--- ray/src/rt/m_bsdf.c 2018/11/13 19:58:33 2.56 +++ ray/src/rt/m_bsdf.c 2021/08/25 16:12:21 2.64 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_bsdf.c,v 2.56 2018/11/13 19:58:33 greg Exp $"; +static const char RCSid[] = "$Id: m_bsdf.c,v 2.64 2021/08/25 16:12:21 greg Exp $"; #endif /* * Shading for materials with BSDFs taken from XML data files @@ -87,6 +87,7 @@ typedef struct { RREAL fromloc[3][3]; /* local BSDF coords to world */ double thick; /* surface thickness */ COLOR cthru; /* "through" component for MAT_ABSDF */ + COLOR cthru_surr; /* surround for "through" component */ SDData *sd; /* loaded BSDF data */ COLOR rdiff; /* diffuse reflection */ COLOR runsamp; /* BSDF hemispherical reflection */ @@ -96,32 +97,51 @@ typedef struct { #define cvt_sdcolor(cv, svp) ccy2rgb(&(svp)->spec, (svp)->cieY, cv) +typedef struct { + double vy; /* brightness (for sorting) */ + FVECT tdir; /* through sample direction (normalized) */ + COLOR vcol; /* BTDF color */ +} PEAKSAMP; /* BTDF peak sample */ + +/* Comparison function to put near-peak values in descending order */ +static int +cmp_psamp(const void *p1, const void *p2) +{ + double diff = (*(const PEAKSAMP *)p1).vy - (*(const PEAKSAMP *)p2).vy; + if (diff > 0) return(-1); + if (diff < 0) return(1); + return(0); +} + /* Compute "through" component color for MAT_ABSDF */ static void compute_through(BSDFDAT *ndp) { -#define NDIR2CHECK 13 +#define NDIR2CHECK 29 static const float dir2check[NDIR2CHECK][2] = { - {0, 0}, - {-0.8, 0}, - {0, 0.8}, - {0, -0.8}, - {0.8, 0}, - {-0.8, 0.8}, - {-0.8, -0.8}, - {0.8, 0.8}, - {0.8, -0.8}, - {-1.6, 0}, - {0, 1.6}, - {0, -1.6}, - {1.6, 0}, + {0, 0}, {-0.6, 0}, {0, 0.6}, + {0, -0.6}, {0.6, 0}, {-0.6, 0.6}, + {-0.6, -0.6}, {0.6, 0.6}, {0.6, -0.6}, + {-1.2, 0}, {0, 1.2}, {0, -1.2}, + {1.2, 0}, {-1.2, 1.2}, {-1.2, -1.2}, + {1.2, 1.2}, {1.2, -1.2}, {-1.8, 0}, + {0, 1.8}, {0, -1.8}, {1.8, 0}, + {-1.8, 1.8}, {-1.8, -1.8}, {1.8, 1.8}, + {1.8, -1.8}, {-2.4, 0}, {0, 2.4}, + {0, -2.4}, {2.4, 0}, }; +#define neighbors(i,j) \ + ((dir2check[i][0]-dir2check[j][0])*(dir2check[i][0]-dir2check[j][0]) + \ + (dir2check[i][1]-dir2check[j][1])*(dir2check[i][1]-dir2check[j][1]) <= 0.73) const double peak_over = 1.5; + PEAKSAMP psamp[NDIR2CHECK]; SDSpectralDF *dfp; FVECT pdir; double tomega, srchrad; - COLOR vpeak, vsum; - int i; + double tomsum, tomsurr; + COLOR vpeak, vsurr; + double vypeak; + int i, j, ns; SDError ec; if (ndp->pr->rod > 0) @@ -133,47 +153,68 @@ compute_through(BSDFDAT *ndp) return; /* no specular transmission */ if (bright(ndp->pr->pcol) <= FTINY) return; /* pattern is black, here */ - srchrad = sqrt(dfp->minProjSA); /* else search for peak */ - setcolor(vpeak, 0, 0, 0); - setcolor(vsum, 