--- ray/src/rt/m_bsdf.c 2017/05/19 15:13:41 2.38 +++ ray/src/rt/m_bsdf.c 2017/07/17 00:14:28 2.40 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_bsdf.c,v 2.38 2017/05/19 15:13:41 greg Exp $"; +static const char RCSid[] = "$Id: m_bsdf.c,v 2.40 2017/07/17 00:14:28 greg Exp $"; #endif /* * Shading for materials with BSDFs taken from XML data files @@ -37,9 +37,9 @@ static const char RCSid[] = "$Id: m_bsdf.c,v 2.38 2017 * Reflection is ignored on the hidden side, as those rays pass through. * When thickness is set to zero, shadow rays will be blocked unless * a BTDF has a strong "through" component in the source direction. - * A separate test prevents over-counting by dropping specular & ambient - * samples that are too close to this "through" direction. The same - * restriction applies for the proxy case (thickness != 0). + * A separate test prevents over-counting by dropping samples that are + * too close to this "through" direction. BSDFs with such a through direction + * will also have a view component, meaning they are somewhat see-through. * The "up" vector for the BSDF is given by three variables, defined * (along with the thickness) by the named function file, or '.' if none. * Together with the surface normal, this defines the local coordinate @@ -79,7 +79,9 @@ typedef struct { COLOR cthru; /* "through" component multiplier */ SDData *sd; /* loaded BSDF data */ COLOR rdiff; /* diffuse reflection */ + COLOR runsamp; /* BSDF hemispherical reflection */ COLOR tdiff; /* diffuse transmission */ + COLOR tunsamp; /* BSDF hemispherical transmission */ } BSDFDAT; /* BSDF material data */ #define cvt_sdcolor(cv, svp) ccy2rgb(&(svp)->spec, (svp)->cieY, cv) @@ -109,14 +111,11 @@ compute_through(BSDFDAT *ndp) FVECT pdir; double tomega, srchrad; COLOR vpeak, vsum; - int nsum, i; + int i; SDError ec; - setcolor(ndp->cthru, .0, .0, .0); /* starting assumption */ + setcolor(ndp->cthru, 0, 0, 0); /* starting assumption */ - if (!(ndp->pr->crtype & (SPECULAR|AMBIENT|SHADOW))) - return; /* simply don't need to know */ - if (ndp->pr->rod > 0) dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb; else @@ -127,9 +126,8 @@ compute_through(BSDFDAT *ndp) if (bright(ndp->pr->pcol) <= FTINY) return; /* pattern is black, here */ srchrad = sqrt(dfp->minProjSA); /* else search for peak */ - setcolor(vpeak, .0, .0, .0); - setcolor(vsum, .0, .0, .0); - nsum = 0; + setcolor(vpeak, 0, 0, 0); + setcolor(vsum, 0, 0, 0); for (i = 0; i < NDIR2CHECK; i++) { FVECT tdir; SDValue sv; @@ -143,7 +141,6 @@ compute_through(BSDFDAT *ndp) goto baderror; cvt_sdcolor(vcol, &sv); addcolor(vsum, vcol); - ++nsum; if (bright(vcol) > bright(vpeak)) { copycolor(vpeak, vcol); VCOPY(pdir, tdir); @@ -154,12 +151,11 @@ compute_through(BSDFDAT *ndp) goto baderror; if (tomega > 1.5*dfp->minProjSA) return; /* not really a peak? */ - if ((bright(vpeak) - ndp->sd->tLamb.cieY*(1./PI))*tomega <= .007) - return; /* < 0.7% transmission */ + if ((bright(vpeak) - ndp->sd->tLamb.cieY*(1./PI))*tomega <= .001) + return; /* < 0.1% transmission */ for (i = 3; i--; ) /* remove peak from average */ colval(vsum,i) -= colval(vpeak,i); - --nsum; - if (peak_over*bright(vsum) >= nsum*bright(vpeak)) + if (peak_over*bright(vsum) >= (NDIR2CHECK-1)*bright(vpeak)) return; /* not peaky enough */ copycolor(ndp->cthru, vpeak); /* else use it */ scalecolor(ndp->cthru, tomega); @@ -198,7 +194,7 @@ direct_specular_OK(COLOR cval, FVECT ldir, double omeg SDError ec; int i; /* in case we fail */ - setcolor(cval, .0, .0, .0); + setcolor(cval, 0, 0, 0); /* transform source direction */ if (SDmapDir(vsrc, ndp->toloc, ldir) != SDEnone) return(0); @@ -224,8 +220,8 @@ direct_specular_OK(COLOR cval, FVECT ldir, double omeg diffY = sv.cieY *= 1./PI; cvt_sdcolor(cdiff, &sv); } else { - diffY = .0; - setcolor(cdiff, .0, .0, .0); + diffY = 0; + setcolor(cdiff, 0, 0, 0); } /* need projected solid angles */ omega *= fabs(vsrc[2]); @@ -233,9 +229,7 @@ direct_specular_OK(COLOR cval, FVECT ldir, double omeg if (ec) goto baderror; /* check indirect over-counting */ - if (ndp->pr->crtype & (SPECULAR|AMBIENT) - && (vsrc[2] > 0) ^ (ndp->vray[2] > 0) - && bright(ndp->cthru) > FTINY) { + if ((vsrc[2] > 0) ^ (ndp->vray[2] > 0) && bright(ndp->cthru) > FTINY) { double dx = vsrc[0] + ndp->vray[0]; double dy = vsrc[1] + ndp->vray[1]; if (dx*dx + dy*dy <= (4./PI)*(omega + tomega + @@ -244,7 +238,7 @@ direct_specular_OK(COLOR cval, FVECT ldir, double omeg } /* assign number of samples */ sf = specjitter * ndp->pr->rweight; - if (tomega <= .0) + if (tomega <= 0) nsamp = 1; else if (25.*tomega <= omega) nsamp = 100.*sf + .5; @@ -285,8 +279,8 @@ direct_specular_OK(COLOR cval, FVECT ldir, double omeg scalecolor(cval, sf); /* subtract diffuse contribution */ for (i = 3*(diffY > FTINY); i--; ) - if ((colval(cval,i) -= colval(cdiff,i)) < .0) - colval(cval,i) = .0; + if ((colval(cval,i) -= colval(cdiff,i)) < 0) + colval(cval,i) = 0; return(1); baderror: objerror(ndp->mp, USER, transSDError(ec)); @@ -307,7 +301,7 @@ dir_bsdf( double dtmp; COLOR ctmp; - setcolor(cval, .0, .0, .0); + setcolor(cval, 0, 0, 0); ldot = DOT(np->pnorm, ldir); if ((-FTINY <= ldot) & (ldot <= FTINY)) @@ -315,7 +309,7 @@ dir_bsdf( if (ldot > 0 && bright(np->rdiff) > FTINY) { /* - * Compute added diffuse reflected component. + * Compute diffuse reflected component */ copycolor(ctmp, np->rdiff); dtmp = ldot * omega * (1./PI); @@ -324,7 +318,7 @@ dir_bsdf( } if (ldot < 0 && bright(np->tdiff) > FTINY) { /* - * Compute added diffuse transmission. + * Compute diffuse transmission */ copycolor(ctmp, np->tdiff); dtmp = -ldot * omega * (1.0/PI); @@ -334,7 +328,7 @@ dir_bsdf( if (ambRayInPmap(np->pr)) return; /* specular already in photon map */ /* - * Compute specular scattering coefficient using BSDF. + * Compute specular scattering coefficient using BSDF */ if (!direct_specular_OK(ctmp, ldir, omega, np)) return; @@ -361,7 +355,7 @@ dir_brdf( double dtmp; COLOR ctmp, ctmp1, ctmp2; - setcolor(cval, .0, .0, .0); + setcolor(cval, 0, 0, 0); ldot = DOT(np->pnorm, ldir); @@ -370,7 +364,7 @@ dir_brdf( if (bright(np->rdiff) > FTINY) { /* - * Compute added diffuse reflected component. + * Compute diffuse reflected component */ copycolor(ctmp, np->rdiff); dtmp = ldot * omega * (1./PI); @@ -380,7 +374,7 @@ dir_brdf( if (ambRayInPmap(np->pr)) return; /* specular already in photon map */ /* - * Compute specular reflection coefficient using BSDF. + * Compute specular