1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Shading for materials with arbitrary BRDF's |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include "data.h" |
14 |
15 |
#include "otypes.h" |
16 |
17 |
#include "func.h" |
18 |
19 |
extern int backvis; /* back faces visible? */ |
20 |
21 |
22 |
* Arguments to this material include the color and specularity. |
23 |
* String arguments include the reflection function and files. |
24 |
* The BRDF is currently used just for the specular component to light |
25 |
* sources. Reflectance values or data coordinates are functions |
26 |
* of the direction to the light source. (Data modification functions |
27 |
* are passed the source direction as args 2-4.) |
28 |
* We orient the surface towards the incoming ray, so a single |
29 |
* surface can be used to represent an infinitely thin object. |
30 |
31 |
* Arguments for MAT_PFUNC and MAT_MFUNC are: |
32 |
* 2+ func funcfile transform |
33 |
* 0 |
34 |
* 4+ red grn blu specularity A5 .. |
35 |
36 |
* Arguments for MAT_PDATA and MAT_MDATA are: |
37 |
* 4+ func datafile funcfile v0 .. transform |
38 |
* 0 |
39 |
40 |
41 |
* Arguments for MAT_TFUNC are: |
42 |
43 |
* 0 |
44 |
* 4+ red grn blu rspec trans tspec A7 .. |
45 |
46 |
* Arguments for MAT_TDATA are: |
47 |
48 |
* 0 |
49 |
50 |
51 |
* Arguments for the more general MAT_BRTDF are: |
52 |
* 10+ rrefl grefl brefl |
53 |
* rtrns gtrns btrns |
54 |
* rbrtd gbrtd bbrtd |
55 |
* funcfile transform |
56 |
* 0 |
57 |
* 9+ rdf gdf bdf |
58 |
* rdb gdb bdb |
59 |
* rdt gdt bdt A10 .. |
60 |
61 |
* In addition to the normal variables available to functions, |
62 |
* we define the following: |
63 |
* NxP, NyP, NzP - perturbed surface normal |
64 |
* RdotP - perturbed ray dot product |
65 |
* CrP, CgP, CbP - perturbed material color (or pattern) |
66 |
67 |
68 |
typedef struct { |
69 |
OBJREC *mp; /* material pointer */ |
70 |
RAY *pr; /* intersected ray */ |
71 |
DATARRAY *dp; /* data array for PDATA, MDATA or TDATA */ |
72 |
COLOR mcolor; /* material (or pattern) color */ |
73 |
COLOR rdiff; /* diffuse reflection */ |
74 |
COLOR tdiff; /* diffuse transmission */ |
75 |
double rspec; /* specular reflectance (1 for BRDTF) */ |
76 |
double trans; /* transmissivity (.5 for BRDTF) */ |
77 |
double tspec; /* specular transmittance (1 for BRDTF) */ |
78 |
FVECT pnorm; /* perturbed surface normal */ |
79 |
double pdot; /* perturbed dot product */ |
80 |
} BRDFDAT; /* BRDF material data */ |
81 |
82 |
83 |
dirbrdf(cval, np, ldir, omega) /* compute source contribution */ |
84 |
COLOR cval; /* returned coefficient */ |
85 |
register BRDFDAT *np; /* material data */ |
86 |
FVECT ldir; /* light source direction */ |
87 |
double omega; /* light source size */ |
88 |
89 |
double ldot; |
90 |
double dtmp; |
91 |
COLOR ctmp; |
92 |
FVECT ldx; |
93 |
double lddx[3], pt[MAXDIM]; |
94 |
double vldx[4]; |
95 |
register char **sa; |
96 |
register int i; |
97 |
98 |
setcolor(cval, 0.0, 0.0, 0.0); |
99 |
100 |
ldot = DOT(np->pnorm, ldir); |
101 |
102 |
if (ldot <= FTINY && ldot >= -FTINY) |
103 |
return; /* too close to grazing */ |
