root/Development/ray/src/rt/m_bsdf.c
Revision: 2.70
Committed: Wed Mar 9 00:27:25 2022 UTC (3 years, 9 months ago) by greg
Changes since 2.69: +18 -18 lines
perf: Moved up test to avoid some work when not needed
2 static const char RCSid[] = "$Id: m_bsdf.c,v 2.69 2022/03/08 22:27:56 greg Exp $";
5 * Shading for materials with BSDFs taken from XML data files
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "ambient.h"
13 #include "source.h"
14 #include "func.h"
15 #include "bsdf.h"
16 #include "random.h"
17 #include "pmapmat.h"
18
19 /*
20 * Arguments to this material include optional diffuse colors.
21 * String arguments include the BSDF and function files.
22 * For the MAT_BSDF type, a non-zero thickness causes the useful behavior
23 * of translating transmitted rays this distance beneath the surface
24 * (opposite the surface normal) to bypass any intervening geometry.
25 * Translation only affects scattered, non-source-directed samples.
26 * A non-zero thickness has the further side-effect that an unscattered
27 * (view) ray will pass right through our material, making the BSDF
28 * surface invisible and showing the proxied geometry instead. Thickness
29 * has the further effect of turning off reflection on the reverse side so
30 * rays heading in the opposite direction pass unimpeded through the BSDF
31 * surface. A paired surface may be placed on the opposide side of
32 * the detail geometry, less than this thickness away, if a two-way
33 * proxy is desired. Note that the sign of the thickness is important.
34 * A positive thickness hides geometry behind the BSDF surface and uses
35 * front reflectance and transmission properties. A negative thickness
36 * hides geometry in front of the surface when rays hit from behind,
37 * and applies only the transmission and backside reflectance properties.
38 * Reflection is ignored on the hidden side, as those rays pass through.
39 * For the MAT_ABSDF type, we check for a strong "through" component.
40 * Such a component will cause direct rays to pass through unscattered.
41 * A separate test prevents over-counting by dropping samples that are
42 * too close to this "through" direction. BSDFs with such a through direction
43 * will also have a view component, meaning they are somewhat see-through.
44 * A MAT_BSDF type with zero thickness behaves the same as a MAT_ABSDF
45 * type with no strong through component.
46 * The "up" vector for the BSDF is given by three variables, defined
47 * (along with the thickness) by the named function file, or '.' if none.
48 * Together with the surface normal, this defines the local coordinate
49 * system for the BSDF.
50 * We do not reorient the surface, so if the BSDF has no back-side
51 * reflectance and none is given in the real arguments, a BSDF surface
52 * with zero thickness will appear black when viewed from behind
53 * unless backface visibility is on, when it becomes invisible.
54 * The diffuse arguments are added to components in the BSDF file,
55 * not multiplied. However, patterns affect this material as a multiplier
56 * on everything except non-diffuse reflection.
57 *
58 * Arguments for MAT_ABSDF are:
59 * 5+ BSDFfile ux uy uz funcfile transform
60 * 0
61 * 0|3|6|9 rdf gdf bdf
62 * rdb gdb bdb
63 * rdt gdt bdt
64 *
65 * Arguments for MAT_BSDF are:
66 * 6+ thick BSDFfile ux uy uz funcfile transform
67 * 0
68 * 0|3|6|9 rdf gdf bdf
69 * rdb gdb bdb
70 * rdt gdt bdt
71 */
72
73 /*
74 * Note that our reverse ray-tracing process means that the positions
75 * of incoming and outgoing vectors may be reversed in our calls
76 * to the BSDF library. This is usually fine, since the bidirectional nature
77 * of the BSDF (that's what the 'B' stands for) means it all works out.
