root/radiance/ray/src/rt/m_bsdf.c
Fri Jun 20 18:05:30 2025 UTC (6 weeks, 5 days ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.76: +5 -5 lines
Diff to previous 2.76 , to selected 2.63
refactor: Changed macros to function type for clarity
Fri Jun 20 17:03:01 2025 UTC (6 weeks, 5 days ago) by greg
Changes since 2.75: +4 -4 lines
Diff to previous 2.75 , to selected 2.63
fix: Avoid array bounds errors in dimlist[] in deep ray trees
Fri Dec 13 19:05:03 2024 UTC (7 months, 3 weeks ago) by greg
Changes since 2.74: +8 -10 lines
Diff to previous 2.74 , to selected 2.63
perf: Minor efficiency improvement for -bv0
Wed Sep 18 19:52:35 2024 UTC (10 months, 2 weeks ago) by greg
Changes since 2.73: +8 -6 lines
Diff to previous 2.73 , to selected 2.63
fix(rtrace,rpict,rvu,rcontrib): David G-M found overestimation bug in BSDF's
Wed Apr 17 16:46:00 2024 UTC (15 months, 2 weeks ago) by greg
Diff to previous 2.72 , to selected 2.63
fix(rtrace,rpict,rvu,rcontrib): Potential divide-by-zero with -lw 0
Fri Apr 5 01:10:26 2024 UTC (16 months ago) by greg
Changes since 2.71: +2 -10 lines
Diff to previous 2.71 , to selected 2.63
fix: Improved tracking of reflected vs. transmitted rays for antimatter
Wed Nov 15 18:02:52 2023 UTC (20 months, 3 weeks ago) by greg
Changes since 2.70: +116 -117 lines
Diff to previous 2.70 , to selected 2.63
Wed Mar 9 00:27:25 2022 UTC (3 years, 5 months ago) by greg
Changes since 2.69: +18 -18 lines
Diff to previous 2.69 , to selected 2.63
perf: Moved up test to avoid some work when not needed
Tue Mar 8 22:27:56 2022 UTC (3 years, 5 months ago) by greg
Changes since 2.68: +18 -8 lines
Diff to previous 2.68 , to selected 2.63
fix(rpict,rvu,rtrace,rcontrib): Eliminated over-counting of diffuse for aBSDF's
Thu Feb 10 16:24:51 2022 UTC (3 years, 5 months ago) by greg
Diff to previous 2.67 , to selected 2.63
perf: Modest improvement in determining when to extract "through" peak
Tue Dec 7 23:49:50 2021 UTC (3 years, 8 months ago) by greg
Changes since 2.66: +3 -3 lines
Diff to previous 2.66 , to selected 2.63
Wed Oct 13 20:03:31 2021 UTC (3 years, 9 months ago) by greg
Changes since 2.65: +20 -39 lines
Diff to previous 2.65 , to selected 2.63
perf: Simplified BSDF sampling, leaving source sampling to -dj option
Fri Aug 27 03:09:27 2021 UTC (3 years, 11 months ago) by greg
Changes since 2.64: +15 -25 lines
Diff to previous 2.64 , to selected 2.63
perf: Undid last change and reduced specular transmission threshold for PE to 0.05%
Wed Aug 25 16:12:21 2021 UTC (3 years, 11 months ago) by greg
Changes since 2.63: +11 -4 lines
Diff to previous 2.63
fix: Improved duplicate sample testing, which improves peak extraction
Revision 2.63 - (view) (download) (annotate) - [selected]
Sat Mar 27 20:08:58 2021 UTC (4 years, 4 months ago) by greg
Changes since 2.62: +5 -5 lines
Diff to previous 2.62
perf: minor optimization on last change
Sat Mar 27 17:50:18 2021 UTC (4 years, 4 months ago) by greg
Changes since 2.61: +11 -5 lines
Diff to previous 2.61 , to selected 2.63
Thu Jul 9 17:32:31 2020 UTC (5 years ago) by greg
Changes since 2.60: +35 -25 lines
Diff to previous 2.60 , to selected 2.63
fix(aBSDF): Improved appearance/accuracy in exclusion zone during peak extraction.
Thanks to David Geisler-Moroder for initial idea, implementation and testing.
Wed Jun 10 16:00:32 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.59: +12 -15 lines
Diff to previous 2.59 , to selected 2.63
Increased number of sampling directions for better peak evaluation
(thanks to David G-M for implementation and testing)
Wed Jun 3 02:27:32 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.58: +5 -4 lines
Diff to previous 2.58 , to selected 2.63
Removed small source sampling bias in direct_specular_OK()
Wed Jun 3 02:08:32 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.57: +66 -35 lines
Diff to previous 2.57 , to selected 2.63
Improved cthru coefficient calculation for aBSDF by summing more inclusive peak
Mon Jun 10 13:56:52 2019 UTC (6 years, 1 month ago) by greg
Diff to previous 2.56 , to selected 2.63
Tue Nov 13 19:58:33 2018 UTC (6 years, 8 months ago) by greg
Changes since 2.55: +2 -1 lines
Diff to previous 2.55 , to selected 2.63
Tue Aug 21 23:31:01 2018 UTC (6 years, 11 months ago) by greg
Changes since 2.54: +6 -2 lines
Diff to previous 2.54 , to selected 2.63
Added balancing calls to SDfreeCache()
Wed Aug 8 04:15:18 2018 UTC (7 years ago) by greg
Changes since 2.53: +1 -2 lines
Diff to previous 2.53 , to selected 2.63
Removed removal of cosine factor, which was actually in error(!)
