--- ray/src/rt/m_bsdf.c 2012/06/09 07:16:47 2.21 +++ ray/src/rt/m_bsdf.c 2012/09/02 15:33:15 2.22 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_bsdf.c,v 2.21 2012/06/09 07:16:47 greg Exp $"; +static const char RCSid[] = "$Id: m_bsdf.c,v 2.22 2012/09/02 15:33:15 greg Exp $"; #endif /* * Shading for materials with BSDFs taken from XML data files @@ -380,7 +380,10 @@ sample_sdf(BSDFDAT *ndp, int sflags) if (sflags == SDsampSpT) { unsc = ndp->tunsamp; - dfp = ndp->sd->tf; + if (ndp->pr->rod > 0) + dfp = (ndp->sd->tf != NULL) ? ndp->sd->tf : ndp->sd->tb; + else + dfp = (ndp->sd->tb != NULL) ? ndp->sd->tb : ndp->sd->tf; cvt_sdcolor(unsc, &ndp->sd->tLamb); } else /* sflags == SDsampSpR */ { unsc = ndp->runsamp; @@ -470,7 +473,7 @@ m_bsdf(OBJREC *m, RAY *r) } else { if (m->oargs.nfargs < 6) { /* check invisible backside */ if (!backvis && (nd.sd->rb == NULL) & - (nd.sd->tf == NULL)) { + (nd.sd->tb == NULL)) { SDfreeCache(nd.sd); raytrans(r); return(1); @@ -567,7 +570,8 @@ m_bsdf(OBJREC *m, RAY *r) flipsurface(r); } /* add direct component */ - if ((bright(nd.tdiff) <= FTINY) & (nd.sd->tf == NULL)) { + if ((bright(nd.tdiff) <= FTINY) & (nd.sd->tf == NULL) & + (nd.sd->tb == NULL)) { direct(r, dir_brdf, &nd); /* reflection only */ } else if (nd.thick == 0) { direct(r, dir_bsdf, &nd); /* thin surface scattering */