78 */
79
80 typedef struct {
81 OBJREC *mp; /* material pointer */
82 RAY *pr; /* intersected ray */
83 FVECT pnorm; /* perturbed surface normal */
84 FVECT vray; /* local outgoing (return) vector */
85 double sr_vpsa[2]; /* sqrt of BSDF projected solid angle extrema */
86 RREAL toloc[3][3]; /* world to local BSDF coords */
87 RREAL fromloc[3][3]; /* local BSDF coords to world */
88 double thick; /* surface thickness */
89 COLOR cthru; /* "through" component for MAT_ABSDF */
90 COLOR cthru_surr; /* surround for "through" component */
91 SDData *sd; /* loaded BSDF data */
92 COLOR rdiff; /* diffuse reflection */
93 COLOR runsamp; /* BSDF hemispherical reflection */
94 COLOR tdiff; /* diffuse transmission */
95 COLOR tunsamp; /* BSDF hemispherical transmission */
96 } BSDFDAT; /* BSDF material data */
97
98 #define cvt_sdcolor(cv, svp) ccy2rgb(&(svp)->spec, (svp)->cieY, cv)
99
100 typedef struct {
101 double vy; /* brightness (for sorting) */
102 FVECT tdir; /* through sample direction (normalized) */
103 COLOR vcol; /* BTDF color */
104 } PEAKSAMP; /* BTDF peak sample */
105
106 /* Comparison function to put near-peak values in descending order */
107 static int
108 cmp_psamp(const void *p1, const void *p2)
109 {
110 double diff = (*(const PEAKSAMP *)p1).vy - (*(const PEAKSAMP *)p2).vy;
111 if (diff > 0) return(-1);
112 if (diff < 0) return(1);
113 return(0);
114 }
115
116 /* Compute "through" component color for MAT_ABSDF */
117 static void
118 compute_through(BSDFDAT *ndp)
119 {
120 #define NDIR2CHECK 29
121 static const float dir2check[NDIR2CHECK][2] = {
122 {0, 0}, {-0.6, 0}, {0, 0.6},
123 {0, -0.6}, {0.6, 0}, {-0.6, 0.6},
124 {-0.6, -0.6}, {0.6, 0.6}, {0.6, -0.6},
125 {-1.2, 0}, {0, 1.2}, {0, -1.2},
126 {1.2, 0}, {-1.2, 1.2}, {-1.2, -1.2},
127 {1.2, 1.2}, {1.2, -1.2}, {-1.8, 0},
128 {0, 1.8}, {0, -1.8}, {1.8, 0},
129 {-1.8, 1.8}, {-1.8, -1.8}, {1.8, 1.8},
130 {1.8, -1.8}, {-2.4, 0}, {0, 2.4},
131 {0, -2.4}, {2.4, 0},
132 };
133 PEAKSAMP psamp[NDIR2CHECK];
134 SDSpectralDF *dfp;
135 FVECT pdir;
136 double tomega, srchrad;
137 double tomsum, tomsurr;
138 COLOR vpeak, vsurr, btdiff;
139 double vypeak;
140 int i, ns;
141 SDError ec;
142
143 if (ndp->pr->rod > 0)
144 dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb;
145 else
146 dfp = (ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf;
147
148 if (dfp == NULL)
149 return; /* no specular transmission */
150 if (bright(ndp->pr->pcol) <= FTINY)
151 return; /* pattern is black, here */
152 srchrad = sqrt(dfp->minProjSA); /* else evaluate peak */
153 for (i = 0; i < NDIR2CHECK; i++) {
154 SDValue sv;
155 psamp[i].tdir[0] = -ndp->vray[0] + dir2check[i][0]*srchrad;
156 psamp[i].tdir[1] = -ndp->vray[1] + dir2check[i][1]*srchrad;
157 psamp[i].tdir[2] = -ndp->vray[2];
158 normalize(psamp[i].tdir);
159 ec = SDevalBSDF(&sv, ndp->vray, psamp[i].tdir, ndp->sd);
160 if (ec)
161 goto baderror;
