root/radiance/ray/src/rt/m_bsdf.c
Revision: 2.17
Committed: Thu Sep 22 02:15:56 2011 UTC (13 years, 7 months ago) by greg
Changes since 2.16: +2 -1 lines
Minor optimizations
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.17 static const char RCSid[] = "$Id: m_bsdf.c,v 2.16 2011/08/24 04:31:13 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Shading for materials with BSDFs taken from XML data files
6     */
7
8     #include "copyright.h"
9
10     #include "ray.h"
11     #include "ambient.h"
12     #include "source.h"
13     #include "func.h"
14     #include "bsdf.h"
15     #include "random.h"
16
17     /*
18     * Arguments to this material include optional diffuse colors.
19     * String arguments include the BSDF and function files.
20 greg 2.5 * A non-zero thickness causes the strange but useful behavior
21     * of translating transmitted rays this distance beneath the surface
22     * (opposite the surface normal) to bypass any intervening geometry.
23     * Translation only affects scattered, non-source-directed samples.
24     * A non-zero thickness has the further side-effect that an unscattered
25 greg 2.1 * (view) ray will pass right through our material if it has any
26 greg 2.5 * non-diffuse transmission, making the BSDF surface invisible. This
27     * shows the proxied geometry instead. Thickness has the further
28     * effect of turning off reflection on the hidden side so that rays
29     * heading in the opposite direction pass unimpeded through the BSDF
30     * surface. A paired surface may be placed on the opposide side of
31     * the detail geometry, less than this thickness away, if a two-way
32     * proxy is desired. Note that the sign of the thickness is important.
33     * A positive thickness hides geometry behind the BSDF surface and uses
34     * front reflectance and transmission properties. A negative thickness
35     * hides geometry in front of the surface when rays hit from behind,
36     * and applies only the transmission and backside reflectance properties.
37     * Reflection is ignored on the hidden side, as those rays pass through.
38 greg 2.1 * The "up" vector for the BSDF is given by three variables, defined
39     * (along with the thickness) by the named function file, or '.' if none.
40     * Together with the surface normal, this defines the local coordinate
41     * system for the BSDF.
42     * We do not reorient the surface, so if the BSDF has no back-side
43 greg 2.5 * reflectance and none is given in the real arguments, a BSDF surface
44     * with zero thickness will appear black when viewed from behind
45     * unless backface visibility is off.
46     * The diffuse arguments are added to components in the BSDF file,
47 greg 2.1 * not multiplied. However, patterns affect this material as a multiplier
48     * on everything except non-diffuse reflection.
49     *
50     * Arguments for MAT_BSDF are:
51     * 6+ thick BSDFfile ux uy uz funcfile transform
52     * 0
53 greg 2.8 * 0|3|6|9 rdf gdf bdf
54 greg 2.1 * rdb gdb bdb
55     * rdt gdt bdt
56     */
57
58 greg 2.4 /*
59     * Note that our reverse ray-tracing process means that the positions
60     * of incoming and outgoing vectors may be reversed in our calls
61     * to the BSDF library. This is fine, since the bidirectional nature
62     * of the BSDF (that's what the 'B' stands for) means it all works out.
63     */
64
65 greg 2.1 typedef struct {
66     OBJREC *mp; /* material pointer */
67     RAY *pr; /* intersected ray */
68     FVECT pnorm; /* perturbed surface normal */
69 greg 2.4 FVECT vray; /* local outgoing (return) vector */
70 greg 2.9 double sr_vpsa[2]; /* sqrt of BSDF projected solid angle extrema */
71 greg 2.1 RREAL toloc[3][3]; /* world to local BSDF coords */
72     RREAL fromloc[3][3]; /* local BSDF coords to world */
73     double thick; /* surface thickness */
74     SDData *sd; /* loaded BSDF data */
75     COLOR runsamp; /* BSDF hemispherical reflection */
76     COLOR rdiff; /* added diffuse reflection */
77     COLOR tunsamp; /* BSDF hemispherical transmission */
78     COLOR tdiff; /* added diffuse transmission */
79     } BSDFDAT; /* BSDF material data */
80
81     #define cvt_sdcolor(cv, svp) ccy2rgb(&(svp)->spec, (svp)->cieY, cv)
82
83 greg 2.4 /* Jitter ray sample according to projected solid angle and specjitter */
84     static void
85 greg 2.15 bsdf_jitter(FVECT vres, BSDFDAT *ndp, double sr_psa)
86 greg 2.4 {
87     VCOPY(vres, ndp->vray);
88     if (specjitter < 1.)
