view) ray will pass right through our material if it has any |
26 |
* non-diffuse transmission, making the BSDF surface invisible. This |
27 |
* shows the proxied geometry instead. Thickness has the further |
28 |
* effect of turning off reflection on the hidden side so that rays |
29 |
* heading in the opposite direction pass unimpeded through the BSDF |
30 |
* surface. A paired surface may be placed on the opposide side of |
31 |
* the detail geometry, less than this thickness away, if a two-way |
32 |
* proxy is desired. Note that the sign of the thickness is important. |
33 |
* A positive thickness hides geometry behind the BSDF surface and uses |
34 |
* front reflectance and transmission properties. A negative thickness |
35 |
* hides geometry in front of the surface when rays hit from behind, |
36 |
* and applies only the transmission and backside reflectance properties. |
37 |
* Reflection is ignored on the hidden side, as those rays pass through. |
38 |
* The "up" vector for the BSDF is given by three variables, defined |
39 |
* (along with the thickness) by the named function file, or '.' if none. |
40 |
* Together with the surface normal, this defines the local coordinate |
41 |
* system for the BSDF. |
42 |
* We do not reorient the surface, so if the BSDF has no back-side |
43 |
* reflectance and none is given in the real arguments, a BSDF surface |
44 |
* with zero thickness will appear black when viewed from behind |
45 |
* unless backface visibility is off. |
46 |
* The diffuse arguments are added to components in the BSDF file, |
47 |
* not multiplied. However, patterns affect this material as a multiplier |
48 |
* on everything except non-diffuse reflection. |
49 |
50 |
* Arguments for MAT_BSDF are: |
51 |
* 6+ thick BSDFfile ux uy uz funcfile transform |
52 |
* 0 |
53 |
* 0|3|6|9 rdf gdf bdf |
54 |
* rdb gdb bdb |
55 |
* rdt gdt bdt |
56 |
57 |
58 |
59 |
* Note that our reverse ray-tracing process means that the positions |
60 |
* of incoming and outgoing vectors may be reversed in our calls |
61 |
* to the BSDF library. This is fine, since the bidirectional nature |
62 |
* of the BSDF (that's what the 'B' stands for) means it all works out. |
63 |
64 |
65 |
typedef struct { |
66 |
OBJREC *mp; /* material pointer */ |
67 |
RAY *pr; /* intersected ray */ |
68 |
FVECT pnorm; /* perturbed surface normal */ |
69 |
FVECT vray; /* local outgoing (return) vector */ |
70 |
double sr_vpsa[2]; /* sqrt of BSDF projected solid angle extrema */ |
71 |
RREAL toloc[3][3]; /* world to local BSDF coords */ |
72 |
RREAL fromloc[3][3]; /* local BSDF coords to world */ |
73 |
double thick; /* surface thickness */ |
74 |
SDData *sd; /* loaded BSDF data */ |
75 |
COLOR runsamp; /* BSDF hemispherical reflection */ |
76 |
COLOR rdiff; /* added diffuse reflection */ |
77 |
COLOR tunsamp; /* BSDF hemispherical transmission */ |