162 cvt_sdcolor(psamp[i].vcol, &sv);
163 psamp[i].vy = sv.cieY;
164 }
165 qsort(psamp, NDIR2CHECK, sizeof(PEAKSAMP), cmp_psamp);
166 if (psamp[0].vy <= FTINY)
167 return; /* zero BTDF here */
168 setcolor(vpeak, 0, 0, 0);
169 setcolor(vsurr, 0, 0, 0);
170 vypeak = tomsum = tomsurr = 0; /* combine top unique values */
171 ns = 0;
172 for (i = 0; i < NDIR2CHECK; i++) {
173 if (i && psamp[i].vy == psamp[i-1].vy)
174 continue; /* assume duplicate sample */
175
176 ec = SDsizeBSDF(&tomega, ndp->vray, psamp[i].tdir,
177 SDqueryMin, ndp->sd);
178 if (ec)
179 goto baderror;
180
181 scalecolor(psamp[i].vcol, tomega);
182 /* not part of peak? */
183 if (tomega > 1.5*dfp->minProjSA ||
184 vypeak > 8.*psamp[i].vy*ns) {
185 if (!i) return; /* abort */
186 addcolor(vsurr, psamp[i].vcol);
187 tomsurr += tomega;
188 continue;
189 }
190 addcolor(vpeak, psamp[i].vcol);
191 tomsum += tomega;
192 vypeak += psamp[i].vy;
193 ++ns;
194 }
195 if (tomsurr < 0.2*tomsum) /* insufficient surround? */
196 return;
197 scalecolor(vsurr, 1./tomsurr); /* surround is avg. BTDF */
198 if (ndp->vray[2] > 0) /* get diffuse BTDF */
199 cvt_sdcolor(btdiff, &ndp->sd->tLambFront);
200 else
201 cvt_sdcolor(btdiff, &ndp->sd->tLambBack);
202 scalecolor(btdiff, (1./PI));
203 for (i = 3; i--; ) { /* remove diffuse contrib. */
204 if ((colval(vpeak,i) -= tomsum*colval(btdiff,i)) < 0)
205 colval(vpeak,i) = 0;
206 if ((colval(vsurr,i) -= colval(btdiff,i)) < 0)
207 colval(vsurr,i) = 0;
208 }
209 if (bright(vpeak) < .0005) /* < 0.05% specular? */
210 return;
211 multcolor(vsurr, ndp->pr->pcol); /* modify by color */
212 multcolor(vpeak, ndp->pr->pcol);
213 copycolor(ndp->cthru, vpeak);
214 copycolor(ndp->cthru_surr, vsurr);
215 return;
216 baderror:
217 objerror(ndp->mp, USER, transSDError(ec));
218 #undef NDIR2CHECK
219 }
220
221 /* Jitter ray sample according to projected solid angle and specjitter */
222 static void
223 bsdf_jitter(FVECT vres, BSDFDAT *ndp, double sr_psa)
224 {
225 VCOPY(vres, ndp->vray);
226 if (specjitter < 1.)
227 sr_psa *= specjitter;
228 if (sr_psa <= FTINY)
229 return;
230 vres[0] += sr_psa*(.5 - frandom());
231 vres[1] += sr_psa*(.5 - frandom());
232 normalize(vres);
233 }
234
235 /* Get BSDF specular for direct component, returning true if OK to proceed */
236 static int
237 direct_specular_OK(COLOR cval, FVECT ldir, double omega, BSDFDAT *ndp)
238 {
239 int nsamp = 1;
240 int scnt = 0;
241 FVECT vsrc, vjit;
242 double tomega, tomega2;
243 double sf, tsr, sd[2];
244 COLOR csmp, cdiff;
245 double diffY;
246 SDValue sv;
247 SDError ec;
248 int i;
249 /* in case we fail */
250 setcolor(cval, 0, 0, 0);
251 /* transform source direction */
252 if (SDmapDir(vsrc, ndp->toloc, ldir) != SDEnone)
253 return(0);
254 /* check indirect over-counting */
255 if ((vsrc[2] > 0) ^ (ndp->vray[2] > 0) && bright(ndp->cthru) > FTINY) {
256 double dx = vsrc[0] + ndp->vray[0];
257 double dy = vsrc[1] + ndp->vray[1];
