--- ray/src/rt/m_bsdf.c 2011/02/20 06:34:19 2.5 +++ ray/src/rt/m_bsdf.c 2011/02/20 17:43:43 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_bsdf.c,v 2.5 2011/02/20 06:34:19 greg Exp $"; +static const char RCSid[] = "$Id: m_bsdf.c,v 2.6 2011/02/20 17:43:43 greg Exp $"; #endif /* * Shading for materials with BSDFs taken from XML data files @@ -401,6 +401,7 @@ sample_sdf(BSDFDAT *ndp, int sflags) int m_bsdf(OBJREC *m, RAY *r) { + int hitfront; COLOR ctmp; SDError ec; FVECT upvec, vtmp; @@ -410,7 +411,8 @@ m_bsdf(OBJREC *m, RAY *r) if ((m->oargs.nsargs < 6) | (m->oargs.nfargs > 9) | (m->oargs.nfargs % 3)) objerror(m, USER, "bad # arguments"); - + /* record surface struck */ + hitfront = (r->rod > .0); /* load cal file */ mf = getfunc(m, 5, 0x1d, 1); /* get thickness */ @@ -425,14 +427,14 @@ m_bsdf(OBJREC *m, RAY *r) } /* check other rays to pass */ if (nd.thick != 0 && (!(r->crtype & (SPECULAR|AMBIENT)) || - nd.thick > .0 ^ r->rod > .0)) { + nd.thick > .0 ^ hitfront)) { raytrans(r); /* hide our proxy */ return(1); } /* get BSDF data */ nd.sd = loadBSDF(m->oargs.sarg[1]); /* diffuse reflectance */ - if (r->rod > .0) { + if (hitfront) { if (m->oargs.nfargs < 3) setcolor(nd.rdiff, .0, .0, .0); else @@ -497,7 +499,7 @@ m_bsdf(OBJREC *m, RAY *r) SDfreeCache(nd.sd); return(1); } - if (r->rod < .0) { /* perturb normal towards hit */ + if (!hitfront) { /* perturb normal towards hit */ nd.pnorm[0] = -nd.pnorm[0]; nd.pnorm[1] = -nd.pnorm[1]; nd.pnorm[2] = -nd.pnorm[2]; @@ -510,18 +512,18 @@ m_bsdf(OBJREC *m, RAY *r) copycolor(ctmp, nd.rdiff); addcolor(ctmp, nd.runsamp); if (bright(ctmp) > FTINY) { /* ambient from reflection */ - if (r->rod < .0) + if (!hitfront) flipsurface(r); multambient(ctmp, r, nd.pnorm); addcolor(r->rcol, ctmp); - if (r->rod < .0) + if (!hitfront) flipsurface(r); } copycolor(ctmp, nd.tdiff); addcolor(ctmp, nd.tunsamp); if (bright(ctmp) > FTINY) { /* ambient from other side */ FVECT bnorm; - if (r->rod > .0) + if (hitfront) flipsurface(r); bnorm[0] = -nd.pnorm[0]; bnorm[1] = -nd.pnorm[1]; @@ -534,7 +536,7 @@ m_bsdf(OBJREC *m, RAY *r) } else multambient(ctmp, r, bnorm); addcolor(r->rcol, ctmp); - if (r->rod > .0) + if (hitfront) flipsurface(r); } /* add direct component */ @@ -546,7 +548,7 @@ m_bsdf(OBJREC *m, RAY *r) direct(r, dir_brdf, &nd); /* reflection first */ VCOPY(vtmp, r->rop); /* offset for transmitted */ VSUM(r->rop, vtmp, r->ron, -nd.thick); - direct(r, dir_btdf, &nd); + direct(r, dir_btdf, &nd); /* separate transmission */ VCOPY(r->rop, vtmp); } /* clean up */
