--- ray/src/rt/m_bsdf.c 2011/02/19 23:42:09 2.4 +++ ray/src/rt/m_bsdf.c 2018/08/08 04:15:18 2.54 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_bsdf.c,v 2.4 2011/02/19 23:42:09 greg Exp $"; +static const char RCSid[] = "$Id: m_bsdf.c,v 2.54 2018/08/08 04:15:18 greg Exp $"; #endif /* * Shading for materials with BSDFs taken from XML data files @@ -8,41 +8,64 @@ static const char RCSid[] = "$Id: m_bsdf.c,v 2.4 2011/ #include "copyright.h" #include "ray.h" +#include "otypes.h" #include "ambient.h" #include "source.h" #include "func.h" #include "bsdf.h" #include "random.h" +#include "pmapmat.h" /* - * Arguments to this material include optional diffuse colors. + * Arguments to this material include optional diffuse colors. * String arguments include the BSDF and function files. - * A thickness variable causes the strange but useful behavior - * of translating transmitted rays this distance past the surface - * intersection in the normal direction to bypass intervening geometry. - * This only affects scattered, non-source directed samples. Thus, - * thickness is relevant only if there is a transmitted component. - * A positive thickness has the further side-effect that an unscattered - * (view) ray will pass right through our material if it has any - * non-diffuse transmission, making our BSDF invisible. This allows the - * underlying geometry to become visible. A matching surface should be - * placed on the other side, less than the thickness away, if the backside - * reflectance is non-zero. + * For the MAT_BSDF type, a non-zero thickness causes the useful behavior + * of translating transmitted rays this distance beneath the surface + * (opposite the surface normal) to bypass any intervening geometry. + * Translation only affects scattered, non-source-directed samples. + * A non-zero thickness has the further side-effect that an unscattered + * (view) ray will pass right through our material, making the BSDF + * surface invisible and showing the proxied geometry instead. Thickness + * has the further effect of turning off reflection on the reverse side so + * rays heading in the opposite direction pass unimpeded through the BSDF + * surface. A paired surface may be placed on the opposide side of + * the detail geometry, less than this thickness away, if a two-way + * proxy is desired. Note that the sign of the thickness is important. + * A positive thickness hides geometry behind the BSDF surface and uses + * front reflectance and transmission properties. A negative thickness + * hides geometry in front of the surface when rays hit from behind, + * and applies only the transmission and backside reflectance properties. + * Reflection is ignored on the hidden side, as those rays pass through. + * For the MAT_ABSDF type, we check for a strong "through" component. + * Such a component will cause direct rays to pass through unscattered. + * A separate test prevents over-counting by dropping samples that are + * too close to this "through" direction. BSDFs with such a through direction + * will also have a view component, meaning they are somewhat see-through. + * A MAT_BSDF type with zero thickness behaves the same as a MAT_ABSDF + * type with no strong through component. * The "up" vector for the BSDF is given by three variables, defined * (along with the thickness) by the named function file, or '.' if none. * Together with the surface normal, this defines the local coordinate * system for the BSDF. * We do not reorient the surface, so if the