258 SDSpectralDF *dfp = (ndp->pr->rod > 0) ?
259 ((ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb) :
260 ((ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf) ;
261
262 tomega = omega*fabs(vsrc[2]);
263 if (dx*dx + dy*dy <= (2.5*4./PI)*(tomega + dfp->minProjSA +
264 2.*sqrt(tomega*dfp->minProjSA))) {
265 if (bright(ndp->cthru_surr) <= FTINY)
266 return(0);
267 copycolor(cval, ndp->cthru_surr);
268 return(1); /* return non-zero surround BTDF */
269 }
270 }
271 /* will discount diffuse portion */
272 switch ((vsrc[2] > 0)<<1 | (ndp->vray[2] > 0)) {
273 case 3:
274 if (ndp->sd->rf == NULL)
275 return(0); /* all diffuse */
276 sv = ndp->sd->rLambFront;
277 break;
278 case 0:
279 if (ndp->sd->rb == NULL)
280 return(0); /* all diffuse */
281 sv = ndp->sd->rLambBack;
282 break;
283 case 1:
284 if ((ndp->sd->tf == NULL) & (ndp->sd->tb == NULL))
285 return(0); /* all diffuse */
286 sv = ndp->sd->tLambFront;
287 break;
288 case 2:
289 if ((ndp->sd->tf == NULL) & (ndp->sd->tb == NULL))
290 return(0); /* all diffuse */
291 sv = ndp->sd->tLambBack;
292 break;
293 }
294 if (sv.cieY > FTINY) {
295 diffY = sv.cieY *= 1./PI;
296 cvt_sdcolor(cdiff, &sv);
297 } else {
298 diffY = 0;
299 setcolor(cdiff, 0, 0, 0);
300 }
301 ec = SDsizeBSDF(&tomega, ndp->vray, vsrc, SDqueryMin, ndp->sd);
302 if (ec)
303 goto baderror;
304 /* check if sampling BSDF */
305 if ((tsr = sqrt(tomega)) > 0) {
306 nsamp = 4.*specjitter*ndp->pr->rweight + .5;
307 nsamp += !nsamp;
308 }
309 /* jitter to fuzz BSDF cells */
310 for (i = nsamp; i--; ) {
311 bsdf_jitter(vjit, ndp, tsr);
312 /* compute BSDF */
313 ec = SDevalBSDF(&sv, vjit, vsrc, ndp->sd);
314 if (ec)
315 goto baderror;
316 if (sv.cieY - diffY <= FTINY)
317 continue; /* no specular part */
318 /* check for variable resolution */
319 ec = SDsizeBSDF(&tomega2, vjit, vsrc, SDqueryMin, ndp->sd);
320 if (ec)
321 goto baderror;
322 if (tomega2 < .12*tomega)
323 continue; /* not safe to include */
324 cvt_sdcolor(csmp, &sv);
325 addcolor(cval, csmp);
326 ++scnt;
327 }
328 if (!scnt) /* no valid specular samples? */
329 return(0);
330
331 sf = 1./scnt; /* weighted average BSDF */
332 scalecolor(cval, sf);
333 /* subtract diffuse contribution */
334 for (i = 3*(diffY > FTINY); i--; )
335 if ((colval(cval,i) -= colval(cdiff,i)) < 0)
336 colval(cval,i) = 0;
337 return(1);
338 baderror:
339 objerror(ndp->mp, USER, transSDError(ec));
340 return(0); /* gratis return */
341 }
342
343 /* Compute source contribution for BSDF (reflected & transmitted) */
344 static void
345 dir_bsdf(
346 COLOR cval, /* returned coefficient */
347 void *nnp, /* material data */
348 FVECT ldir, /* light source direction */
349 double omega /* light source size */
350 )
351 {
352 BSDFDAT *np = (BSDFDAT *)nnp;
353 double ldot;
354 double dtmp;
355 COLOR ctmp;
356
357 setcolor(cval, 0, 0, 0);
358
359 ldot = DOT(np->pnorm, ldir);
360 if ((-FTINY <= ldot) & (ldot <= FTINY))
361 return;
362
363 if (ldot > 0 && bright(np->rdiff) > FTINY) {
364 /*
365 * Compute diffuse reflected component
366 */
367 copycolor(ctmp, np->rdiff);
368 dtmp = ldot * omega * (1./PI);
369 scalecolor(ctmp, dtmp);
370 addcolor(cval, ctmp);
371 }
372 if (ldot < 0 && bright(np->tdiff) > FTINY) {
373 /*
374 * Compute diffuse transmission
375 */
376 copycolor(ctmp, np->tdiff);