104 |
105 |
if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) |
106 |
return; /* wrong side */ |
107 |
108 |
if (ldot > 0.0) { |
109 |
110 |
* Compute and add diffuse reflected component to returned |
111 |
* color. The diffuse reflected component will always be |
112 |
* modified by the color of the material. |
113 |
114 |
copycolor(ctmp, np->rdiff); |
115 |
dtmp = ldot * omega / PI; |
116 |
scalecolor(ctmp, dtmp); |
117 |
addcolor(cval, ctmp); |
118 |
} else { |
119 |
120 |
* Diffuse transmitted component. |
121 |
122 |
copycolor(ctmp, np->tdiff); |
123 |
dtmp = -ldot * omega / PI; |
124 |
125 |
126 |
127 |
if (ldot > 0.0 ? np->rspec <= FTINY : np->tspec <= FTINY) |
128 |
return; /* no specular component */ |
129 |
/* set up function */ |
130 |
setbrdfunc(np); |
131 |
sa = np->mp->oargs.sarg; |
132 |
errno = 0; |
133 |
/* transform light vector */ |
134 |
multv3(ldx, ldir, funcxf.xfm); |
135 |
for (i = 0; i < 3; i++) |
136 |
lddx[i] = ldx[i]/funcxf.sca; |
137 |
/* compute BRTDF */ |
138 |
if (np->mp->otype == MAT_BRTDF) { |
139 |
if (sa[6][0] == '0') /* special case */ |
140 |
colval(ctmp,RED) = 0.0; |
141 |
else |
142 |
colval(ctmp,RED) = funvalue(sa[6], 3, lddx); |
143 |
if (!strcmp(sa[7],sa[6])) |
144 |
colval(ctmp,GRN) = colval(ctmp,RED); |
145 |
else |
146 |
colval(ctmp,GRN) = funvalue(sa[7], 3, lddx); |
147 |
if (!strcmp(sa[8],sa[6])) |
148 |
colval(ctmp,BLU) = colval(ctmp,RED); |
149 |
else if (!strcmp(sa[8],sa[7])) |
150 |
colval(ctmp,BLU) = colval(ctmp,GRN); |
151 |
else |
152 |
colval(ctmp,BLU) = funvalue(sa[8], 3, lddx); |
153 |
dtmp = bright(ctmp); |
154 |
} else if (np->dp == NULL) { |
155 |
dtmp = funvalue(sa[0], 3, lddx); |
156 |
setcolor(ctmp, dtmp, dtmp, dtmp); |
157 |
} else { |
158 |
for (i = 0; i < np->dp->nd; i++) |
159 |
pt[i] = funvalue(sa[3+i], 3, lddx); |
160 |
vldx[0] = datavalue(np->dp, pt); |
161 |
vldx[1] = lddx[0]; vldx[2] = lddx[1]; vldx[3] = lddx[2]; |
162 |
dtmp = funvalue(sa[0], 4, vldx); |
163 |
164 |
165 |
if (errno) { |
166 |
objerror(np->mp, WARNING, "compute error"); |
167 |
return; |
168 |
169 |
if (dtmp <= FTINY) |
170 |
return; |
171 |
if (ldot > 0.0) { |
172 |
173 |
* Compute reflected non-diffuse component. |
174 |
175 |
if (np->mp->otype == MAT_MFUNC | np->mp->otype == MAT_MDATA) |
176 |
multcolor(ctmp, np->mcolor); |
177 |
dtmp = ldot * omega * np->rspec; |
178 |
179 |
180 |
} else { |
181 |
182 |
* Compute transmitted non-diffuse component. |
183 |
184 |
if (np->mp->otype == MAT_TFUNC | np->mp->otype == MAT_TDATA) |
185 |
186 |
dtmp = -ldot * omega * np->tspec; |
187 |
188 |
189 |
190 |
191 |
192 |
193 |
m_brdf(m, r) /* color a ray which hit a BRDTF material */ |
194 |
register OBJREC *m; |
195 |
register RAY *r; |
196 |
197 |
BRDFDAT nd; |
198 |
RAY sr; |
199 |
double transtest, transdist; |
200 |
int hasrefl, hastrans; |
201 |
COLOR ctmp; |
202 |
register MFUNC *mf; |
203 |
register int i; |
204 |
/* check arguments */ |
205 |
if (m->oargs.nsargs < 10 | m->oargs.nfargs < 9) |
206 |
objerror(m, USER, "bad # arguments"); |
207 |
nd.mp = m; |
208 |
nd.pr = r; |
209 |