89     sr_psa *= specjitter;
90     if (sr_psa <= FTINY)
91     return;
92     vres[0] += sr_psa*(.5 - frandom());
93     vres[1] += sr_psa*(.5 - frandom());
94     normalize(vres);
95     }
96
97 greg 2.7 /* Evaluate BSDF for direct component, returning true if OK to proceed */
98     static int
99 greg 2.13 direct_bsdf_OK(COLOR cval, FVECT ldir, double omega, BSDFDAT *ndp)
100 greg 2.7 {
101 greg 2.15 int nsamp, ok = 0;
102 greg 2.13 FVECT vsrc, vsmp, vjit;
103     double tomega;
104 greg 2.15 double sf, tsr, sd[2];
105 greg 2.13 COLOR csmp;
106 greg 2.7 SDValue sv;
107     SDError ec;
108 greg 2.13 int i;
109 greg 2.7 /* transform source direction */
110     if (SDmapDir(vsrc, ndp->toloc, ldir) != SDEnone)
111     return(0);
112 greg 2.16 /* assign number of samples */
113     ec = SDsizeBSDF(&tomega, ndp->vray, vsrc, SDqueryMin, ndp->sd);
114     if (ec)
115     goto baderror;
116 greg 2.13 /* check indirect over-counting */
117     if (ndp->thick != 0 && ndp->pr->crtype & (SPECULAR|AMBIENT)
118     && vsrc[2] > 0 ^ ndp->vray[2] > 0) {
119     double dx = vsrc[0] + ndp->vray[0];
120     double dy = vsrc[1] + ndp->vray[1];
121 greg 2.16 if (dx*dx + dy*dy <= omega+tomega)
122 greg 2.7 return(0);
123     }
124 greg 2.15 sf = specjitter * ndp->pr->rweight;
125     if (25.*tomega <= omega)
126     nsamp = 100.*sf + .5;
127     else
128     nsamp = 4.*sf*omega/tomega + .5;
129     nsamp += !nsamp;
130     setcolor(cval, .0, .0, .0); /* sample our source area */
131 greg 2.13 sf = sqrt(omega);
132 greg 2.15 tsr = sqrt(tomega);
133 greg 2.13 for (i = nsamp; i--; ) {
134     VCOPY(vsmp, vsrc); /* jitter query directions */
135     if (nsamp > 1) {
136     multisamp(sd, 2, (i + frandom())/(double)nsamp);
137     vsmp[0] += (sd[0] - .5)*sf;
138     vsmp[1] += (sd[1] - .5)*sf;
139     if (normalize(vsmp) == 0) {
140     --nsamp;
141     continue;
142     }
143     }
144 greg 2.15 bsdf_jitter(vjit, ndp, tsr);
145 greg 2.13 /* compute BSDF */
146     ec = SDevalBSDF(&sv, vjit, vsmp, ndp->sd);
147     if (ec)
148     goto baderror;
149     if (sv.cieY <= FTINY) /* worth using? */
150     continue;
151     cvt_sdcolor(csmp, &sv);
152     addcolor(cval, csmp); /* average it in */
153     ++ok;
154     }
155     sf = 1./(double)nsamp;
156     scalecolor(cval, sf);
157     return(ok);
158     baderror:
159     objerror(ndp->mp, USER, transSDError(ec));
160 greg 2.17 return(0); /* gratis return */
161 greg 2.7 }
162
163 greg 2.5 /* Compute source contribution for BSDF (reflected & transmitted) */
164 greg 2.1 static void
165 greg 2.5 dir_bsdf(
166 greg 2.1 COLOR cval, /* returned coefficient */
167     void *nnp, /* material data */
168     FVECT ldir, /* light source direction */
169     double omega /* light source size */
170     )
171     {
172 greg 2.3 BSDFDAT *np = (BSDFDAT *)nnp;
173 greg 2.1 double ldot;
174     double dtmp;
175     COLOR ctmp;
176
177     setcolor(cval, .0, .0, .0);
178
179     ldot = DOT(np->pnorm, ldir);
180     if ((-FTINY <= ldot) & (ldot <= FTINY))
181     return;
182
183 greg 2.9 if (ldot > 0 && bright(np->rdiff) > FTINY) {
184 greg 2.1 /*
185     * Compute added diffuse reflected component.