377 dtmp = -ldot * omega * (1./PI);
378 scalecolor(ctmp, dtmp);
379 addcolor(cval, ctmp);
380 }
381 if (ambRayInPmap(np->pr))
382 return; /* specular already in photon map */
383 /*
384 * Compute specular scattering coefficient using BSDF
385 */
386 if (!direct_specular_OK(ctmp, ldir, omega, np))
387 return;
388 if (ldot < 0) { /* pattern for specular transmission */
389 multcolor(ctmp, np->pr->pcol);
390 dtmp = -ldot * omega;
391 } else
392 dtmp = ldot * omega;
393 scalecolor(ctmp, dtmp);
394 addcolor(cval, ctmp);
395 }
396
397 /* Compute source contribution for BSDF (reflected only) */
398 static void
399 dir_brdf(
400 COLOR cval, /* returned coefficient */
401 void *nnp, /* material data */
402 FVECT ldir, /* light source direction */
403 double omega /* light source size */
404 )
405 {
406 BSDFDAT *np = (BSDFDAT *)nnp;
407 double ldot;
408 double dtmp;
409 COLOR ctmp, ctmp1, ctmp2;
410
411 setcolor(cval, 0, 0, 0);
412
413 ldot = DOT(np->pnorm, ldir);
414
415 if (ldot <= FTINY)
416 return;
417
418 if (bright(np->rdiff) > FTINY) {
419 /*
420 * Compute diffuse reflected component
421 */
422 copycolor(ctmp, np->rdiff);
423 dtmp = ldot * omega * (1./PI);
424 scalecolor(ctmp, dtmp);
425 addcolor(cval, ctmp);
426 }
427 if (ambRayInPmap(np->pr))
428 return; /* specular already in photon map */
429 /*
430 * Compute specular reflection coefficient using BSDF
431 */
432 if (!direct_specular_OK(ctmp, ldir, omega, np))
433 return;
434 dtmp = ldot * omega;
435 scalecolor(ctmp, dtmp);
436 addcolor(cval, ctmp);
437 }
438
439 /* Compute source contribution for BSDF (transmitted only) */
440 static void
441 dir_btdf(
442 COLOR cval, /* returned coefficient */
443 void *nnp, /* material data */
444 FVECT ldir, /* light source direction */
445 double omega /* light source size */
446 )
447 {
448 BSDFDAT *np = (BSDFDAT *)nnp;
449 double ldot;
450 double dtmp;
451 COLOR ctmp;
452
453 setcolor(cval, 0, 0, 0);
454
455 ldot = DOT(np->pnorm, ldir);
456
457 if (ldot >= -FTINY)
458 return;
459
460 if (bright(np->tdiff) > FTINY) {
461 /*
462 * Compute diffuse transmission
463 */
464 copycolor(ctmp, np->tdiff);
465 dtmp = -ldot * omega * (1./PI);
466 scalecolor(ctmp, dtmp);
467 addcolor(cval, ctmp);
468 }
469 if (ambRayInPmap(np->pr))
470 return; /* specular already in photon map */
471 /*
472 * Compute specular scattering coefficient using BSDF
473 */
474 if (!direct_specular_OK(ctmp, ldir, omega, np))
475 return;
476 /* full pattern on transmission */
477 multcolor(ctmp, np->pr->pcol);
478 dtmp = -ldot * omega;
479 scalecolor(ctmp, dtmp);
480 addcolor(cval, ctmp);
481 }
482
483 /* Sample separate BSDF component */
484 static int
485 sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int xmit)
486 {
487 const int hasthru = (xmit &&
488 !(ndp->pr->crtype & (SPECULAR|AMBIENT))
489 && bright(ndp->cthru) > FTINY);
490 int nstarget = 1;
491 int nsent = 0;
492 int n;
493 SDError ec;
494 SDValue bsv;
495 double xrand;
496 FVECT vsmp, vinc;
497 RAY sr;
498 /* multiple samples? */
499 if (specjitter > 1.5) {
500 nstarget = specjitter*ndp->pr->rweight + .5;
501 nstarget += !nstarget;
502 }
503 /* run through our samples */
504 for (n = 0; n < nstarget; n++) {
505 if (nstarget == 1) { /* stratify random variable */
506 xrand = urand(ilhash(dimlist,ndims)+samplendx);
507 if (specjitter < 1.)