78 |
COLOR tdiff; /* added diffuse transmission */ |
79 |
} BSDFDAT; /* BSDF material data */ |
80 |
81 |
#define cvt_sdcolor(cv, svp) ccy2rgb(&(svp)->spec, (svp)->cieY, cv) |
82 |
83 |
/* Jitter ray sample according to projected solid angle and specjitter */ |
84 |
static void |
85 |
bsdf_jitter(FVECT vres, BSDFDAT *ndp, double sr_psa) |
86 |
87 |
VCOPY(vres, ndp->vray); |
88 |
if (specjitter < 1.) |
89 |
sr_psa *= specjitter; |
90 |
if (sr_psa <= FTINY) |
91 |
return; |
92 |
vres[0] += sr_psa*(.5 - frandom()); |
93 |
vres[1] += sr_psa*(.5 - frandom()); |
94 |
normalize(vres); |
95 |
96 |
97 |
/* Evaluate BSDF for direct component, returning true if OK to proceed */ |
98 |
static int |
99 |
direct_bsdf_OK(COLOR cval, FVECT ldir, double omega, BSDFDAT *ndp) |
100 |
101 |
int nsamp, ok = 0; |
102 |
FVECT vsrc, vsmp, vjit; |
103 |
double tomega; |
104 |
double sf, tsr, sd[2]; |
105 |
COLOR csmp; |
106 |
SDValue sv; |
107 |
SDError ec; |
108 |
int i; |
109 |
/* transform source direction */ |
110 |
if (SDmapDir(vsrc, ndp->toloc, ldir) != SDEnone) |
111 |
return(0); |
112 |
/* assign number of samples */ |
113 |
ec = SDsizeBSDF(&tomega, ndp->vray, vsrc, SDqueryMin, ndp->sd); |
114 |
if (ec) |
115 |
goto baderror; |
116 |
/* check indirect over-counting */ |
117 |
if (ndp->thick != 0 && ndp->pr->crtype & (SPECULAR|AMBIENT) |
118 |
&& vsrc[2] > 0 ^ ndp->vray[2] > 0) { |
119 |
double dx = vsrc[0] + ndp->vray[0]; |
120 |
double dy = vsrc[1] + ndp->vray[1]; |
121 |
if (dx*dx + dy*dy <= omega+tomega) |
122 |
return(0); |
123 |
124 |
sf = specjitter * ndp->pr->rweight; |
125 |
if (25.*tomega <= omega) |
126 |
nsamp = 100.*sf + .5; |
127 |
else |
128 |
nsamp = 4.*sf*omega/tomega + .5; |
129 |
nsamp += !nsamp; |
130 |
setcolor(cval, .0, .0, .0); /* sample our source area */ |
131 |
sf = sqrt(omega); |
132 |
tsr = sqrt(tomega); |
133 |
for (i = nsamp; i--; ) { |
134 |
VCOPY(vsmp, vsrc); /* jitter query directions */ |
135 |
if (nsamp > 1) { |
136 |
multisamp(sd, 2, (i + frandom())/(double)nsamp); |
137 |
vsmp[0] += (sd[0] - .5)*sf; |
138 |
vsmp[1] += (sd[1] - .5)*sf; |
139 |
if (normalize(vsmp) == 0) { |
140 |
--nsamp; |
141 |
continue; |
142 |
143 |
144 |
bsdf_jitter(vjit, ndp, tsr); |
145 |
/* compute BSDF */ |
146 |
ec = SDevalBSDF(&sv, vjit, vsmp, ndp->sd); |
147 |
if (ec) |
148 |
goto baderror; |
149 |
if (sv.cieY <= FTINY) /* worth using? */ |
150 |
continue; |
151 |
cvt_sdcolor(csmp, &sv); |
152 |
addcolor(cval, csmp); /* average it in */ |
153 |
++ok; |
154 |
155 |
sf = 1./(double)nsamp; |
156 |
scalecolor(cval, sf); |
157 |
return(ok); |
158 |
baderror: |
159 |
objerror(ndp->mp, USER, transSDError(ec)); |
160 |
return(0); /* gratis return */ |
161 |
162 |
163 |
/* Compute source contribution for BSDF (reflected & transmitted) */ |
164 |
static void |
165 |
dir_bsdf( |
166 |
COLOR cval, /* returned coefficient */ |