186     */
187     copycolor(ctmp, np->rdiff);
188     dtmp = ldot * omega * (1./PI);
189     scalecolor(ctmp, dtmp);
190     addcolor(cval, ctmp);
191     }
192 greg 2.9 if (ldot < 0 && bright(np->tdiff) > FTINY) {
193 greg 2.1 /*
194     * Compute added diffuse transmission.
195     */
196     copycolor(ctmp, np->tdiff);
197     dtmp = -ldot * omega * (1.0/PI);
198     scalecolor(ctmp, dtmp);
199     addcolor(cval, ctmp);
200     }
201     /*
202     * Compute scattering coefficient using BSDF.
203     */
204 greg 2.13 if (!direct_bsdf_OK(ctmp, ldir, omega, np))
205 greg 2.1 return;
206 greg 2.9 if (ldot > 0) { /* pattern only diffuse reflection */
207 greg 2.1 COLOR ctmp1, ctmp2;
208 greg 2.9 dtmp = (np->pr->rod > 0) ? np->sd->rLambFront.cieY
209 greg 2.1 : np->sd->rLambBack.cieY;
210 greg 2.7 /* diffuse fraction */
211     dtmp /= PI * bright(ctmp);
212 greg 2.1 copycolor(ctmp2, np->pr->pcol);
213     scalecolor(ctmp2, dtmp);
214     setcolor(ctmp1, 1.-dtmp, 1.-dtmp, 1.-dtmp);
215     addcolor(ctmp1, ctmp2);
216 greg 2.3 multcolor(ctmp, ctmp1); /* apply derated pattern */
217 greg 2.1 dtmp = ldot * omega;
218     } else { /* full pattern on transmission */
219     multcolor(ctmp, np->pr->pcol);
220     dtmp = -ldot * omega;
221     }
222     scalecolor(ctmp, dtmp);
223     addcolor(cval, ctmp);
224     }
225
226 greg 2.5 /* Compute source contribution for BSDF (reflected only) */
227     static void
228     dir_brdf(
229     COLOR cval, /* returned coefficient */
230     void *nnp, /* material data */
231     FVECT ldir, /* light source direction */
232     double omega /* light source size */
233     )
234     {
235     BSDFDAT *np = (BSDFDAT *)nnp;
236     double ldot;
237     double dtmp;
238     COLOR ctmp, ctmp1, ctmp2;
239
240     setcolor(cval, .0, .0, .0);
241
242     ldot = DOT(np->pnorm, ldir);
243
244     if (ldot <= FTINY)
245     return;
246
247     if (bright(np->rdiff) > FTINY) {
248     /*
249     * Compute added diffuse reflected component.
250     */
251     copycolor(ctmp, np->rdiff);
252     dtmp = ldot * omega * (1./PI);
253     scalecolor(ctmp, dtmp);
254     addcolor(cval, ctmp);
255     }
256     /*
257     * Compute reflection coefficient using BSDF.