508 xrand = .5 + specjitter*(xrand-.5);
509 } else {
510 xrand = (n + frandom())/(double)nstarget;
511 }
512 SDerrorDetail[0] = '\0'; /* sample direction & coef. */
513 bsdf_jitter(vsmp, ndp, ndp->sr_vpsa[0]);
514 VCOPY(vinc, vsmp); /* to compare after */
515 ec = SDsampComponent(&bsv, vsmp, xrand, dcp);
516 if (ec)
517 objerror(ndp->mp, USER, transSDError(ec));
518 if (bsv.cieY <= FTINY) /* zero component? */
519 break;
520 if (hasthru) { /* check for view ray */
521 double dx = vinc[0] + vsmp[0];
522 double dy = vinc[1] + vsmp[1];
523 if (dx*dx + dy*dy <= ndp->sr_vpsa[0]*ndp->sr_vpsa[0])
524 continue; /* exclude view sample */
525 }
526 /* map non-view sample->world */
527 if (SDmapDir(sr.rdir, ndp->fromloc, vsmp) != SDEnone)
528 break;
529 /* spawn a specular ray */
530 if (nstarget > 1)
531 bsv.cieY /= (double)nstarget;
532 cvt_sdcolor(sr.rcoef, &bsv); /* use sample color */
533 if (xmit) /* apply pattern on transmit */
534 multcolor(sr.rcoef, ndp->pr->pcol);
535 if (rayorigin(&sr, SPECULAR, ndp->pr, sr.rcoef) < 0) {
536 if (!n & (nstarget > 1)) {
537 n = nstarget; /* avoid infinitue loop */
538 nstarget = nstarget*sr.rweight/minweight;
539 if (n == nstarget) break;
540 n = -1; /* moved target */
541 }
542 continue; /* try again */
543 }
544 if (xmit && ndp->thick != 0) /* need to offset origin? */
545 VSUM(sr.rorg, sr.rorg, ndp->pr->ron, -ndp->thick);
546 rayvalue(&sr); /* send & evaluate sample */
547 multcolor(sr.rcol, sr.rcoef);
548 addcolor(ndp->pr->rcol, sr.rcol);
549 ++nsent;
550 }
551 return(nsent);
552 }
553
554 /* Sample non-diffuse components of BSDF */
555 static int
556 sample_sdf(BSDFDAT *ndp, int sflags)
557 {
558 int hasthru = (sflags == SDsampSpT &&
559 !(ndp->pr->crtype & (SPECULAR|AMBIENT))
560 && bright(ndp->cthru) > FTINY);
561 int n, ntotal = 0;
562 double b = 0;
563 SDSpectralDF *dfp;
564 COLORV *unsc;
565
566 if (sflags == SDsampSpT) {
567 unsc = ndp->tunsamp;
568 if (ndp->pr->rod > 0)
569 dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb;
570 else
571 dfp = (ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf;
572 } else /* sflags == SDsampSpR */ {
573 unsc = ndp->runsamp;
574 if (ndp->pr->rod > 0)
575 dfp = ndp->sd->rf;
576 else
577 dfp = ndp->sd->rb;
578 }
579 setcolor(unsc, 0, 0, 0);
580 if (dfp == NULL) /* no specular component? */
581 return(0);
582
583 if (hasthru) { /* separate view sample? */
584 RAY tr;
585 if (rayorigin(&tr, TRANS, ndp->pr, ndp->cthru) == 0) {
586 VCOPY(tr.rdir, ndp->pr->rdir);
587 rayvalue(&tr);
588 multcolor(tr.rcol, tr.rcoef);
589 addcolor(ndp->pr->rcol, tr.rcol);
590 ndp->pr->rxt = ndp->pr->rot + raydistance(&tr);
591 ++ntotal;
592 b = bright(ndp->cthru);
593 } else
594 hasthru = 0;
595 }
596 if (dfp->maxHemi - b <= FTINY) { /* have specular to sample? */
597 b = 0;
598 } else {
599 FVECT vjit;
600 bsdf_jitter(vjit, ndp, ndp->sr_vpsa[1]);
601 b = SDdirectHemi(vjit, sflags, ndp->sd) - b;
602 if (b < 0) b = 0;
603 }
604 if (b <= specthresh+FTINY) { /* below sampling threshold? */
605 if (b > FTINY) { /* XXX no color from BSDF */
