--- ray/src/rt/m_brdf.c 1993/05/27 15:28:01 2.6 +++ ray/src/rt/m_brdf.c 1993/08/24 12:59:25 2.8 @@ -21,7 +21,8 @@ static char SCCSid[] = "$SunId$ LBL"; * String arguments include the reflection function and files. * The BRDF is currently used just for the specular component to light * sources. Reflectance values or data coordinates are functions - * of the direction to the light source. + * of the direction to the light source. (Data modification functions + * are passed the source direction as args 2-4.) * We orient the surface towards the incoming ray, so a single * surface can be used to represent an infinitely thin object. * @@ -88,6 +89,7 @@ double omega; /* light source size */ COLOR ctmp; FVECT ldx; double lddx[3], pt[MAXDIM]; + double vldx[4]; register char **sa; register int i; @@ -153,8 +155,9 @@ double omega; /* light source size */ } else { for (i = 0; i < np->dp->nd; i++) pt[i] = funvalue(sa[3+i], 3, lddx); - dtmp = datavalue(np->dp, pt); - dtmp = funvalue(sa[0], 1, &dtmp); + vldx[0] = datavalue(np->dp, pt); + vldx[1] = lddx[0]; vldx[2] = lddx[1]; vldx[3] = lddx[2]; + dtmp = funvalue(sa[0], 4, vldx); setcolor(ctmp, dtmp, dtmp, dtmp); } if (errno) { @@ -239,6 +242,7 @@ register RAY *r; /* compute transmitted ray */ setbrdfunc(&nd); transtest = 0; + transdist = r->rot; errno = 0; setcolor(ctmp, evalue(mf->ep[3]), evalue(mf->ep[4]),