258     */
259 greg 2.13 if (!direct_bsdf_OK(ctmp, ldir, omega, np))
260 greg 2.5 return;
261     /* pattern only diffuse reflection */
262 greg 2.9 dtmp = (np->pr->rod > 0) ? np->sd->rLambFront.cieY
263 greg 2.5 : np->sd->rLambBack.cieY;
264 greg 2.7 dtmp /= PI * bright(ctmp); /* diffuse fraction */
265 greg 2.5 copycolor(ctmp2, np->pr->pcol);
266     scalecolor(ctmp2, dtmp);
267     setcolor(ctmp1, 1.-dtmp, 1.-dtmp, 1.-dtmp);
268     addcolor(ctmp1, ctmp2);
269     multcolor(ctmp, ctmp1); /* apply derated pattern */
270     dtmp = ldot * omega;
271     scalecolor(ctmp, dtmp);
272     addcolor(cval, ctmp);
273     }
274
275     /* Compute source contribution for BSDF (transmitted only) */
276     static void
277     dir_btdf(
278     COLOR cval, /* returned coefficient */
279     void *nnp, /* material data */
280     FVECT ldir, /* light source direction */
281     double omega /* light source size */
282     )
283     {
284     BSDFDAT *np = (BSDFDAT *)nnp;
285     double ldot;
286     double dtmp;
287     COLOR ctmp;
288
289     setcolor(cval, .0, .0, .0);
290
291     ldot = DOT(np->pnorm, ldir);
292
293     if (ldot >= -FTINY)
294     return;
295
296     if (bright(np->tdiff) > FTINY) {
297     /*
298     * Compute added diffuse transmission.
299     */
300     copycolor(ctmp, np->tdiff);
301     dtmp = -ldot * omega * (1.0/PI);
302     scalecolor(ctmp, dtmp);
303     addcolor(cval, ctmp);
304     }
305     /*
306     * Compute scattering coefficient using BSDF.
307     */
308 greg 2.13 if (!direct_bsdf_OK(ctmp, ldir, omega, np))
309 greg 2.5 return;
310     /* full pattern on transmission */
311     multcolor(ctmp, np->pr->pcol);
312     dtmp = -ldot * omega;
313     scalecolor(ctmp, dtmp);
314     addcolor(cval, ctmp);
315     }
316
317 greg 2.1 /* Sample separate BSDF component */
318     static int
319     sample_sdcomp(BSDFDAT *ndp, SDComponent *dcp, int usepat)
320     {
321     int nstarget = 1;
322 greg 2.11 int nsent;
323 greg 2.1 SDError ec;
324     SDValue bsv;
325 greg 2.11 double xrand;
326 greg 2.10 FVECT vsmp;
327 greg 2.1 RAY sr;
328     /* multiple samples? */
329     if (specjitter > 1.5) {
330     nstarget = specjitter*ndp->pr->rweight + .5;
331 greg 2.14 nstarget += !nstarget;
332 greg 2.1 }
333 greg 2.11 /* run through our samples */
334     for (nsent = 0; nsent < nstarget; nsent++) {
335 greg 2.15 if (nstarget == 1) { /* stratify random variable */
336 greg 2.11 xrand = urand(ilhash(dimlist,ndims)+samplendx);
337 greg 2.15 if (specjitter < 1.)