BSDF has no back-side - * reflectance and none is given in the real arguments, the surface will - * appear as black when viewed from behind (unless backvis is false). - * The diffuse compnent arguments are added to components in the BSDF file, + * reflectance and none is given in the real arguments, a BSDF surface + * with zero thickness will appear black when viewed from behind + * unless backface visibility is on, when it becomes invisible. + * The diffuse arguments are added to components in the BSDF file, * not multiplied. However, patterns affect this material as a multiplier * on everything except non-diffuse reflection. * + * Arguments for MAT_ABSDF are: + * 5+ BSDFfile ux uy uz funcfile transform + * 0 + * 0|3|6|9 rdf gdf bdf + * rdb gdb bdb + * rdt gdt bdt + * * Arguments for MAT_BSDF are: * 6+ thick BSDFfile ux uy uz funcfile transform * 0 - * 0|3|9 rdf gdf bdf + * 0|3|6|9 rdf gdf bdf * rdb gdb bdb * rdt gdt bdt */ @@ -50,7 +73,7 @@ static const char RCSid[] = "$Id: m_bsdf.c,v 2.4 2011/ /* * Note that our reverse ray-tracing process means that the positions * of incoming and outgoing vectors may be reversed in our calls - * to the BSDF library. This is fine, since the bidirectional nature + * to the BSDF library. This is usually fine, since the bidirectional nature * of the BSDF (that's what the 'B' stands for) means it all works out. */ @@ -59,25 +82,105 @@ typedef struct { RAY *pr; /* intersected ray */ FVECT pnorm; /* perturbed surface normal */ FVECT vray; /* local outgoing (return) vector */ - double sr_vpsa; /* sqrt of BSDF projected solid angle */ + double sr_vpsa[2]; /* sqrt of BSDF projected solid angle extrema */ RREAL toloc[3][3]; /* world to local BSDF coords */ RREAL fromloc[3][3]; /* local BSDF coords to world */ double thick; /* surface thickness */ + COLOR cthru; /* "through" component for MAT_ABSDF */ SDData *sd; /* loaded BSDF data */ + COLOR rdiff; /* diffuse reflection */ COLOR runsamp; /* BSDF hemispherical reflection */ - COLOR rdiff; /* added diffuse reflection */ + COLOR tdiff; /* diffuse transmission */ COLOR tunsamp; /* BSDF hemispherical transmission */ - COLOR tdiff; /* added diffuse transmission */ } BSDFDAT; /* BSDF material data */ #define cvt_sdcolor(cv, svp) ccy2rgb(&(svp)->spec, (svp)->cieY, cv) -/* Jitter ray sample according to projected solid angle and specjitter */ +/* Compute "through" component color for MAT_ABSDF */ static void -bsdf_jitter(FVECT vres, BSDFDAT *ndp) +compute_through(BSDFDAT *ndp) { - double sr_psa = ndp->sr_vpsa; +#define NDIR2CHECK 13 + static const float dir2check[NDIR2CHECK][2] = { + {0, 0}, + {-0.8, 0}, + {0, 0.8}, + {0, -0.8}, + {0.8, 0}, + {-0.8, 0.8}, + {-0.8, -0.8}, + {0.8, 0.8}, + {0.8, -0.8}, + {-1.6, 0}, + {0, 1.6}, + {0, -1.6}, + {1.6, 0}, + }; + const double peak_over = 1.5; + SDSpectralDF *dfp; + FVECT pdir; + double tomega, srchrad; + COLOR vpeak, vsum; + int i; + SDError ec; + if (ndp->pr->rod > 0) + dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb; + else + dfp = (ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf; + + if (dfp == NULL) + return; /* no specular transmission */ + if (bright(ndp->pr->pcol) <= FTINY) + return; /* pattern is black, here */ + srchrad = sqrt(dfp->minProjSA); /* else search for peak */ + setcolor(vpeak, 0, 0, 0); + setcolor(vsum, 0, 0, 0); + pdir[2] = 0.0; + for (i = 0; i < NDIR2CHECK; i++) { + FVECT tdir; + SDValue sv; + COLOR vcol; + tdir[0] = -ndp->vray[0] + dir2check[i][0]*srchrad; + tdir[1] = -ndp->vray[1] + dir2check[i][1]*srchrad; + tdir[2] = -ndp->vray[2]; + normalize(tdir); + ec = SDevalBSDF(&sv, tdir, ndp->vray, ndp->sd); + if (ec) + goto baderror; + cvt_sdcolor(vcol, &sv); + addcolor(vsum, vcol); + if (sv.cieY > bright(vpeak)) { + copycolor(vpeak, vcol); + VCOPY(pdir, tdir); + } + } + if (pdir[2] == 0.0) + return; /* zero neighborhood */ + ec = SDsizeBSDF(&tomega, pdir, ndp->vray, SDqueryMin, ndp->sd); + if (ec) + goto baderror; + if (tomega > 1.5*dfp->minProjSA) + return; /* not really a peak? */ + if ((bright(vpeak) - ndp->sd->tLamb.cieY*(1./PI))*tomega <= .001) + return; /* < 0.1% transmission */ + for (i = 3; i--; ) /* remove peak from average */ + colval(vsum,i) -= colval(vpeak,i); + if (peak_over*bright(vsum) >= (NDIR2CHECK-1)*bright(vpeak)) + return; /* not peaky enough */ + copycolor(ndp->cthru, vpeak); /* else use it */ + scalecolor(ndp->cthru, tomega); + multcolor(ndp->cthru, ndp->pr->pcol); /* modify by pattern */ + return; +baderror: + objerror(ndp->mp, USER, transSDError(ec)); +#undef NDIR2CHECK +} + +/* Jitter ray sample according to projected solid angle and specjitter */ +static void +bsdf_jitter(FVECT vres, BSDFDAT *ndp, double sr_psa) +{ VCOPY(vres, ndp->vray); if (specjitter < 1.) sr_psa *= specjitter; @@ -88,9 +191,126 @@ bsdf_jitter(FVECT vres, BSDFDAT *ndp) normalize(vres); } -/* Compute source contribution for BSDF */ +/* Get BSDF specular for direct component, returning true if OK to proceed */ +static int +direct_specular_OK(COLOR cval, FVECT ldir, double omega, BSDFDAT *ndp) +{ + int nsamp; + double wtot = 0; + FVECT vsrc, vsmp, vjit; + double tomega, tomega2; + double sf, tsr, sd[2]; + COLOR csmp, cdiff; + double diffY; + SDValue sv; + SDError ec; + int i; + /* in case we fail */ + setcolor(cval, 0, 0, 0); + /* transform source direction */ + if (SDmapDir(vsrc, ndp->toloc, ldir) != SDEnone) + return(0); + /* will discount diffuse portion */ + switch ((vsrc[2] > 0)<<1 | (ndp->vray[2] > 0)) { + case 3: + if (ndp->sd->rf == NULL) + return(0); /* all diffuse */ + sv = ndp->sd->rLambFront; + break; + case 0: + if (ndp->sd->rb == NULL) + return(0); /* all diffuse */ + sv = ndp->sd->rLambBack; + break; + default: + if ((ndp->sd->tf == NULL) & (ndp->sd->tb == NULL)) + return(0); /* all diffuse */ + sv = ndp->sd->tLamb; + break; + } + if (sv.cieY > FTINY) { + diffY = sv.cieY *= 1./PI; + cvt_sdcolor(cdiff, &sv); + } else { + diffY = 0; + setcolor(cdiff, 0, 0, 0); + } + /* need projected solid angle */ + omega *= fabs(vsrc[2]); + /* check indirect over-counting */ + if ((vsrc[2] > 0) ^ (ndp->vray[2] > 0) && bright(ndp->cthru) > FTINY) { + double dx = vsrc[0] + ndp->vray[0]; + double dy = vsrc[1] + ndp->vray[1]; + SDSpectralDF *dfp = (ndp->pr->rod > 0) ? + ((ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb) : + ((ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf) ; + + if (dx*dx + dy*dy <= (2.5*4./PI)*(omega + dfp->minProjSA + + 2.*sqrt(omega*dfp->minProjSA))) + return(0); + } + ec = SDsizeBSDF(&tomega, ndp->vray, vsrc, SDqueryMin, ndp->sd); + if (ec) + goto baderror; + /* assign number of samples */ + sf = specjitter * ndp->pr->rweight; + if (tomega <= 0) + nsamp = 1; + else if (25.*tomega <= omega) + nsamp = 100.*sf + .5; + else + nsamp = 4.