0, 0, 0); - pdir[2] = 0.0; + srchrad = sqrt(dfp->minProjSA); /* else evaluate peak */ for (i = 0; i < NDIR2CHECK; i++) { - FVECT tdir; SDValue sv; - COLOR vcol; - tdir[0] = -ndp->vray[0] + dir2check[i][0]*srchrad; - tdir[1] = -ndp->vray[1] + dir2check[i][1]*srchrad; - tdir[2] = -ndp->vray[2]; - normalize(tdir); - ec = SDevalBSDF(&sv, tdir, ndp->vray, ndp->sd); + psamp[i].tdir[0] = -ndp->vray[0] + dir2check[i][0]*srchrad; + psamp[i].tdir[1] = -ndp->vray[1] + dir2check[i][1]*srchrad; + psamp[i].tdir[2] = -ndp->vray[2]; + normalize(psamp[i].tdir); + ec = SDevalBSDF(&sv, psamp[i].tdir, ndp->vray, ndp->sd); if (ec) goto baderror; - cvt_sdcolor(vcol, &sv); - addcolor(vsum, vcol); - if (sv.cieY > bright(vpeak)) { - copycolor(vpeak, vcol); - VCOPY(pdir, tdir); + cvt_sdcolor(psamp[i].vcol, &sv); + psamp[i].vy = sv.cieY; + } + qsort(psamp, NDIR2CHECK, sizeof(PEAKSAMP), cmp_psamp); + if (psamp[0].vy <= FTINY) + return; /* zero area */ + setcolor(vpeak, 0, 0, 0); + setcolor(vsurr, 0, 0, 0); + vypeak = tomsum = tomsurr = 0; /* combine top unique values */ + ns = 0; + for (i = 0; i < NDIR2CHECK; i++) { + for (j = i; j--; ) /* check for duplicate sample */ + if (psamp[j].vy == psamp[i].vy && neighbors(i,j)) + break; + if (j >= 0) + continue; /* skip duplicate */ + + ec = SDsizeBSDF(&tomega, psamp[i].tdir, ndp->vray, + SDqueryMin, ndp->sd); + if (ec) + goto baderror; + /* not really a peak? */ + if (tomega > 1.5*dfp->minProjSA || + vypeak > 8.*psamp[i].vy*ns) { + if (!i) return; /* abort */ + scalecolor(psamp[i].vcol, tomega); + addcolor(vsurr, psamp[i].vcol); + tomsurr += tomega; + continue; } + scalecolor(psamp[i].vcol, tomega); + addcolor(vpeak, psamp[i].vcol); + tomsum += tomega; + vypeak += psamp[i].vy; + ++ns; } - if (pdir[2] == 0.0) - return; /* zero neighborhood */ - ec = SDsizeBSDF(&tomega, pdir, ndp->vray, SDqueryMin, ndp->sd); - if (ec) - goto baderror; - if (tomega > 1.5*dfp->minProjSA) - return; /* not really a peak? */ - if ((bright(vpeak) - ndp->sd->tLamb.cieY*(1./PI))*tomega <= .001) + if (vypeak*tomsurr < peak_over*bright(vsurr)*ns) + return; /* peak not peaky enough */ + if ((vypeak/ns - (ndp->vray[2] > 0 ? ndp->sd->tLambFront.cieY + : ndp->sd->tLambBack.cieY)*(1./PI))*tomsum <= .001) return; /* < 0.1% transmission */ - for (i = 3; i--; ) /* remove peak from average */ - colval(vsum,i) -= colval(vpeak,i); - if (peak_over*bright(vsum) >= (NDIR2CHECK-1)*bright(vpeak)) - return; /* not peaky enough */ - copycolor(ndp->cthru, vpeak); /* else use it */ - scalecolor(ndp->cthru, tomega); + copycolor(ndp->cthru, vpeak); /* already scaled by omega */ multcolor(ndp->cthru, ndp->pr->pcol); /* modify by pattern */ + if (tomsurr > FTINY) { /* surround contribution? */ + scalecolor(vsurr, 1./tomsurr); /* this one is avg. BTDF */ + copycolor(ndp->cthru_surr, vsurr); + multcolor(ndp->cthru_surr, ndp->pr->pcol); + } return; baderror: objerror(ndp->mp, USER, transSDError(ec)); +#undef neighbors #undef NDIR2CHECK } @@ -222,11 +263,16 @@ direct_specular_OK(COLOR cval, FVECT ldir, double omeg return(0); /* all diffuse */ sv = ndp->sd->rLambBack; break; - default: + case 1: if ((ndp->sd->tf == NULL) & (ndp->sd->tb == NULL)) return(0); /* all diffuse */ - sv = ndp->sd->tLamb; + sv = ndp->sd->tLambFront; break; + case 2: + if ((ndp->sd->tf == NULL) & (ndp->sd->tb == NULL)) + return(0); /* all diffuse */ + sv = ndp->sd->tLambBack; + break; } if (sv.cieY > FTINY) { diffY = sv.cieY *= 1./PI; @@ -246,8 +292,12 @@ direct_specular_OK(COLOR cval, FVECT ldir, double omeg ((ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf) ; if (dx*dx + dy*dy <= (2.5*4./PI)*(omega + dfp->minProjSA + - 2.*sqrt(omega*dfp->minProjSA))) - return(0); + 2.*sqrt(omega*dfp->minProjSA))) { + if (bright(ndp->cthru_surr) <= FTINY) + return(0); + copycolor(cval, ndp->cthru_surr); + return(1); /* return non-zero surround BTDF */ + } } ec = SDsizeBSDF(&tomega, ndp->vray, vsrc, SDqueryMin, ndp->sd); if (ec) @@ -285,12 +335,13 @@ direct_specular_OK(COLOR cval, FVECT ldir, double omeg if (tomega2 < .12*tomega) continue; /* not safe to include */ cvt_sdcolor(csmp, &sv); - - if (sf < 2.5*tsr) { /* weight by Y for small sources */ +#if 0 + if (sf < 2.5*tsr) { /* weight by BSDF for small sources */ scalecolor(csmp, sv.cieY); wtot += sv.cieY; } else - wtot += 1.; +#endif + wtot += 1.; addcolor(cval, csmp); } if (wtot <= FTINY) /* no valid specular samples? */ @@ -639,7 +690,7 @@ m_bsdf(OBJREC *m, RAY *r) SDfreeCache(nd.sd); return(1); } - /* diffuse reflectance */ + /* diffuse components */ if (hitfront) { cvt_sdcolor(nd.rdiff, &nd.sd->rLambFront); if (m->oargs.nfargs >= 3) { @@ -648,6 +699,7 @@ m_bsdf(OBJREC *m, RAY *r) m->oargs.farg[2]); addcolor(nd.rdiff, ctmp); } + cvt_sdcolor(nd.tdiff, &nd.sd->tLambFront); } else { cvt_sdcolor(nd.rdiff, &nd.sd->rLambBack); if (m->oargs.nfargs >= 6) { @@ -656,10 +708,9 @@ m_bsdf(OBJREC *m, RAY *r) m->oargs.farg[5]); addcolor(nd.rdiff, ctmp); } + cvt_sdcolor(nd.tdiff, &nd.sd->tLambBack); } - /* diffuse transmittance */ - cvt_sdcolor(nd.tdiff, &nd.sd->tLamb); - if (m->oargs.nfargs >= 9) { + if (m->oargs.nfargs >= 9) { /* add diffuse transmittance? */ setcolor(ctmp, m->oargs.farg[6], m->oargs.farg[7], m->oargs.farg[8]); @@ -698,6 +749,7 @@ m_bsdf(OBJREC *m, RAY *r) return(1); } setcolor(nd.cthru, 0, 0, 0); /* consider through component */ + setcolor(nd.cthru_surr, 0, 0, 0); if (m->otype == MAT_ABSDF) { compute_through(&nd); if (r->crtype & SHADOW) {