Thu Aug 2 22:44:35 2018 UTC (7 years ago) by greg
Changes since 2.52: +13 -9 lines
Diff to previous 2.52 , to selected 2.63
Switched to minimum solid angle rather than local SA for over-counting test
Tue Jun 26 14:42:18 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.51: +7 -7 lines
Diff to previous 2.51 , to selected 2.63
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
Mon Jun 25 23:04:06 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.50: +4 -2 lines
Diff to previous 2.50 , to selected 2.63
Fixed bug in direct calculation for BSDF introduced in last change
Mon Jun 25 20:49:10 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.49: +45 -30 lines
Diff to previous 2.49 , to selected 2.63
Sat May 12 02:32:10 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.48: +3 -1 lines
Diff to previous 2.48 , to selected 2.63
Some paranoia to avoid infinite loops
Fri May 11 14:26:24 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.47: +6 -4 lines
Diff to previous 2.47 , to selected 2.63
Avoid loss of specular sampling for low-weight daughter rays
Mon Feb 12 23:20:31 2018 UTC (7 years, 5 months ago) by greg
Changes since 2.46: +7 -7 lines
Diff to previous 2.46 , to selected 2.63
Reverted previous change and added 1.5 fudge factor to avoid over-counting
Mon Feb 12 18:46:29 2018 UTC (7 years, 5 months ago) by greg
Changes since 2.45: +8 -8 lines
Diff to previous 2.45 , to selected 2.63
Fixed issue with under-counting specular
Fri Jan 5 02:47:46 2018 UTC (7 years, 7 months ago) by greg
Changes since 2.44: +3 -3 lines
Diff to previous 2.44 , to selected 2.63
Tweaked peak extraction code to improve results
Sat Dec 2 16:13:04 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.43: +7 -4 lines
Diff to previous 2.43 , to selected 2.63
Made it so weighted average only kicks in for small sources
Fri Dec 1 02:45:14 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.42: +11 -7 lines
Diff to previous 2.42 , to selected 2.63
Added cosine correction for through component and improved accuracy of direct specular component
Tue Nov 28 22:17:00 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.41: +4 -1 lines
Diff to previous 2.41 , to selected 2.63
Fixed occasional issue with zero BSDF regions
Tue Jul 18 21:33:14 2017 UTC (8 years ago) by greg
Changes since 2.40: +14 -14 lines
Diff to previous 2.40 , to selected 2.63
Minor change should not affect behavior
Mon Jul 17 00:14:28 2017 UTC (8 years ago) by greg
Changes since 2.39: +75 -53 lines
Diff to previous 2.39 , to selected 2.63
Implemented view component for BTDFs
Fri Jun 2 18:10:11 2017 UTC (8 years, 2 months ago) by greg
Changes since 2.38: +22 -19 lines
Diff to previous 2.38 , to selected 2.63
Fixed over-counting error introduced in revision 2.31
Fri May 19 15:13:41 2017 UTC (8 years, 2 months ago) by greg
Changes since 2.37: +7 -4 lines
Diff to previous 2.37 , to selected 2.63
Fixed issue with indirect under-estimation in proxied BSDF transmitters
Thu May 18 17:59:37 2017 UTC (8 years, 2 months ago) by greg
Changes since 2.36: +19 -16 lines
Diff to previous 2.36 , to selected 2.63
Further tweak to make sure we never double-count
Tue May 16 20:06:40 2017 UTC (8 years, 2 months ago) by greg
Changes since 2.35: +13 -13 lines
Diff to previous 2.35 , to selected 2.63
Fixed issue with variable-resolution BSDF sampling of direct component
Tue May 16 02:52:15 2017 UTC (8 years, 2 months ago) by greg
Changes since 2.34: +16 -12 lines
Diff to previous 2.34 , to selected 2.63
Fixed comments and changed threshold to 0.7% for "through" shadow testing
Mon May 15 22:50:33 2017 UTC (8 years, 2 months ago) by greg
Changes since 2.33: +108 -13 lines
Diff to previous 2.33 , to selected 2.63
Made shadow testing work through BSDF's with through component (Thanks to David G-M)
Sun Feb 19 17:22:18 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.32: +11 -11 lines
Diff to previous 2.32 , to selected 2.63
Renamed direct sampling routine for clarity
Sat Feb 18 19:12:49 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.31: +44 -8 lines
Diff to previous 2.31 , to selected 2.63
Corrected double-counting of diffuse contributions
Fri Feb 17 23:24:56 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.30: +31 -57 lines
Diff to previous 2.30 , to selected 2.63
Simplified handling of diffuse components
Wed Sep 2 18:59:01 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.29: +8 -1 lines
Diff to previous 2.29 , to selected 2.63
Had to reinstate ambRayInPmap() macro to avoid over-counting bug
Sat Aug 1 23:27:04 2015 UTC (10 years ago) by greg
Diff to previous 2.28 , to selected 2.63