reflection coefficient using BSDF */ if (!direct_specular_OK(ctmp, ldir, omega, np)) return; @@ -403,7 +397,7 @@ dir_btdf( double dtmp; COLOR ctmp; - setcolor(cval, .0, .0, .0); + setcolor(cval, 0, 0, 0); ldot = DOT(np->pnorm, ldir); @@ -412,7 +406,7 @@ dir_btdf( if (bright(np->tdiff) > FTINY) { /* - * Compute added diffuse transmission. + * Compute diffuse transmission */ copycolor(ctmp, np->tdiff); dtmp = -ldot * omega * (1.0/PI); @@ -422,7 +416,7 @@ dir_btdf( if (ambRayInPmap(np->pr)) return; /* specular already in photon map */ /* - * Compute specular scattering coefficient using BSDF. + * Compute specular scattering coefficient using BSDF */ if (!direct_specular_OK(ctmp, ldir, omega, np)) return; @@ -435,14 +429,17 @@ dir_btdf( /* Sample separate BSDF component */ static int -sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usepat) +sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int xmit) { + int hasthru = (xmit && !(ndp->pr->crtype & (SPECULAR|AMBIENT)) + && bright(ndp->cthru) > FTINY); int nstarget = 1; - int nsent; + int nsent = 0; + int n; SDError ec; SDValue bsv; double xrand; - FVECT vsmp; + FVECT vsmp, vinc; RAY sr; /* multiple samples? */ if (specjitter > 1.5) { @@ -450,41 +447,48 @@ sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usep nstarget += !nstarget; } /* run through our samples */ - for (nsent = 0; nsent < nstarget; nsent++) { + for (n = 0; n < nstarget; n++) { if (nstarget == 1) { /* stratify random variable */ xrand = urand(ilhash(dimlist,ndims)+samplendx); if (specjitter < 1.) xrand = .5 + specjitter*(xrand-.5); } else { - xrand = (nsent + frandom())/(double)nstarget; + xrand = (n + frandom())/(double)nstarget; } SDerrorDetail[0] = '\0'; /* sample direction & coef. */ bsdf_jitter(vsmp, ndp, ndp->sr_vpsa[0]); + VCOPY(vinc, vsmp); /* to compare after */ ec = SDsampComponent(&bsv, vsmp, xrand, dcp); if (ec) objerror(ndp->mp, USER, transSDError(ec)); if (bsv.cieY <= FTINY) /* zero component? */ break; - /* map vector to world */ + if (hasthru) { /* check for view ray */ + double dx = vinc[0] + vsmp[0]; + double dy = vinc[1] + vsmp[1]; + if (dx*dx + dy*dy <= ndp->sr_vpsa[0]*ndp->sr_vpsa[0]) + continue; /* exclude view sample */ + } + /* map non-view sample->world */ if (SDmapDir(sr.rdir, ndp->fromloc, vsmp) != SDEnone) break; /* spawn a specular ray */ if (nstarget > 1) bsv.cieY /= (double)nstarget; cvt_sdcolor(sr.rcoef, &bsv); /* use sample color */ - if (usepat) /* apply pattern? */ + if (xmit) /* apply pattern on transmit */ multcolor(sr.rcoef, ndp->pr->pcol); if (rayorigin(&sr, SPECULAR, ndp->pr, sr.rcoef) < 0) { if (maxdepth > 0) break; continue; /* Russian roulette victim */ } - /* need to offset origin? */ - if (ndp->thick != 0 && (ndp->pr->rod > 0) ^ (vsmp[2] > 0)) + if (xmit && ndp->thick != 0) /* need to offset origin? */ VSUM(sr.rorg, sr.rorg, ndp->pr->ron, -ndp->thick); rayvalue(&sr); /* send & evaluate sample */ multcolor(sr.rcol, sr.rcoef); addcolor(ndp->pr->rcol, sr.rcol); + ++nsent; } return(nsent); } @@ -493,45 +497,64 @@ sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usep static int sample_sdf(BSDFDAT *ndp, int sflags) { + int hasthru = (sflags == SDsampSpT + && !