338     xrand = .5 + specjitter*(xrand-.5);
339     } else {
340 greg 2.11 xrand = (nsent + frandom())/(double)nstarget;
341 greg 2.15 }
342 greg 2.11 SDerrorDetail[0] = '\0'; /* sample direction & coef. */
343 greg 2.15 bsdf_jitter(vsmp, ndp, ndp->sr_vpsa[0]);
344 greg 2.11 ec = SDsampComponent(&bsv, vsmp, xrand, dcp);
345 greg 2.1 if (ec)
346 greg 2.2 objerror(ndp->mp, USER, transSDError(ec));
347 greg 2.11 if (bsv.cieY <= FTINY) /* zero component? */
348 greg 2.1 break;
349     /* map vector to world */
350 greg 2.4 if (SDmapDir(sr.rdir, ndp->fromloc, vsmp) != SDEnone)
351 greg 2.1 break;
352     /* spawn a specular ray */
353     if (nstarget > 1)
354     bsv.cieY /= (double)nstarget;
355 greg 2.11 cvt_sdcolor(sr.rcoef, &bsv); /* use sample color */
356     if (usepat) /* apply pattern? */
357 greg 2.1 multcolor(sr.rcoef, ndp->pr->pcol);
358     if (rayorigin(&sr, SPECULAR, ndp->pr, sr.rcoef) < 0) {
359 greg 2.11 if (maxdepth > 0)
360 greg 2.1 break;
361 greg 2.11 continue; /* Russian roulette victim */
362 greg 2.1 }
363 greg 2.5 /* need to offset origin? */
364 greg 2.9 if (ndp->thick != 0 && ndp->pr->rod > 0 ^ vsmp[2] > 0)
365 greg 2.5 VSUM(sr.rorg, sr.rorg, ndp->pr->ron, -ndp->thick);
366 greg 2.1 rayvalue(&sr); /* send & evaluate sample */
367     multcolor(sr.rcol, sr.rcoef);
368     addcolor(ndp->pr->rcol, sr.rcol);
369     }
370     return(nsent);
371     }
372
373     /* Sample non-diffuse components of BSDF */
374     static int
375     sample_sdf(BSDFDAT *ndp, int sflags)
376     {
377     int n, ntotal = 0;
378     SDSpectralDF *dfp;
379     COLORV *unsc;
380
381     if (sflags == SDsampSpT) {
382     unsc = ndp->tunsamp;
383     dfp = ndp->sd->tf;
384     cvt_sdcolor(unsc, &ndp->sd->tLamb);
385     } else /* sflags == SDsampSpR */ {
386     unsc = ndp->runsamp;
387 greg 2.9 if (ndp->pr->rod > 0) {
388 greg 2.1 dfp = ndp->sd->rf;
389     cvt_sdcolor(unsc, &ndp->sd->rLambFront);
390     } else {
391     dfp = ndp->sd->rb;
392     cvt_sdcolor(unsc, &ndp->sd->rLambBack);
393     }
394     }
395     multcolor(unsc, ndp->pr->pcol);
396     if (dfp == NULL) /* no specular component? */
397     return(0);
398     /* below sampling threshold? */
399     if (dfp->maxHemi <= specthresh+FTINY) {
400 greg 2.3 if (dfp->maxHemi > FTINY) { /* XXX no color from BSDF */
401 greg 2.4 FVECT vjit;
402     double d;
403 greg 2.1 COLOR ctmp;
404 greg 2.15 bsdf_jitter(vjit, ndp, ndp->sr_vpsa[1]);
405 greg 2.4 d = SDdirectHemi(vjit, sflags, ndp->sd);
406 greg 2.1 if (sflags == SDsampSpT) {
407     copycolor(ctmp, ndp->pr->pcol);
408     scalecolor(ctmp, d);
409     } else /* no pattern on reflection */
410     setcolor(ctmp, d, d, d);
411     addcolor(unsc, ctmp);
412     }
413     return(0);
414     }
415     /* else need to sample */
416     dimlist[ndims++] = (int)(size_t)ndp->mp;
