--- ray/src/rt/m_bsdf.c 2011/08/21 22:38:12 2.14 +++ ray/src/rt/m_bsdf.c 2012/03/30 15:08:40 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_bsdf.c,v 2.14 2011/08/21 22:38:12 greg Exp $"; +static const char RCSid[] = "$Id: m_bsdf.c,v 2.18 2012/03/30 15:08:40 greg Exp $"; #endif /* * Shading for materials with BSDFs taken from XML data files @@ -82,10 +82,8 @@ typedef struct { /* Jitter ray sample according to projected solid angle and specjitter */ static void -bsdf_jitter(FVECT vres, BSDFDAT *ndp, int domax) +bsdf_jitter(FVECT vres, BSDFDAT *ndp, double sr_psa) { - double sr_psa = ndp->sr_vpsa[domax]; - VCOPY(vres, ndp->vray); if (specjitter < 1.) sr_psa *= specjitter; @@ -100,10 +98,10 @@ bsdf_jitter(FVECT vres, BSDFDAT *ndp, int domax) static int direct_bsdf_OK(COLOR cval, FVECT ldir, double omega, BSDFDAT *ndp) { - int nsamp = 1, ok = 0; + int nsamp, ok = 0; FVECT vsrc, vsmp, vjit; double tomega; - double sf, sd[2]; + double sf, tsr, sd[2]; COLOR csmp; SDValue sv; SDError ec; @@ -111,27 +109,27 @@ direct_bsdf_OK(COLOR cval, FVECT ldir, double omega, B /* transform source direction */ if (SDmapDir(vsrc, ndp->toloc, ldir) != SDEnone) return(0); + /* assign number of samples */ + ec = SDsizeBSDF(&tomega, ndp->vray, vsrc, SDqueryMin, ndp->sd); + if (ec) + goto baderror; /* check indirect over-counting */ if (ndp->thick != 0 && ndp->pr->crtype & (SPECULAR|AMBIENT) && vsrc[2] > 0 ^ ndp->vray[2] > 0) { double dx = vsrc[0] + ndp->vray[0]; double dy = vsrc[1] + ndp->vray[1]; - if (dx*dx + dy*dy <= omega*(1./PI)) + if (dx*dx + dy*dy <= omega+tomega) return(0); } - if (specjitter > FTINY) { /* assign number of samples */ - ec = SDsizeBSDF(&tomega, ndp->vray, vsrc, SDqueryMin, ndp->sd); - if (ec) - goto baderror; - sf = specjitter * ndp->pr->rweight; - if (tomega <= omega*.01) - nsamp = 100.*sf + .5; - else - nsamp = 4.*sf*omega/tomega + .5; - nsamp += !nsamp; - } - sf = sqrt(omega); + sf = specjitter * ndp->pr->rweight; + if (25.*tomega <= omega) + nsamp = 100.*sf + .5; + else + nsamp = 4.*sf*omega/tomega + .5; + nsamp += !nsamp; setcolor(cval, .0, .0, .0); /* sample our source area */ + sf = sqrt(omega); + tsr = sqrt(tomega); for (i = nsamp; i--; ) { VCOPY(vsmp, vsrc); /* jitter query directions */ if (nsamp > 1) { @@ -143,7 +141,7 @@ direct_bsdf_OK(COLOR cval, FVECT ldir, double omega, B continue; } } - bsdf_jitter(vjit, ndp, 0); + bsdf_jitter(vjit, ndp, tsr); /* compute BSDF */ ec = SDevalBSDF(&sv, vjit, vsmp, ndp->sd); if (ec) @@ -159,6 +157,7 @@ direct_bsdf_OK(COLOR cval, FVECT ldir, double omega, B return(ok); baderror: objerror(ndp->mp, USER, transSDError(ec)); + return(0); /* gratis return */ } /* Compute source contribution for BSDF (reflected & transmitted) */ @@ -333,12 +332,15 @@ sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usep } /* run through our samples */ for (nsent = 0; nsent < nstarget; nsent++) { - if (nstarget == 1) /* stratify random variable */ + if (nstarget == 1) { /* stratify random variable */ xrand = urand(ilhash(dimlist,ndims)+samplendx); - else + if (specjitter < 1.) + xrand = .5 + specjitter*(xrand-.5); + } else { xrand = (nsent + frandom())/(double)nstarget; + } SDerrorDetail[0] = '\0'; /* sample direction & coef. */ - bsdf_jitter(vsmp, ndp, 0); + bsdf_jitter(vsmp, ndp, ndp->sr_vpsa[0]); ec = SDsampComponent(&bsv, vsmp, xrand, dcp); if (ec) objerror(ndp->mp, USER, transSDError(ec)); @@ -399,7 +401,7 @@ sample_sdf(BSDFDAT *ndp, int sflags) FVECT vjit; double d; COLOR ctmp; - bsdf_jitter(vjit, ndp, 1); + bsdf_jitter(vjit, ndp, ndp->sr_vpsa[1]); d = SDdirectHemi(vjit, sflags, ndp->sd); if (sflags == SDsampSpT) { copycolor(ctmp, ndp->pr->pcol); @@ -555,7 +557,7 @@ m_bsdf(OBJREC *m, RAY *r) bnorm[2] = -nd.pnorm[2]; if (nd.thick != 0) { /* proxy with offset? */ VCOPY(vtmp, r->rop); - VSUM(r->rop, vtmp, r->ron, -nd.thick); + VSUM(r->rop, vtmp, r->ron, nd.thick); multambient(ctmp, r, bnorm); VCOPY(r->rop, vtmp); } else