Tue May 26 13:21:07 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.27: +1 -7 lines
Diff to previous 2.27 , to selected 2.63
Removed deprecated ambRayInPmap() macro from code
Tue Feb 24 19:39:26 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.26: +7 -1 lines
Diff to previous 2.26 , to selected 2.63
Sat Jan 25 18:27:39 2014 UTC (11 years, 6 months ago) by greg
Changes since 2.25: +8 -9 lines
Diff to previous 2.25 , to selected 2.63
Wed Jan 22 16:39:57 2014 UTC (11 years, 6 months ago) by greg
Changes since 2.24: +2 -1 lines
Diff to previous 2.24 , to selected 2.63
Added missing call to set function context
Thu Jul 4 15:14:45 2013 UTC (12 years, 1 month ago) by greg
Changes since 2.23: +4 -2 lines
Diff to previous 2.23 , to selected 2.63
Added extra checks where projected solid angle is undefined
Tue Apr 9 16:55:15 2013 UTC (12 years, 4 months ago) by greg
Changes since 2.22: +5 -1 lines
Diff to previous 2.22 , to selected 2.63
Fixed bug for BSDF materials included via octree or mesh instances
Sun Sep 2 15:33:15 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.21: +8 -4 lines
Diff to previous 2.21 , to selected 2.63
Sat Jun 9 07:16:47 2012 UTC (13 years, 2 months ago) by greg
Changes since 2.20: +4 -4 lines
Diff to previous 2.20 , to selected 2.63
Tue Apr 24 15:53:41 2012 UTC (13 years, 3 months ago) by greg
Changes since 2.19: +8 -11 lines
Diff to previous 2.19 , to selected 2.63
Further refinements in error testing/reporting
Tue Apr 24 15:36:40 2012 UTC (13 years, 3 months ago) by greg
Changes since 2.18: +6 -3 lines
Diff to previous 2.18 , to selected 2.63
Improved error reporting for illegal orientation vector
Fri Mar 30 15:08:40 2012 UTC (13 years, 4 months ago) by greg
Diff to previous 2.17 , to selected 2.63
Fixed serious bug in transmitting proxy material ambient sampling
Thu Sep 22 02:15:56 2011 UTC (13 years, 10 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.63
Minor optimizations
Wed Aug 24 04:31:13 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.15: +6 -6 lines
Diff to previous 2.15 , to selected 2.63
Improved oversampling check
Mon Aug 22 16:00:47 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.14: +24 -23 lines
Diff to previous 2.14 , to selected 2.63
Further improved sampling method
Sun Aug 21 22:38:12 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.13: +14 -13 lines
Diff to previous 2.13 , to selected 2.63
Minor improvements to direct specular sampling
Sun Aug 21 21:24:30 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.12: +54 -32 lines
Diff to previous 2.12 , to selected 2.63
Vastly improved direct specular sampling
Sun Aug 21 16:55:29 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.11: +7 -7 lines
Diff to previous 2.11 , to selected 2.63
Minor fix to through component calculation
Wed Jun 8 15:37:46 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.10: +16 -21 lines
Diff to previous 2.10 , to selected 2.63
Stratified specular sampling with -ss > 1
Sun Apr 24 19:39:21 2011 UTC (14 years, 3 months ago) by greg
Diff to previous 2.9 , to selected 2.63
Partial implementation of variable-resolution BSDFs
Tue Apr 19 21:31:22 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.8: +39 -28 lines
Diff to previous 2.8 , to selected 2.63
Fixed interface for determining BSDF solid angles
Wed Apr 6 00:14:26 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 2.7 , to selected 2.63
Improved output efficiency by reducing number of calls to fwrite()
Tue Feb 22 05:41:02 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.6: +39 -43 lines
Diff to previous 2.6 , to selected 2.63
Fixed problem with double-counting through component in indirect
Sun Feb 20 17:43:43 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.5: +12 -10 lines
Diff to previous 2.5 , to selected 2.63
Fixed bug in source sampling for proxies
Sun Feb 20 06:34:19 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.4: +171 -41 lines
Diff to previous 2.4 , to selected 2.63
Made BSDF proxy behavior consistent for shadowing, reflection and transmission
Sat Feb 19 23:42:09 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.3: +53 -19 lines
Diff to previous 2.3 , to selected 2.63
Fixes to BSDF including blurring of angle boundaries
Sat Feb 19 01:48:59 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.2: +15 -18 lines
Diff to previous 2.2 , to selected 2.63
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 02:41:55 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.1: +6 -31 lines
Diff to previous 2.1 , to selected 2.63
Minor fixes and adjustments
Fri Feb 18 00:40:25 2011 UTC (14 years, 5 months ago) by greg
Diff to selected 2.63