167 |
void *nnp, /* material data */ |
168 |
FVECT ldir, /* light source direction */ |
169 |
double omega /* light source size */ |
170 |
171 |
172 |
BSDFDAT *np = (BSDFDAT *)nnp; |
173 |
double ldot; |
174 |
double dtmp; |
175 |
COLOR ctmp; |
176 |
177 |
setcolor(cval, .0, .0, .0); |
178 |
179 |
ldot = DOT(np->pnorm, ldir); |
180 |
if ((-FTINY <= ldot) & (ldot <= FTINY)) |
181 |
return; |
182 |
183 |
if (ldot > 0 && bright(np->rdiff) > FTINY) { |
184 |
185 |
* Compute added diffuse reflected component. |
186 |
187 |
copycolor(ctmp, np->rdiff); |
188 |
dtmp = ldot * omega * (1./PI); |
189 |
scalecolor(ctmp, dtmp); |
190 |
addcolor(cval, ctmp); |
191 |
192 |
if (ldot < 0 && bright(np->tdiff) > FTINY) { |
193 |
194 |
* Compute added diffuse transmission. |
195 |
196 |
copycolor(ctmp, np->tdiff); |
197 |
dtmp = -ldot * omega * (1.0/PI); |
198 |
199 |
200 |
201 |
202 |
* Compute scattering coefficient using BSDF. |
203 |
204 |
if (!direct_bsdf_OK(ctmp, ldir, omega, np)) |
205 |
return; |
206 |
if (ldot > 0) { /* pattern only diffuse reflection */ |
207 |
COLOR ctmp1, ctmp2; |
208 |
dtmp = (np->pr->rod > 0) ? np->sd->rLambFront.cieY |
209 |
: np->sd->rLambBack.cieY; |
210 |
/* diffuse fraction */ |
211 |
dtmp /= PI * bright(ctmp); |
212 |
copycolor(ctmp2, np->pr->pcol); |
213 |
scalecolor(ctmp2, dtmp); |
214 |
setcolor(ctmp1, 1.-dtmp, 1.-dtmp, 1.-dtmp); |
215 |
addcolor(ctmp1, ctmp2); |
216 |
multcolor(ctmp, ctmp1); /* apply derated pattern */ |
217 |
dtmp = ldot * omega; |
218 |
} else { /* full pattern on transmission */ |
219 |
multcolor(ctmp, np->pr->pcol); |
220 |
dtmp = -ldot * omega; |
221 |
222 |
223 |
224 |
225 |
226 |
/* Compute source contribution for BSDF (reflected only) */ |
227 |
static void |
228 |
dir_brdf( |
229 |
230 |
231 |
232 |
233 |
234 |
235 |
236 |
double ldot; |
237 |
double dtmp; |
238 |
COLOR ctmp, ctmp1, ctmp2; |
239 |
240 |
241 |
242 |
243 |
244 |
if (ldot <= FTINY) |
245 |
return; |
246 |
247 |
if (bright(np->rdiff) > FTINY) { |
248 |
249 |
250 |
251 |
252 |
253 |
254 |
255 |
256 |
257 |
* Compute reflection coefficient using BSDF. |
258 |
259 |
260 |
return; |
261 |
262 |
263 |
264 |
dtmp /= PI * bright(ctmp); /* diffuse fraction */ |
265 |
266 |
267 |
268 |
269 |
270 |
271 |
272 |
273 |
274 |
275 |
/* Compute source contribution for BSDF (transmitted only) */ |
276 |
static void |
277 |
dir_btdf( |
278 |
279 |
280 |
281 |
282 |
283 |
284 |
285 |
double ldot; |
286 |
double dtmp; |
287 |
COLOR ctmp; |
288 |
289 |
290 |
291 |
292 |
293 |
if (ldot >= -FTINY) |
294 |
return; |
295 |
296 |
if (bright(np->tdiff) > FTINY) { |
297 |
298 |
299 |
300 |
301 |
302 |
303 |
304 |
305 |
306 |
307 |
308 |
309 |
return; |
310 |
311 |
312 |
313 |
314 |
315 |
316 |
317 |
/* Sample separate BSDF component */ |
318 |
static int |
319 |
sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usepat) |
320 |
321 |