417     ndims++;
418     for (n = dfp->ncomp; n--; ) { /* loop over components */
419     dimlist[ndims-1] = n + 9438;
420     ntotal += sample_sdcomp(ndp, &dfp->comp[n], sflags==SDsampSpT);
421     }
422     ndims -= 2;
423     return(ntotal);
424     }
425
426     /* Color a ray that hit a BSDF material */
427     int
428     m_bsdf(OBJREC *m, RAY *r)
429     {
430 greg 2.6 int hitfront;
431 greg 2.1 COLOR ctmp;
432     SDError ec;
433 greg 2.5 FVECT upvec, vtmp;
434 greg 2.1 MFUNC *mf;
435     BSDFDAT nd;
436     /* check arguments */
437     if ((m->oargs.nsargs < 6) | (m->oargs.nfargs > 9) |
438     (m->oargs.nfargs % 3))
439     objerror(m, USER, "bad # arguments");
440 greg 2.6 /* record surface struck */
441 greg 2.9 hitfront = (r->rod > 0);
442 greg 2.1 /* load cal file */
443     mf = getfunc(m, 5, 0x1d, 1);
444     /* get thickness */
445     nd.thick = evalue(mf->ep[0]);
446 greg 2.5 if ((-FTINY <= nd.thick) & (nd.thick <= FTINY))
447 greg 2.1 nd.thick = .0;
448     /* check shadow */
449     if (r->crtype & SHADOW) {
450 greg 2.9 if (nd.thick != 0)
451 greg 2.3 raytrans(r); /* pass-through */
452 greg 2.5 return(1); /* or shadow */
453 greg 2.1 }
454 greg 2.5 /* check other rays to pass */
455 greg 2.9 if (nd.thick != 0 && (!(r->crtype & (SPECULAR|AMBIENT)) ||
456     nd.thick > 0 ^ hitfront)) {
457 greg 2.5 raytrans(r); /* hide our proxy */
458 greg 2.1 return(1);
459     }
460 greg 2.5 /* get BSDF data */
461     nd.sd = loadBSDF(m->oargs.sarg[1]);
462 greg 2.1 /* diffuse reflectance */
463 greg 2.6 if (hitfront) {
464 greg 2.1 if (m->oargs.nfargs < 3)
465     setcolor(nd.rdiff, .0, .0, .0);
466     else
467     setcolor(nd.rdiff, m->oargs.farg[0],
468     m->oargs.farg[1],
469     m->oargs.farg[2]);
470     } else {
471     if (m->oargs.nfargs < 6) { /* check invisible backside */
472 greg 2.3 if (!backvis && (nd.sd->rb == NULL) &
473     (nd.sd->tf == NULL)) {
474 greg 2.1 SDfreeCache(nd.sd);
475     raytrans(r);
476     return(1);
477     }
478     setcolor(nd.rdiff, .0, .0, .0);
479     } else
480     setcolor(nd.rdiff, m->oargs.farg[3],
481     m->oargs.farg[4],
482     m->oargs.farg[5]);
483     }
484     /* diffuse transmittance */
485     if (m->oargs.nfargs < 9)
486     setcolor(nd.tdiff, .0, .0, .0);
487     else
488     setcolor(nd.tdiff, m->oargs.farg[6],
489     m->oargs.farg[7],
490     m->oargs.farg[8]);
491     nd.mp = m;
492     nd.pr = r;
493     /* get modifiers */
494     raytexture(r, m->omod);
495     /* modify diffuse values */
496     multcolor(nd.rdiff, r->pcol);
497     multcolor(nd.tdiff, r->pcol);
498     /* get up vector */
499     upvec[0] = evalue(mf->ep[1]);
500     upvec[1] = evalue(mf->ep[2]);
501     upvec[2] = evalue(mf->ep[3]);
502     /* return to world coords */
503     if (mf->f != &unitxf) {
504     multv3(upvec, upvec, mf->f->xfm);