*sf*omega/tomega + .5; + nsamp += !nsamp; + sf = sqrt(omega); /* sample our source area */ + tsr = sqrt(tomega); + for (i = nsamp; i--; ) { + VCOPY(vsmp, vsrc); /* jitter query directions */ + if (nsamp > 1) { + multisamp(sd, 2, (i + frandom())/(double)nsamp); + vsmp[0] += (sd[0] - .5)*sf; + vsmp[1] += (sd[1] - .5)*sf; + normalize(vsmp); + } + bsdf_jitter(vjit, ndp, tsr); + /* compute BSDF */ + ec = SDevalBSDF(&sv, vjit, vsmp, ndp->sd); + if (ec) + goto baderror; + if (sv.cieY - diffY <= FTINY) + continue; /* no specular part */ + /* check for variable resolution */ + ec = SDsizeBSDF(&tomega2, vjit, vsmp, SDqueryMin, ndp->sd); + if (ec) + goto baderror; + if (tomega2 < .12*tomega) + continue; /* not safe to include */ + cvt_sdcolor(csmp, &sv); + + if (sf < 2.5*tsr) { /* weight by Y for small sources */ + scalecolor(csmp, sv.cieY); + wtot += sv.cieY; + } else + wtot += 1.; + addcolor(cval, csmp); + } + if (wtot <= FTINY) /* no valid specular samples? */ + return(0); + + sf = 1./wtot; /* weighted average BSDF */ + scalecolor(cval, sf); + /* subtract diffuse contribution */ + for (i = 3*(diffY > FTINY); i--; ) + if ((colval(cval,i) -= colval(cdiff,i)) < 0) + colval(cval,i) = 0; + return(1); +baderror: + objerror(ndp->mp, USER, transSDError(ec)); + return(0); /* gratis return */ +} + +/* Compute source contribution for BSDF (reflected & transmitted) */ static void -dirbsdf( +dir_bsdf( COLOR cval, /* returned coefficient */ void *nnp, /* material data */ FVECT ldir, /* light source direction */ @@ -98,123 +318,199 @@ dirbsdf( ) { BSDFDAT *np = (BSDFDAT *)nnp; - SDError ec; - SDValue sv; - FVECT vsrc; - FVECT vjit; double ldot; double dtmp; COLOR ctmp; - setcolor(cval, .0, .0, .0); + setcolor(cval, 0, 0, 0); ldot = DOT(np->pnorm, ldir); if ((-FTINY <= ldot) & (ldot <= FTINY)) return; - if (ldot > .0 && bright(np->rdiff) > FTINY) { + if (ldot > 0 && bright(np->rdiff) > FTINY) { /* - * Compute added diffuse reflected component. + * Compute diffuse reflected component */ copycolor(ctmp, np->rdiff); dtmp = ldot * omega * (1./PI); scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } - if (ldot < .0 && bright(np->tdiff) > FTINY) { + if (ldot < 0 && bright(np->tdiff) > FTINY) { /* - * Compute added diffuse transmission. + * Compute diffuse transmission */ copycolor(ctmp, np->tdiff); dtmp = -ldot * omega * (1.0/PI); scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } + if (ambRayInPmap(np->pr)) + return; /* specular already in photon map */ /* - * Compute scattering coefficient using BSDF. + * Compute specular scattering coefficient using BSDF */ - if (SDmapDir(vsrc, np->toloc, ldir) != SDEnone) + if (!direct_specular_OK(ctmp, ldir, omega, np)) return; - bsdf_jitter(vjit, np); - ec = SDevalBSDF(&sv, vjit, vsrc, np->sd); - if (ec) - objerror(np->mp, USER, transSDError(ec)); - - if (sv.cieY <= FTINY) /* not worth using? */ - return; - cvt_sdcolor(ctmp, &sv); - if (ldot > .0) { /* pattern only diffuse reflection */ - COLOR ctmp1, ctmp2; - dtmp = (np->pr->rod > .0) ? np->sd->rLambFront.cieY - : np->sd->rLambBack.cieY; - dtmp /= PI * sv.cieY; /* diffuse fraction */ - copycolor(ctmp2, np->pr->pcol); - scalecolor(ctmp2, dtmp); - setcolor(ctmp1, 1.-dtmp, 1.-dtmp, 1.-dtmp); - addcolor(ctmp1, ctmp2); - multcolor(ctmp, ctmp1); /* apply derated pattern */ - dtmp = ldot * omega; - } else { /* full pattern on transmission */ + if (ldot < 0) { /* pattern for specular transmission */ multcolor(ctmp, np->pr->pcol); dtmp = -ldot * omega; + } else + dtmp = ldot * omega; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); +} + +/* Compute source contribution for BSDF (reflected only) */ +static void +dir_brdf( + COLOR cval, /* returned coefficient */ + void *nnp, /* material data */ + FVECT ldir, /* light source direction */ + double omega /* light source size */ +) +{ + BSDFDAT *np = (BSDFDAT *)nnp; + double ldot; + double dtmp; + COLOR ctmp, ctmp1, ctmp2; + + setcolor(cval, 0, 0, 0); + + ldot = DOT(np->pnorm, ldir); + + if (ldot <= FTINY) + return; + + if (bright(np->rdiff) > FTINY) { + /* + * Compute diffuse reflected component + */ + copycolor(ctmp, np->rdiff); + dtmp = ldot * omega * (1./PI); + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); } + if (ambRayInPmap(np->pr)) + return; /* specular already in photon map */ + /* + * Compute specular reflection coefficient using BSDF + */ + if (!direct_specular_OK(ctmp, ldir, omega, np)) + return; + dtmp = ldot * omega; scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } +/* Compute source contribution for BSDF (transmitted only) */ +static void +dir_btdf( + COLOR cval, /* returned coefficient */ + void *nnp, /* material data */ + FVECT ldir, /* light source direction */ + double omega /* light source size */ +) +{ + BSDFDAT *np = (BSDFDAT *)nnp; + double ldot; + double dtmp; + COLOR ctmp; + + setcolor(cval, 0, 0, 0); + + ldot = DOT(np->pnorm, ldir); + + if (ldot >= -FTINY) + return; + + if (bright(np->tdiff) > FTINY) { + /* + * Compute diffuse transmission + */ + copycolor(ctmp, np->tdiff); + dtmp = -ldot * omega * (1.0/PI); + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } + if (ambRayInPmap(np->pr)) + return; /* specular already in photon map */ + /* + * Compute specular scattering coefficient using BSDF + */ + if (!direct_specular_OK(ctmp, ldir, omega, np)) + return; + /* full pattern on transmission */ + multcolor(ctmp, np->pr->pcol); + dtmp = -ldot * omega; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); +} + /* Sample separate BSDF component */ static int -sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usepat) +sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int xmit) { - int nstarget = 1; - int nsent = 0; - SDError ec; - SDValue bsv; - double sthick; - FVECT vjit, vsmp; - RAY sr; - int ntrials; + const int hasthru = (xmit && + !(ndp->pr->crtype & (SPECULAR|AMBIENT)) + && bright(ndp->cthru) > FTINY); + int nstarget = 1; + int nsent = 0; + int n; + SDError ec; + SDValue bsv; + double xrand; + FVECT vsmp, vinc; + RAY sr; /* multiple samples? */ if (specjitter > 1.5) { nstarget = specjitter*ndp->pr->rweight + .5; - if (nstarget < 1) - nstarget = 1; + nstarget += !nstarget; } - /* run through our trials */ - for (ntrials = 0; nsent < nstarget && ntrials < 9*nstarget; ntrials++) { - SDerrorDetail[0] = '\0'; - /* sample direction & coef. */ - bsdf_jitter(vjit, ndp); - ec = SDsampComponent(&bsv, vsmp, vjit, ntrials ? frandom() - : urand(ilhash(dimlist,ndims)+samplendx), dcp); + /* run through our samples */ + for (n = 0; n < nstarget; n++) { + if (nstarget == 1) { /* stratify random variable */ + xrand = urand(ilhash(dimlist,ndims)+samplendx); + if (specjitter < 1.) + xrand = .5 + specjitter*(xrand-.5); + } else { + xrand = (n + frandom())/(double)nstarget; + } + SDerrorDetail[0] = '\0'; /* sample direction & coef. */ + bsdf_jitter(vsmp, ndp, ndp->sr_vpsa[0]); + VCOPY(vinc, vsmp); /* to compare after */ + ec = SDsampComponent(&bsv, vsmp, xrand, dcp); if (ec) objerror(ndp->mp, USER, transSDError(ec)); - /* zero component? */ - if (bsv.cieY <= FTINY) + if (bsv.cieY <= FTINY) /* zero component? */ break; - /* map vector to world */ + if (hasthru) { /* check for view ray */ + double dx = vinc[0] + vsmp[0]; + double dy = vinc[1] + vsmp[1]; + if (dx*dx + dy*dy <= ndp->sr_vpsa[0]*ndp->sr_vpsa[0]) + continue; /* exclude view