int nstarget = 1; |
322 |
int nsent; |
323 |
SDError ec; |
324 |
SDValue bsv; |
325 |
double xrand; |
326 |
FVECT vsmp; |
327 |
RAY sr; |
328 |
/* multiple samples? */ |
329 |
if (specjitter > 1.5) { |
330 |
nstarget = specjitter*ndp->pr->rweight + .5; |
331 |
nstarget += !nstarget; |
332 |
333 |
/* run through our samples */ |
334 |
for (nsent = 0; nsent < nstarget; nsent++) { |
335 |
if (nstarget == 1) { /* stratify random variable */ |
336 |
xrand = urand(ilhash(dimlist,ndims)+samplendx); |
337 |
338 |
xrand = .5 + specjitter*(xrand-.5); |
339 |
} else { |
340 |
xrand = (nsent + frandom())/(double)nstarget; |
341 |
342 |
SDerrorDetail[0] = '\0'; /* sample direction & coef. */ |
343 |
bsdf_jitter(vsmp, ndp, ndp->sr_vpsa[0]); |
344 |
ec = SDsampComponent(&bsv, vsmp, xrand, dcp); |
345 |
if (ec) |
346 |
347 |
if (bsv.cieY <= FTINY) /* zero component? */ |
348 |
break; |
349 |
/* map vector to world */ |
350 |
if (SDmapDir(sr.rdir, ndp->fromloc, vsmp) != SDEnone) |
351 |
break; |
352 |
/* spawn a specular ray */ |
353 |
if (nstarget > 1) |
354 |
bsv.cieY /= (double)nstarget; |
355 |
cvt_sdcolor(sr.rcoef, &bsv); /* use sample color */ |
356 |
if (usepat) /* apply pattern? */ |
357 |
multcolor(sr.rcoef, ndp->pr->pcol); |
358 |
if (rayorigin(&sr, SPECULAR, ndp->pr, sr.rcoef) < 0) { |
359 |
if (maxdepth > 0) |
360 |
break; |
361 |
continue; /* Russian roulette victim */ |
362 |
363 |
/* need to offset origin? */ |
364 |
if (ndp->thick != 0 && ndp->pr->rod > 0 ^ vsmp[2] > 0) |
365 |
VSUM(sr.rorg, sr.rorg, ndp->pr->ron, -ndp->thick); |
366 |
rayvalue(&sr); /* send & evaluate sample */ |
367 |
multcolor(sr.rcol, sr.rcoef); |
368 |
addcolor(ndp->pr->rcol, sr.rcol); |
369 |
370 |
return(nsent); |
371 |
372 |
373 |
/* Sample non-diffuse components of BSDF */ |
374 |
static int |
375 |
sample_sdf(BSDFDAT *ndp, int sflags) |
376 |
377 |
int n, ntotal = 0; |
378 |
SDSpectralDF *dfp; |
379 |
COLORV *unsc; |
380 |
381 |
if (sflags == SDsampSpT) { |
382 |
unsc = ndp->tunsamp; |
383 |
if (ndp->pr->rod > 0) |
384 |
dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb; |
385 |
else |
386 |
dfp = (ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf; |
387 |
cvt_sdcolor(unsc, &ndp->sd->tLamb); |
388 |
} else /* sflags == SDsampSpR */ { |
389 |
unsc = ndp->runsamp; |
390 |
if (ndp->pr->rod > 0) { |
391 |
dfp = ndp->sd->rf; |
392 |
cvt_sdcolor(unsc, &ndp->sd->rLambFront); |
393 |
} else { |
394 |
dfp = ndp->sd->rb; |
395 |
cvt_sdcolor(unsc, &ndp->sd->rLambBack); |
396 |
397 |
398 |
multcolor(unsc, ndp->pr->pcol); |
399 |
if (dfp == NULL) /* no specular component? */ |
400 |
return(0); |
401 |
/* below sampling threshold? */ |
402 |
if (dfp->maxHemi <= specthresh+FTINY) { |
403 |
if (dfp->maxHemi > FTINY) { /* XXX no color from BSDF */ |
404 |
FVECT vjit; |
405 |
double d; |
406 |
COLOR ctmp; |
407 |
bsdf_jitter(vjit, ndp, ndp->sr_vpsa[1]); |