/* dummy values */ |
210 |
nd.rspec = nd.tspec = 1.0; |
211 |
nd.trans = 0.5; |
212 |
/* diffuse reflectance */ |
213 |
if (r->rod > 0.0) |
214 |
setcolor(nd.rdiff, m->oargs.farg[0], |
215 |
m->oargs.farg[1], |
216 |
m->oargs.farg[2]); |
217 |
else |
218 |
setcolor(nd.rdiff, m->oargs.farg[3], |
219 |
m->oargs.farg[4], |
220 |
m->oargs.farg[5]); |
221 |
/* diffuse transmittance */ |
222 |
setcolor(nd.tdiff, m->oargs.farg[6], |
223 |
m->oargs.farg[7], |
224 |
m->oargs.farg[8]); |
225 |
/* get modifiers */ |
226 |
raytexture(r, m->omod); |
227 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ |
228 |
if (r->rod < 0.0) { /* orient perturbed values */ |
229 |
nd.pdot = -nd.pdot; |
230 |
for (i = 0; i < 3; i++) { |
231 |
nd.pnorm[i] = -nd.pnorm[i]; |
232 |
r->pert[i] = -r->pert[i]; |
233 |
234 |
235 |
copycolor(nd.mcolor, r->pcol); /* get pattern color */ |
236 |
multcolor(nd.rdiff, nd.mcolor); /* modify diffuse values */ |
237 |
multcolor(nd.tdiff, nd.mcolor); |
238 |
hasrefl = bright(nd.rdiff) > FTINY; |
239 |
hastrans = bright(nd.tdiff) > FTINY; |
240 |
/* load cal file */ |
241 |
nd.dp = NULL; |
242 |
mf = getfunc(m, 9, 0x3f, 0); |
243 |
/* compute transmitted ray */ |
244 |
setbrdfunc(&nd); |
245 |
transtest = 0; |
246 |
transdist = r->rot; |
247 |
errno = 0; |
248 |
setcolor(ctmp, evalue(mf->ep[3]), |
249 |
evalue(mf->ep[4]), |
250 |
evalue(mf->ep[5])); |
251 |
if (errno) |
252 |
objerror(m, WARNING, "compute error"); |
253 |
else if (rayorigin(&sr, r, TRANS, bright(ctmp)) == 0) { |
254 |
if (!(r->crtype & SHADOW) && |
255 |
DOT(r->pert,r->pert) > FTINY*FTINY) { |
256 |
for (i = 0; i < 3; i++) /* perturb direction */ |
257 |
sr.rdir[i] = r->rdir[i] - .75*r->pert[i]; |
258 |
if (normalize(sr.rdir) == 0.0) { |
259 |
objerror(m, WARNING, "illegal perturbation"); |
260 |
VCOPY(sr.rdir, r->rdir); |
261 |
262 |
} else { |
263 |
264 |
transtest = 2; |
265 |
266 |
rayvalue(&sr); |
267 |
multcolor(sr.rcol, ctmp); |
268 |
addcolor(r->rcol, sr.rcol); |
269 |
transtest *= bright(sr.rcol); |
270 |
transdist = r->rot + sr.rt; |
271 |
272 |
if (r->crtype & SHADOW) /* the rest is shadow */ |
273 |
return(1); |
274 |
/* compute reflected ray */ |
275 |
setbrdfunc(&nd); |
276 |
errno = 0; |
277 |
setcolor(ctmp, evalue(mf->ep[0]), |
278 |
evalue(mf->ep[1]), |
279 |
evalue(mf->ep[2])); |
280 |
if (errno) |
281 |
282 |
else if (rayorigin(&sr, r, REFLECTED, bright(ctmp)) == 0) { |
283 |
284 |
sr.rdir[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i]; |
285 |
rayvalue(&sr); |
286 |
287 |
288 |
289 |
/* compute ambient */ |
290 |
if (hasrefl) { |
291 |
if (nd.pdot < 0.0) |
292 |
flipsurface(r); |
293 |
ambient(ctmp, r); |
294 |
multcolor(ctmp, nd.rdiff); |
295 |
addcolor(r->rcol, ctmp); /* add to returned color */ |
296 |
297 |
flipsurface(r); |
298 |
299 |
if (hastrans) { /* from other side */ |
300 |
if (nd.pdot > 0.0) |
301 |
flipsurface(r); |
302 |
ambient(ctmp, r); |
303 |
multcolor(ctmp, nd.tdiff); |
304 |
addcolor(r->rcol, ctmp); |
305 |
306 |
flipsurface(r); |
307 |
308 |
if (hasrefl | hastrans || m->oargs.sarg[6][0] != '0') |
309 |