sample */ + } + /* map non-view sample->world */ if (SDmapDir(sr.rdir, ndp->fromloc, vsmp) != SDEnone) break; - /* unintentional penetration? */ - if (DOT(sr.rdir, ndp->pr->ron) > .0 ^ vsmp[2] > .0) - continue; /* spawn a specular ray */ if (nstarget > 1) bsv.cieY /= (double)nstarget; - cvt_sdcolor(sr.rcoef, &bsv); /* use color */ - if (usepat) /* pattern on transmission */ + cvt_sdcolor(sr.rcoef, &bsv); /* use sample color */ + if (xmit) /* apply pattern on transmit */ multcolor(sr.rcoef, ndp->pr->pcol); if (rayorigin(&sr, SPECULAR, ndp->pr, sr.rcoef) < 0) { - if (maxdepth > 0) - break; - ++nsent; /* Russian roulette victim */ - continue; + if (!n & (nstarget > 1)) { + n = nstarget; /* avoid infinitue loop */ + nstarget = nstarget*sr.rweight/minweight; + if (n == nstarget) break; + n = -1; /* moved target */ + } + continue; /* try again */ } - if (ndp->thick > FTINY) { /* need to move origin? */ - sthick = (ndp->pr->rod > .0) ? -ndp->thick : ndp->thick; - if (sthick < .0 ^ vsmp[2] > .0) - VSUM(sr.rorg, sr.rorg, ndp->pr->ron, sthick); - } + if (xmit && ndp->thick != 0) /* need to offset origin? */ + VSUM(sr.rorg, sr.rorg, ndp->pr->ron, -ndp->thick); rayvalue(&sr); /* send & evaluate sample */ multcolor(sr.rcol, sr.rcoef); addcolor(ndp->pr->rcol, sr.rcol); @@ -227,47 +523,63 @@ sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usep static int sample_sdf(BSDFDAT *ndp, int sflags) { + int hasthru = (sflags == SDsampSpT && + !(ndp->pr->crtype & (SPECULAR|AMBIENT)) + && bright(ndp->cthru) > FTINY); int n, ntotal = 0; + double b = 0; SDSpectralDF *dfp; COLORV *unsc; if (sflags == SDsampSpT) { unsc = ndp->tunsamp; - dfp = ndp->sd->tf; - cvt_sdcolor(unsc, &ndp->sd->tLamb); + if (ndp->pr->rod > 0) + dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb; + else + dfp = (ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf; } else /* sflags == SDsampSpR */ { unsc = ndp->runsamp; - if (ndp->pr->rod > .0) { + if (ndp->pr->rod > 0) dfp = ndp->sd->rf; - cvt_sdcolor(unsc, &ndp->sd->rLambFront); - } else { + else dfp = ndp->sd->rb; - cvt_sdcolor(unsc, &ndp->sd->rLambBack); - } } - multcolor(unsc, ndp->pr->pcol); + setcolor(unsc, 0, 0, 0); if (dfp == NULL) /* no specular component? */ return(0); - /* below sampling threshold? */ - if (dfp->maxHemi <= specthresh+FTINY) { - if (dfp->maxHemi > FTINY) { /* XXX no color from BSDF */ - FVECT vjit; - double d; - COLOR ctmp; - bsdf_jitter(vjit, ndp); - d = SDdirectHemi(vjit, sflags, ndp->sd); + + if (hasthru) { /* separate view sample? */ + RAY tr; + if (rayorigin(&tr, TRANS, ndp->pr, ndp->cthru) == 0) { + VCOPY(tr.rdir, ndp->pr->rdir); + rayvalue(&tr); + multcolor(tr.rcol, tr.rcoef); + addcolor(ndp->pr->rcol, tr.rcol); + ++ntotal; + b = bright(ndp->cthru); + } else + hasthru = 0; + } + if (dfp->maxHemi - b <= FTINY) { /* have specular to sample? */ + b = 0; + } else { + FVECT vjit; + bsdf_jitter(vjit, ndp, ndp->sr_vpsa[1]); + b = SDdirectHemi(vjit, sflags, ndp->sd) - b; + if (b < 0) b = 0; + } + if (b <= specthresh+FTINY) { /* below sampling threshold? */ + if (b > FTINY) { /* XXX no color from BSDF */ if (sflags == SDsampSpT) { - copycolor(ctmp, ndp->pr->pcol); - scalecolor(ctmp, d); + copycolor(unsc, ndp->pr->pcol); + scalecolor(unsc, b); } else /* no pattern on reflection */ - setcolor(ctmp, d, d, d); - addcolor(unsc, ctmp); + setcolor(unsc, b, b, b); } - return(0); + return(ntotal); } - /* else need to sample */ - dimlist[ndims++] = (int)(size_t)ndp->mp; - ndims++; + dimlist[ndims] = (int)(size_t)ndp->mp; /* else