(ndp->pr->crtype & (SPECULAR|AMBIENT)) + && bright(ndp->cthru) > FTINY); int n, ntotal = 0; + double b = 0; SDSpectralDF *dfp; COLORV *unsc; if (sflags == SDsampSpT) { - unsc = ndp->tdiff; + unsc = ndp->tunsamp; if (ndp->pr->rod > 0) dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb; else dfp = (ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf; } else /* sflags == SDsampSpR */ { - unsc = ndp->rdiff; + unsc = ndp->runsamp; if (ndp->pr->rod > 0) dfp = ndp->sd->rf; else dfp = ndp->sd->rb; } + setcolor(unsc, 0, 0, 0); if (dfp == NULL) /* no specular component? */ return(0); - /* below sampling threshold? */ - if (dfp->maxHemi <= specthresh+FTINY) { - if (dfp->maxHemi > FTINY) { /* XXX no color from BSDF */ - FVECT vjit; - double d; - COLOR ctmp; - bsdf_jitter(vjit, ndp, ndp->sr_vpsa[1]); - d = SDdirectHemi(vjit, sflags, ndp->sd); + + dimlist[ndims++] = (int)(size_t)ndp->mp; + if (hasthru) { /* separate view sample? */ + RAY tr; + if (rayorigin(&tr, TRANS, ndp->pr, ndp->cthru) == 0) { + VCOPY(tr.rdir, ndp->pr->rdir); + rayvalue(&tr); + multcolor(tr.rcol, tr.rcoef); + addcolor(ndp->pr->rcol, tr.rcol); + ++ntotal; + b = bright(ndp->cthru); + } else + hasthru = 0; + } + ndims--; + if (dfp->maxHemi - b <= FTINY) { /* how specular to sample? */ + b = 0; + } else { + FVECT vjit; + bsdf_jitter(vjit, ndp, ndp->sr_vpsa[1]); + b = SDdirectHemi(vjit, sflags, ndp->sd) - b; + if (b < 0) b = 0; + } + if (b <= specthresh+FTINY) { /* below sampling threshold? */ + if (b > FTINY) { /* XXX no color from BSDF */ if (sflags == SDsampSpT) { - copycolor(ctmp, ndp->pr->pcol); - scalecolor(ctmp, d); + copycolor(unsc, ndp->pr->pcol); + scalecolor(unsc, b); } else /* no pattern on reflection */ - setcolor(ctmp, d, d, d); - addcolor(unsc, ctmp); + setcolor(unsc, b, b, b); } - return(0); + return(ntotal); } - /* else need to sample */ - dimlist[ndims++] = (int)(size_t)ndp->mp; - ndims++; + ndims += 2; /* else sample specular */ for (n = dfp->ncomp; n--; ) { /* loop over components */ dimlist[ndims-1] = n + 9438; ntotal += sample_sdcomp(ndp, &dfp->comp[n], sflags==SDsampSpT); @@ -562,7 +585,7 @@ m_bsdf(OBJREC *m, RAY *r) /* get thickness */ nd.thick = evalue(mf->ep[0]); if ((-FTINY <= nd.thick) & (nd.thick <= FTINY)) - nd.thick = .0; + nd.thick = 0; /* check backface visibility */ if (!hitfront & !backvis) { raytrans(r); @@ -669,23 +692,25 @@ m_bsdf(OBJREC *m, RAY *r) /* sample transmission */ sample_sdf(&nd, SDsampSpT); /* compute indirect diffuse */ - if (bright(nd.rdiff) > FTINY) { /* ambient from reflection */ + copycolor(ctmp, nd.rdiff); + addcolor(ctmp, nd.runsamp); + if (bright(ctmp) > FTINY) { /* ambient from reflection */ if (!hitfront) flipsurface(r); - copycolor(ctmp, nd.rdiff); multambient(ctmp, r, nd.pnorm); addcolor(r->rcol, ctmp); if (!hitfront) flipsurface(r); } - if (bright(nd.tdiff) > FTINY) { /* ambient from other side */ + copycolor(ctmp, nd.tdiff); + addcolor(ctmp, nd.tunsamp); + if (bright(ctmp) > FTINY) { /* ambient from other side */ FVECT bnorm; if (hitfront) flipsurface(r); bnorm[0] = -nd.pnorm[0]; bnorm[1] = -nd.pnorm[1]; bnorm[2] = -nd.pnorm[2]; - copycolor(ctmp, nd.tdiff); if (nd.thick != 0) { /* proxy with offset? */ VCOPY(vtmp, r->rop); VSUM(r->rop, vtmp, r->ron, nd.thick);