606 if (sflags == SDsampSpT) {
607 copycolor(unsc, ndp->pr->pcol);
608 scalecolor(unsc, b);
609 } else /* no pattern on reflection */
610 setcolor(unsc, b, b, b);
611 }
612 return(ntotal);
613 }
614 dimlist[ndims] = (int)(size_t)ndp->mp; /* else sample specular */
615 ndims += 2;
616 for (n = dfp->ncomp; n--; ) { /* loop over components */
617 dimlist[ndims-1] = n + 9438;
618 ntotal += sample_sdcomp(ndp, &dfp->comp[n], sflags==SDsampSpT);
619 }
620 ndims -= 2;
621 return(ntotal);
622 }
623
624 /* Color a ray that hit a BSDF material */
625 int
626 m_bsdf(OBJREC *m, RAY *r)
627 {
628 int hasthick = (m->otype == MAT_BSDF);
629 int hitfront;
630 COLOR ctmp;
631 SDError ec;
632 FVECT upvec, vtmp;
633 MFUNC *mf;
634 BSDFDAT nd;
635 /* check arguments */
636 if ((m->oargs.nsargs < hasthick+5) | (m->oargs.nfargs > 9) |
637 (m->oargs.nfargs % 3))
638 objerror(m, USER, "bad # arguments");
639 /* record surface struck */
640 hitfront = (r->rod > 0);
641 /* load cal file */
642 mf = hasthick ? getfunc(m, 5, 0x1d, 1)
643 : getfunc(m, 4, 0xe, 1) ;
644 setfunc(m, r);
645 nd.thick = 0; /* set thickness */
646 if (hasthick) {
647 nd.thick = evalue(mf->ep[0]);
648 if ((-FTINY <= nd.thick) & (nd.thick <= FTINY))
649 nd.thick = 0;
650 }
651 /* check backface visibility */
652 if (!hitfront & !backvis) {
653 raytrans(r);
654 return(1);
655 }
656 /* check other rays to pass */
657 if (nd.thick != 0 && (r->crtype & SHADOW ||
658 !(r->crtype & (SPECULAR|AMBIENT)) ||
659 (nd.thick > 0) ^ hitfront)) {
660 raytrans(r); /* hide our proxy */
661 return(1);
662 }
663 if (hasthick && r->crtype & SHADOW) /* early shadow check #1 */
664 return(1);
665 nd.mp = m;
666 nd.pr = r;
667 /* get BSDF data */
668 nd.sd = loadBSDF(m->oargs.sarg[hasthick]);
669 /* early shadow check #2 */
670 if (r->crtype & SHADOW && (nd.sd->tf == NULL) & (nd.sd->tb == NULL)) {
671 SDfreeCache(nd.sd);
672 return(1);
673 }
674 /* diffuse components */
675 if (hitfront) {
676 cvt_sdcolor(nd.rdiff, &nd.sd->rLambFront);
677 if (m->oargs.nfargs >= 3) {
678 setcolor(ctmp, m->oargs.farg[0],
679 m->oargs.farg[1],
680 m->oargs.farg[2]);
681 addcolor(nd.rdiff, ctmp);
682 }
683 cvt_sdcolor(nd.tdiff, &nd.sd->tLambFront);
684 } else {
685 cvt_sdcolor(nd.rdiff, &nd.sd->rLambBack);
686 if (m->oargs.nfargs >= 6) {
687 setcolor(ctmp, m->oargs.farg[3],
688 m->oargs.farg[4],
689 m->oargs.farg[5]);
690 addcolor(nd.rdiff, ctmp);
691 }
692 cvt_sdcolor(nd.tdiff, &nd.sd->tLambBack);
693 }
694 if (m->oargs.nfargs >= 9) { /* add diffuse transmittance? */
695 setcolor(ctmp, m->oargs.farg[6],
696 m->oargs.farg[7],
697 m->oargs.farg[8]);
698 addcolor(nd.tdiff, ctmp);
699 }
700 /* get modifiers */
701 raytexture(r, m->omod);
702 /* modify diffuse values */
703 multcolor(nd.rdiff, r->pcol);
704 multcolor(nd.tdiff, r->pcol);
705 /* get up vector */
706 upvec[0] = evalue(mf->ep[hasthick+0]);
707 upvec[1] = evalue(mf->ep[hasthick+1]);
708 upvec[2] = evalue(mf->ep[hasthick+2]);
709 /* return to world coords */
710 if (mf->fxp != &unitxf) {
711 multv3(upvec, upvec, mf->fxp->xfm);
712 nd.thick *= mf->fxp->sca;
713 }