sample specular */ + ndims += 2; for (n = dfp->ncomp; n--; ) { /* loop over components */ dimlist[ndims-1] = n + 9438; ntotal += sample_sdcomp(ndp, &dfp->comp[n], sflags==SDsampSpT); @@ -280,87 +592,94 @@ sample_sdf(BSDFDAT *ndp, int sflags) int m_bsdf(OBJREC *m, RAY *r) { + int hasthick = (m->otype == MAT_BSDF); + int hitfront; COLOR ctmp; SDError ec; - FVECT upvec, outVec; + FVECT upvec, vtmp; MFUNC *mf; BSDFDAT nd; /* check arguments */ - if ((m->oargs.nsargs < 6) | (m->oargs.nfargs > 9) | + if ((m->oargs.nsargs < hasthick+5) | (m->oargs.nfargs > 9) | (m->oargs.nfargs % 3)) objerror(m, USER, "bad # arguments"); - - /* get BSDF data */ - nd.sd = loadBSDF(m->oargs.sarg[1]); + /* record surface struck */ + hitfront = (r->rod > 0); /* load cal file */ - mf = getfunc(m, 5, 0x1d, 1); - /* get thickness */ - nd.thick = evalue(mf->ep[0]); - if (nd.thick < .0) - nd.thick = .0; - /* check shadow */ - if (r->crtype & SHADOW) { - if ((nd.thick > FTINY) & (nd.sd->tf != NULL)) - raytrans(r); /* pass-through */ - SDfreeCache(nd.sd); - return(1); /* else shadow */ + mf = hasthick ? getfunc(m, 5, 0x1d, 1) + : getfunc(m, 4, 0xe, 1) ; + setfunc(m, r); + nd.thick = 0; /* set thickness */ + if (hasthick) { + nd.thick = evalue(mf->ep[0]); + if ((-FTINY <= nd.thick) & (nd.thick <= FTINY)) + nd.thick = 0; } - /* check unscattered ray */ - if (!(r->crtype & (SPECULAR|AMBIENT)) && - (nd.thick > FTINY) & (nd.sd->tf != NULL)) { - SDfreeCache(nd.sd); - raytrans(r); /* pass-through */ + /* check backface visibility */ + if (!hitfront & !backvis) { + raytrans(r); return(1); } + /* check other rays to pass */ + if (nd.thick != 0 && (r->crtype & SHADOW || + !(r->crtype & (SPECULAR|AMBIENT)) || + (nd.thick > 0) ^ hitfront)) { + raytrans(r); /* hide our proxy */ + return(1); + } + if (hasthick && r->crtype & SHADOW) /* early shadow check #1 */ + return(1); + nd.mp = m; + nd.pr = r; + /* get BSDF data */ + nd.sd = loadBSDF(m->oargs.sarg[hasthick]); + /* early shadow check #2 */ + if (r->crtype & SHADOW && (nd.sd->tf == NULL) & (nd.sd->tb == NULL)) + return(1); /* diffuse reflectance */ - if (r->rod > .0) { - if (m->oargs.nfargs < 3) - setcolor(nd.rdiff, .0, .0, .0); - else - setcolor(nd.rdiff, m->oargs.farg[0], + if (hitfront) { + cvt_sdcolor(nd.rdiff, &nd.sd->rLambFront); + if (m->oargs.nfargs >= 3) { + setcolor(ctmp, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); + addcolor(nd.rdiff, ctmp); + } } else { - if (m->oargs.nfargs < 6) { /* check invisible backside */ - if (!backvis && (nd.sd->rb == NULL) & - (nd.sd->tf == NULL)) { - SDfreeCache(nd.sd); - raytrans(r); - return(1); - } - setcolor(nd.rdiff, .0, .0, .0); - } else - setcolor(nd.rdiff, m->oargs.farg[3], + cvt_sdcolor(nd.rdiff, &nd.sd->rLambBack); + if (m->oargs.nfargs >= 6) { + setcolor(ctmp, m->oargs.farg[3], m->oargs.farg[4], m->oargs.farg[5]); + addcolor(nd.rdiff, ctmp); + } } /* diffuse transmittance */ - if (m->oargs.nfargs < 9) - setcolor(nd.tdiff, .0, .0, .0); - else - setcolor(nd.tdiff, m->oargs.farg[6], + cvt_sdcolor(nd.tdiff, &nd.sd->tLamb); + if (m->oargs.nfargs >= 9) { + setcolor(ctmp, m->oargs.farg[6], m->oargs.farg[7], m->oargs.farg[8]); - nd.mp = m; - nd.pr = r; + addcolor(nd.tdiff, ctmp); + } /* get modifiers */ raytexture(r, m->omod); - if (bright(r->pcol) <= FTINY) { /* black pattern?! */ - SDfreeCache(nd.sd); - return(1); - } /* modify diffuse values */ multcolor(nd.rdiff, r->pcol); multcolor(nd.tdiff, r->pcol); /* get up vector */ - upvec[0] = evalue(mf->ep[1]); - upvec[1] = evalue(mf->ep[2]); - upvec[2] = evalue(mf->ep[3]); + upvec[0] = evalue(mf->ep[hasthick+0]); + upvec[1] = evalue(mf->ep[hasthick+1]); + upvec[2] = evalue(mf->ep[hasthick+2]); /* return to world coords */ - if (mf->f != &unitxf) { - multv3(upvec, upvec, mf->f->xfm); - nd.thick *= mf->f->sca; + if (mf->fxp != &unitxf) { + multv3(upvec, upvec, mf->fxp->xfm); + nd.thick *= mf->fxp->sca; } + if (r->rox != NULL) { + multv3(upvec, upvec, r->rox->f.xfm); + nd.thick *= r->rox->f.sca; + } raynormal(nd.pnorm, r); /* compute local BSDF xform */ ec = SDcompXform(nd.toloc, nd.pnorm, upvec); @@ -370,20 +689,34 @@ m_bsdf(OBJREC *m, RAY *r) nd.vray[2] = -r->rdir[2]; ec = SDmapDir(nd.vray, nd.toloc, nd.vray); } - if (!ec) - ec = SDinvXform(nd.fromloc, nd.toloc); - /* determine BSDF resolution */ - if (!ec) - ec = SDsizeBSDF(&nd.sr_vpsa, nd.vray, SDqueryMin, nd.sd); - if (!ec) - nd.sr_vpsa = sqrt(nd.sr_vpsa); - else { - objerror(m, WARNING, transSDError(ec)); - SDfreeCache(nd.sd); + if (ec) { + objerror(m, WARNING, "Illegal orientation vector"); return(1); } - - if (r->rod < .0) { /* perturb normal towards hit */ + setcolor(nd.cthru, 0, 0, 0); /* consider through component */ + if (m->otype == MAT_ABSDF) { + compute_through(&nd); + if (r->crtype & SHADOW) { + RAY tr; /* attempt to pass shadow ray */ + if (rayorigin(&tr, TRANS, r, nd.cthru) < 0) + return(1); /* no through component */ + VCOPY(tr.rdir, r->rdir); + rayvalue(&tr); /* transmit with scaling */ + multcolor(tr.rcol, tr.rcoef); + copycolor(r->rcol, tr.rcol); + return(1); /* we're done */ + } + } + ec = SDinvXform(nd.fromloc, nd.toloc); + if (!ec) /* determine BSDF resolution */ + ec = SDsizeBSDF(nd.sr_vpsa, nd.vray, NULL, + SDqueryMin+SDqueryMax, nd.sd); + if (ec) + objerror(m, USER, transSDError(ec)); + + nd.sr_vpsa[0] = sqrt(nd.sr_vpsa[0]); + nd.sr_vpsa[1] = sqrt(nd.sr_vpsa[1]); + if (!hitfront) { /* perturb normal towards hit */ nd.pnorm[0] = -nd.pnorm[0]; nd.pnorm[1] = -nd.pnorm[1]; nd.pnorm[2] = -nd.pnorm[2]; @@ -395,30 +728,47 @@ m_bsdf(OBJREC *m, RAY *r) /* compute indirect diffuse */ copycolor(ctmp, nd.rdiff); addcolor(ctmp, nd.runsamp); - if (bright(ctmp) > FTINY) { /* ambient from this side */ - if (r->rod < .0) + if (bright(ctmp) > FTINY) { /* ambient from reflection */ + if (!hitfront) flipsurface(r); multambient(ctmp, r, nd.pnorm); addcolor(r->rcol, ctmp); - if (r->rod < .0) + if (!hitfront) flipsurface(r); } copycolor(ctmp, nd.tdiff); addcolor(ctmp, nd.tunsamp); if (bright(ctmp) > FTINY) { /* ambient from other side */ FVECT bnorm; - if (r->rod > .0) + if (hitfront) flipsurface(r); bnorm[0] = -nd.pnorm[0]; bnorm[1] = -nd.pnorm[1]; bnorm[2] = -nd.pnorm[2]; - multambient(ctmp, r, bnorm); + if (nd.thick != 0) { /* proxy with offset? */ + VCOPY(vtmp, r->rop); + VSUM(r->rop, vtmp, r->ron, nd.thick); + multambient(ctmp, r, bnorm); + VCOPY(r->rop, vtmp); + } else + multambient(ctmp, r, bnorm); addcolor(r->rcol, ctmp); - if (r->rod > .0) + if (hitfront) flipsurface(r); } /* add direct component */ - direct(r, dirbsdf, &nd); + if ((bright(nd.tdiff) <= FTINY) & (nd.sd->tf == NULL) & + (nd.sd->tb == NULL)) { + direct(r, dir_brdf, &nd); /* reflection only */ + } else if (nd.thick == 0) { + direct(r, dir_bsdf, &nd); /* thin surface scattering */ + } else { + direct(r, dir_brdf, &nd); /* reflection first */ + VCOPY(vtmp, r->rop); /* offset for transmitted */ + VSUM(r->rop, vtmp, r->ron, -nd.thick); + direct(r, dir_btdf, &nd); /* separate transmission */ + VCOPY(r->rop, vtmp); + } /* clean up */ SDfreeCache(nd.sd); return(1);