408 |
d = SDdirectHemi(vjit, sflags, ndp->sd); |
409 |
410 |
copycolor(ctmp, ndp->pr->pcol); |
411 |
scalecolor(ctmp, d); |
412 |
} else /* no pattern on reflection */ |
413 |
setcolor(ctmp, d, d, d); |
414 |
addcolor(unsc, ctmp); |
415 |
416 |
return(0); |
417 |
418 |
/* else need to sample */ |
419 |
dimlist[ndims++] = (int)(size_t)ndp->mp; |
420 |
ndims++; |
421 |
for (n = dfp->ncomp; n--; ) { /* loop over components */ |
422 |
dimlist[ndims-1] = n + 9438; |
423 |
ntotal += sample_sdcomp(ndp, &dfp->comp[n], sflags==SDsampSpT); |
424 |
425 |
ndims -= 2; |
426 |
return(ntotal); |
427 |
428 |
429 |
/* Color a ray that hit a BSDF material */ |
430 |
int |
431 |
m_bsdf(OBJREC *m, RAY *r) |
432 |
433 |
int hitfront; |
434 |
COLOR ctmp; |
435 |
SDError ec; |
436 |
FVECT upvec, vtmp; |
437 |
MFUNC *mf; |
438 |
BSDFDAT nd; |
439 |
/* check arguments */ |
440 |
if ((m->oargs.nsargs < 6) | (m->oargs.nfargs > 9) | |
441 |
(m->oargs.nfargs % 3)) |
442 |
objerror(m, USER, "bad # arguments"); |
443 |
/* record surface struck */ |
444 |
hitfront = (r->rod > 0); |
445 |
/* load cal file */ |
446 |
mf = getfunc(m, 5, 0x1d, 1); |
447 |
/* get thickness */ |
448 |
nd.thick = evalue(mf->ep[0]); |
449 |
if ((-FTINY <= nd.thick) & (nd.thick <= FTINY)) |
450 |
nd.thick = .0; |
451 |
/* check shadow */ |
452 |
if (r->crtype & SHADOW) { |
453 |
if (nd.thick != 0) |
454 |
raytrans(r); /* pass-through */ |
455 |
return(1); /* or shadow */ |
456 |
457 |
/* check other rays to pass */ |
458 |
if (nd.thick != 0 && (!(r->crtype & (SPECULAR|AMBIENT)) || |
459 |
nd.thick > 0 ^ hitfront)) { |
460 |
raytrans(r); /* hide our proxy */ |
461 |
return(1); |
462 |
463 |
/* get BSDF data */ |
464 |
nd.sd = loadBSDF(m->oargs.sarg[1]); |
465 |
/* diffuse reflectance */ |
466 |
if (hitfront) { |
467 |
if (m->oargs.nfargs < 3) |
468 |
setcolor(nd.rdiff, .0, .0, .0); |
469 |
else |
470 |
setcolor(nd.rdiff, m->oargs.farg[0], |
471 |
m->oargs.farg[1], |
472 |
m->oargs.farg[2]); |
473 |
} else { |
474 |
if (m->oargs.nfargs < 6) { /* check invisible backside */ |
475 |
if (!backvis && (nd.sd->rb == NULL) & |
476 |
(nd.sd->tb == NULL)) { |
477 |
SDfreeCache(nd.sd); |
478 |
raytrans(r); |
479 |
return(1); |
480 |
481 |
482 |
} else |
483 |
setcolor(nd.rdiff, m->oargs.farg[3], |
484 |
m->oargs.farg[4], |
485 |
m->oargs.farg[5]); |
486 |
487 |
/* diffuse transmittance */ |
488 |
if (m->oargs.nfargs < 9) |
489 |
setcolor(nd.tdiff, .0, .0, .0); |
490 |
else |
491 |
setcolor(nd.tdiff, m->oargs.farg[6], |
492 |
m->oargs.farg[7], |
493 |
m->oargs.farg[8]); |
494 |
nd.mp = m; |
495 |
nd.pr = r; |
496 |
/* get modifiers */ |
497 |
raytexture(r, m->omod); |
498 |
/* modify diffuse values */ |
499 |
multcolor(nd.rdiff, r->pcol); |
500 |
multcolor(nd.tdiff, r->pcol); |
501 |
/* get up vector */ |
502 |
upvec[0] = evalue(mf->ep[1]); |
503 |
upvec[1] = evalue(mf->ep[2]); |