direct(r, dirbrdf, &nd); /* add direct component */ |
310 |
/* check distance */ |
311 |
if (transtest > bright(r->rcol)) |
312 |
r->rt = transdist; |
313 |
314 |
return(1); |
315 |
316 |
317 |
318 |
319 |
m_brdf2(m, r) /* color a ray which hit a BRDF material */ |
320 |
321 |
register RAY *r; |
322 |
323 |
BRDFDAT nd; |
324 |
COLOR ctmp; |
325 |
double dtmp; |
326 |
/* always a shadow */ |
327 |
if (r->crtype & SHADOW) |
328 |
return(1); |
329 |
330 |
if (m->oargs.nsargs < (hasdata(m->otype)?4:2) | m->oargs.nfargs < |
331 |
(m->otype==MAT_TFUNC|m->otype==MAT_TDATA?6:4)) |
332 |
333 |
nd.mp = m; |
334 |
nd.pr = r; |
335 |
/* get material color */ |
336 |
setcolor(nd.mcolor, m->oargs.farg[0], |
337 |
m->oargs.farg[1], |
338 |
339 |
/* get specular component */ |
340 |
nd.rspec = m->oargs.farg[3]; |
341 |
/* compute transmittance */ |
342 |
if (m->otype == MAT_TFUNC | m->otype == MAT_TDATA) { |
343 |
nd.trans = m->oargs.farg[4]*(1.0 - nd.rspec); |
344 |
nd.tspec = nd.trans * m->oargs.farg[5]; |
345 |
dtmp = nd.trans - nd.tspec; |
346 |
setcolor(nd.tdiff, dtmp, dtmp, dtmp); |
347 |
} else { |
348 |
nd.tspec = nd.trans = 0.0; |
349 |
setcolor(nd.tdiff, 0.0, 0.0, 0.0); |
350 |
351 |
/* compute reflectance */ |
352 |
dtmp = 1.0 - nd.trans - nd.rspec; |
353 |
setcolor(nd.rdiff, dtmp, dtmp, dtmp); |
354 |
/* check for back side */ |
355 |
if (r->rod < 0.0) { |
356 |
if (!backvis && m->otype != MAT_TFUNC |
357 |
&& m->otype != MAT_TDATA) { |
358 |
raytrans(r); |
359 |
return(1); |
360 |
361 |
flipsurface(r); /* reorient if backvis */ |
362 |
363 |
364 |
365 |
366 |
multcolor(nd.mcolor, r->pcol); /* modify material color */ |
367 |
multcolor(nd.rdiff, nd.mcolor); |
368 |
369 |
/* load auxiliary files */ |
370 |
if (hasdata(m->otype)) { |
371 |
nd.dp = getdata(m->oargs.sarg[1]); |
372 |
getfunc(m, 2, 0, 0); |
373 |
} else { |
374 |
nd.dp = NULL; |
375 |
getfunc(m, 1, 0, 0); |
376 |
377 |
378 |
if (nd.trans < 1.0-FTINY) { |
379 |
ambient(ctmp, r); |
380 |
scalecolor(ctmp, 1.0-nd.trans); |
381 |
multcolor(ctmp, nd.mcolor); /* modified by material color */ |
382 |
383 |
384 |
if (nd.trans > FTINY) { /* from other side */ |
385 |
flipsurface(r); |
386 |
ambient(ctmp, r); |
387 |
scalecolor(ctmp, nd.trans); |
388 |
multcolor(ctmp, nd.mcolor); |
389 |
390 |
flipsurface(r); |
391 |
392 |
393 |
direct(r, dirbrdf, &nd); |
394 |
395 |
return(1); |
396 |
397 |
398 |
399 |
setbrdfunc(np) /* set up brdf function and variables */ |
400 |
register BRDFDAT *np; |
401 |
402 |
FVECT vec; |
403 |
404 |
if (setfunc(np->mp, np->pr) == 0) |
405 |
return(0); /* it's OK, setfunc says we're done */ |
406 |
/* else (re)assign special variables */ |
407 |
multv3(vec, np->pnorm, funcxf.xfm); |
408 |
varset("NxP", '=', vec[0]/funcxf.sca); |
409 |
varset("NyP", '=', vec[1]/funcxf.sca); |
410 |
varset("NzP", '=', vec[2]/funcxf.sca); |
411 |
varset("RdotP", '=', np->pdot <= -1.0 ? -1.0 : |
412 |
np->pdot >= 1.0 ? 1.0 : np->pdot); |
413 |
varset("CrP", '=', colval(np->mcolor,RED)); |
414 |
varset("CgP", '=', colval(np->mcolor,GRN)); |
415 |
varset("CbP", '=', colval(np->mcolor,BLU)); |
416 |
return(1); |
417 |