714 if (r->rox != NULL) {
715 multv3(upvec, upvec, r->rox->f.xfm);
716 nd.thick *= r->rox->f.sca;
717 }
718 raynormal(nd.pnorm, r);
719 /* compute local BSDF xform */
720 ec = SDcompXform(nd.toloc, nd.pnorm, upvec);
721 if (!ec) {
722 nd.vray[0] = -r->rdir[0];
723 nd.vray[1] = -r->rdir[1];
724 nd.vray[2] = -r->rdir[2];
725 ec = SDmapDir(nd.vray, nd.toloc, nd.vray);
726 }
727 if (ec) {
728 objerror(m, WARNING, "Illegal orientation vector");
729 SDfreeCache(nd.sd);
730 return(1);
731 }
732 setcolor(nd.cthru, 0, 0, 0); /* consider through component */
733 setcolor(nd.cthru_surr, 0, 0, 0);
734 if (m->otype == MAT_ABSDF) {
735 compute_through(&nd);
736 if (r->crtype & SHADOW) {
737 RAY tr; /* attempt to pass shadow ray */
738 SDfreeCache(nd.sd);
739 if (rayorigin(&tr, TRANS, r, nd.cthru) < 0)
740 return(1); /* no through component */
741 VCOPY(tr.rdir, r->rdir);
742 rayvalue(&tr); /* transmit with scaling */
743 multcolor(tr.rcol, tr.rcoef);
744 copycolor(r->rcol, tr.rcol);
745 return(1); /* we're done */
746 }
747 }
748 ec = SDinvXform(nd.fromloc, nd.toloc);
749 if (!ec) /* determine BSDF resolution */
750 ec = SDsizeBSDF(nd.sr_vpsa, nd.vray, NULL,
751 SDqueryMin+SDqueryMax, nd.sd);
752 if (ec)
753 objerror(m, USER, transSDError(ec));
754
755 nd.sr_vpsa[0] = sqrt(nd.sr_vpsa[0]);
756 nd.sr_vpsa[1] = sqrt(nd.sr_vpsa[1]);
757 if (!hitfront) { /* perturb normal towards hit */
758 nd.pnorm[0] = -nd.pnorm[0];
759 nd.pnorm[1] = -nd.pnorm[1];
760 nd.pnorm[2] = -nd.pnorm[2];
761 }
762 /* sample reflection */
763 sample_sdf(&nd, SDsampSpR);
764 /* sample transmission */
765 sample_sdf(&nd, SDsampSpT);
766 /* compute indirect diffuse */
767 copycolor(ctmp, nd.rdiff);
768 addcolor(ctmp, nd.runsamp);
769 if (bright(ctmp) > FTINY) { /* ambient from reflection */
770 if (!hitfront)
771 flipsurface(r);
772 multambient(ctmp, r, nd.pnorm);
773 addcolor(r->rcol, ctmp);
774 if (!hitfront)
775 flipsurface(r);
776 }
777 copycolor(ctmp, nd.tdiff);
778 addcolor(ctmp, nd.tunsamp);
779 if (bright(ctmp) > FTINY) { /* ambient from other side */
780 FVECT bnorm;
781 if (hitfront)
782 flipsurface(r);
783 bnorm[0] = -nd.pnorm[0];
784 bnorm[1] = -nd.pnorm[1];
785 bnorm[2] = -nd.pnorm[2];
786 if (nd.thick != 0) { /* proxy with offset? */
787 VCOPY(vtmp, r->rop);
788 VSUM(r->rop, vtmp, r->ron, nd.thick);
789 multambient(ctmp, r, bnorm);
790 VCOPY(r->rop, vtmp);
791 } else
792 multambient(ctmp, r, bnorm);
793 addcolor(r->rcol, ctmp);
794 if (hitfront)
795 flipsurface(r);
796 }
797 /* add direct component */
798 if ((bright(nd.tdiff) <= FTINY) & (nd.sd->tf == NULL) &
799 (nd.sd->tb == NULL)) {
800 direct(r, dir_brdf, &nd); /* reflection only */
801 } else if (nd.thick == 0) {
802 direct(r, dir_bsdf, &nd); /* thin surface scattering */
803 } else {
804 direct(r, dir_brdf, &nd); /* reflection first */
805 VCOPY(vtmp, r->rop); /* offset for transmitted */
806 VSUM(r->rop, vtmp, r->ron, -nd.thick);
807 direct(r, dir_btdf, &nd); /* separate transmission */
808 VCOPY(r->rop, vtmp);
809 }
810 /* clean up */
811 SDfreeCache(nd.sd);
812 return(1);
813 }