504 |
upvec[2] = evalue(mf->ep[3]); |
505 |
/* return to world coords */ |
506 |
if (mf->fxp != &unitxf) { |
507 |
multv3(upvec, upvec, mf->fxp->xfm); |
508 |
nd.thick *= mf->fxp->sca; |
509 |
510 |
if (r->rox != NULL) { |
511 |
multv3(upvec, upvec, r->rox->f.xfm); |
512 |
nd.thick *= r->rox->f.sca; |
513 |
514 |
raynormal(nd.pnorm, r); |
515 |
/* compute local BSDF xform */ |
516 |
ec = SDcompXform(nd.toloc, nd.pnorm, upvec); |
517 |
if (!ec) { |
518 |
nd.vray[0] = -r->rdir[0]; |
519 |
nd.vray[1] = -r->rdir[1]; |
520 |
nd.vray[2] = -r->rdir[2]; |
521 |
ec = SDmapDir(nd.vray, nd.toloc, nd.vray); |
522 |
523 |
if (!ec) |
524 |
ec = SDinvXform(nd.fromloc, nd.toloc); |
525 |
if (ec) { |
526 |
objerror(m, WARNING, "Illegal orientation vector"); |
527 |
return(1); |
528 |
529 |
/* determine BSDF resolution */ |
530 |
ec = SDsizeBSDF(nd.sr_vpsa, nd.vray, NULL, SDqueryMin+SDqueryMax, nd.sd); |
531 |
if (ec) |
532 |
objerror(m, USER, transSDError(ec)); |
533 |
534 |
nd.sr_vpsa[0] = sqrt(nd.sr_vpsa[0]); |
535 |
nd.sr_vpsa[1] = sqrt(nd.sr_vpsa[1]); |
536 |
if (!hitfront) { /* perturb normal towards hit */ |
537 |
nd.pnorm[0] = -nd.pnorm[0]; |
538 |
nd.pnorm[1] = -nd.pnorm[1]; |
539 |
nd.pnorm[2] = -nd.pnorm[2]; |
540 |
541 |
/* sample reflection */ |
542 |
sample_sdf(&nd, SDsampSpR); |
543 |
/* sample transmission */ |
544 |
sample_sdf(&nd, SDsampSpT); |
545 |
/* compute indirect diffuse */ |
546 |
copycolor(ctmp, nd.rdiff); |
547 |
addcolor(ctmp, nd.runsamp); |
548 |
if (bright(ctmp) > FTINY) { /* ambient from reflection */ |
549 |
if (!hitfront) |
550 |
flipsurface(r); |
551 |
multambient(ctmp, r, nd.pnorm); |
552 |
addcolor(r->rcol, ctmp); |
553 |
if (!hitfront) |
554 |
flipsurface(r); |
555 |
556 |
copycolor(ctmp, nd.tdiff); |
557 |
addcolor(ctmp, nd.tunsamp); |
558 |
if (bright(ctmp) > FTINY) { /* ambient from other side */ |
559 |
FVECT bnorm; |
560 |
if (hitfront) |
561 |
flipsurface(r); |
562 |
bnorm[0] = -nd.pnorm[0]; |
563 |
bnorm[1] = -nd.pnorm[1]; |
564 |
bnorm[2] = -nd.pnorm[2]; |
565 |
if (nd.thick != 0) { /* proxy with offset? */ |
566 |
VCOPY(vtmp, r->rop); |
567 |
VSUM(r->rop, vtmp, r->ron, nd.thick); |
568 |
multambient(ctmp, r, bnorm); |
569 |
VCOPY(r->rop, vtmp); |
570 |
} else |
571 |
572 |
573 |
if (hitfront) |
574 |
flipsurface(r); |
575 |
576 |
/* add direct component */ |
577 |
if ((bright(nd.tdiff) <= FTINY) & (nd.sd->tf == NULL) & |
578 |
579 |
direct(r, dir_brdf, &nd); /* reflection only */ |
580 |
} else if (nd.thick == 0) { |
581 |
direct(r, dir_bsdf, &nd); /* thin surface scattering */ |
582 |
} else { |
583 |
direct(r, dir_brdf, &nd); /* reflection first */ |
584 |
VCOPY(vtmp, r->rop); /* offset for transmitted */ |
585 |
VSUM(r->rop, vtmp, r->ron, -nd.thick); |
586 |
direct(r, dir_btdf, &nd); /* separate transmission */ |
587 |
588 |
589 |
/* clean up */ |
590 |
591 |
return(1); |
592 |