505     nd.thick *= mf->f->sca;
506     }
507     raynormal(nd.pnorm, r);
508     /* compute local BSDF xform */
509     ec = SDcompXform(nd.toloc, nd.pnorm, upvec);
510     if (!ec) {
511 greg 2.4 nd.vray[0] = -r->rdir[0];
512     nd.vray[1] = -r->rdir[1];
513     nd.vray[2] = -r->rdir[2];
514     ec = SDmapDir(nd.vray, nd.toloc, nd.vray);
515 greg 2.1 }
516     if (!ec)
517     ec = SDinvXform(nd.fromloc, nd.toloc);
518 greg 2.4 /* determine BSDF resolution */
519     if (!ec)
520 greg 2.9 ec = SDsizeBSDF(nd.sr_vpsa, nd.vray, NULL,
521     SDqueryMin+SDqueryMax, nd.sd);
522     if (ec) {
523 greg 2.2 objerror(m, WARNING, transSDError(ec));
524 greg 2.1 SDfreeCache(nd.sd);
525     return(1);
526     }
527 greg 2.9 nd.sr_vpsa[0] = sqrt(nd.sr_vpsa[0]);
528     nd.sr_vpsa[1] = sqrt(nd.sr_vpsa[1]);
529 greg 2.6 if (!hitfront) { /* perturb normal towards hit */
530 greg 2.1 nd.pnorm[0] = -nd.pnorm[0];
531     nd.pnorm[1] = -nd.pnorm[1];
532     nd.pnorm[2] = -nd.pnorm[2];
533     }
534     /* sample reflection */
535     sample_sdf(&nd, SDsampSpR);
536     /* sample transmission */
537     sample_sdf(&nd, SDsampSpT);
538     /* compute indirect diffuse */
539     copycolor(ctmp, nd.rdiff);
540     addcolor(ctmp, nd.runsamp);
541 greg 2.5 if (bright(ctmp) > FTINY) { /* ambient from reflection */
542 greg 2.6 if (!hitfront)
543 greg 2.1 flipsurface(r);
544     multambient(ctmp, r, nd.pnorm);
545     addcolor(r->rcol, ctmp);
546 greg 2.6 if (!hitfront)
547 greg 2.1 flipsurface(r);
548     }
549     copycolor(ctmp, nd.tdiff);
550     addcolor(ctmp, nd.tunsamp);
551     if (bright(ctmp) > FTINY) { /* ambient from other side */
552     FVECT bnorm;
553 greg 2.6 if (hitfront)
554 greg 2.1 flipsurface(r);
555     bnorm[0] = -nd.pnorm[0];
556     bnorm[1] = -nd.pnorm[1];
557     bnorm[2] = -nd.pnorm[2];
558 greg 2.9 if (nd.thick != 0) { /* proxy with offset? */
559 greg 2.5 VCOPY(vtmp, r->rop);
560     VSUM(r->rop, vtmp, r->ron, -nd.thick);
561     multambient(ctmp, r, bnorm);
562     VCOPY(r->rop, vtmp);
563     } else
564     multambient(ctmp, r, bnorm);
565 greg 2.1 addcolor(r->rcol, ctmp);
566 greg 2.6 if (hitfront)
567 greg 2.1 flipsurface(r);
568     }
569     /* add direct component */
570 greg 2.5 if ((bright(nd.tdiff) <= FTINY) & (nd.sd->tf == NULL)) {
571     direct(r, dir_brdf, &nd); /* reflection only */
572 greg 2.9 } else if (nd.thick == 0) {
573 greg 2.5 direct(r, dir_bsdf, &nd); /* thin surface scattering */
574     } else {
575     direct(r, dir_brdf, &nd); /* reflection first */
576     VCOPY(vtmp, r->rop); /* offset for transmitted */
577     VSUM(r->rop, vtmp, r->ron, -nd.thick);
578 greg 2.6 direct(r, dir_btdf, &nd); /* separate transmission */
579 greg 2.5 VCOPY(r->rop, vtmp);
580     }
581 greg 2.1 /* clean up */
582     SDfreeCache(nd.sd);
583     return(1);
584     }
