root/radiance/ray/src/rt/m_brdf.c
Revision: 2.7
Committed: Thu Aug 12 17:50:40 1993 UTC (32 years ago) by greg
Changes since 2.6: +6 -3 lines
added source direction to data value function parameters
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Shading for materials with arbitrary BRDF's
9 */
10
11 #include "ray.h"
12
13 #include "data.h"
14
15 #include "otypes.h"
16
17 #include "func.h"
18
19 /*
20 * Arguments to this material include the color and specularity.
21 * String arguments include the reflection function and files.
22 * The BRDF is currently used just for the specular component to light
23 * sources. Reflectance values or data coordinates are functions
24 * of the direction to the light source. (Data modification functions
25 * are passed the source direction as args 2-4.)
26 * We orient the surface towards the incoming ray, so a single
27 * surface can be used to represent an infinitely thin object.
28 *
29 * Arguments for MAT_PFUNC and MAT_MFUNC are:
30 * 2+ func funcfile transform
31 * 0
32 * 4+ red grn blu specularity A5 ..
33 *
34 * Arguments for MAT_PDATA and MAT_MDATA are:
35 * 4+ func datafile funcfile v0 .. transform
36 * 0
37 * 4+ red grn blu specularity A5 ..
38 *
39 * Arguments for MAT_TFUNC are:
40 * 2+ func funcfile transform
41 * 0
42 * 4+ red grn blu rspec trans tspec A7 ..
43 *
44 * Arguments for MAT_TDATA are:
45 * 4+ func datafile funcfile v0 .. transform
46 * 0
47 * 4+ red grn blu rspec trans tspec A7 ..
48 *
49 * Arguments for the more general MAT_BRTDF are:
50 * 10+ rrefl grefl brefl
51 * rtrns gtrns btrns
52 * rbrtd gbrtd bbrtd
53 * funcfile transform
54 * 0
55 * 9+ rdf gdf bdf
56 * rdb gdb bdb
57 * rdt gdt bdt A10 ..
58 *
59 * In addition to the normal variables available to functions,
60 * we define the following:
61 * NxP, NyP, NzP - perturbed surface normal
62 * RdotP - perturbed ray dot product
63 * CrP, CgP, CbP - perturbed material color (or pattern)
64 */
65
66 typedef struct {
67 OBJREC *mp; /* material pointer */
68 RAY *pr; /* intersected ray */
69 DATARRAY *dp; /* data array for PDATA, MDATA or TDATA */
70 COLOR mcolor; /* material (or pattern) color */
71 COLOR rdiff; /* diffuse reflection */
72 COLOR tdiff; /* diffuse transmission */
73 double rspec; /* specular reflectance (1 for BRDTF) */
74 double trans; /* transmissivity (.5 for BRDTF) */
75 double tspec; /* specular transmittance (1 for BRDTF) */
76 FVECT pnorm; /* perturbed surface normal */
77 double pdot; /* perturbed dot product */
78 } BRDFDAT; /* BRDF material data */
79
80
81 dirbrdf(cval, np, ldir, omega) /* compute source contribution */
82 COLOR cval; /* returned coefficient */
83 register BRDFDAT *np; /* material data */
84 FVECT ldir; /* light source direction */
85 double omega; /* light source size */
86 {
87 double ldot;
88 double dtmp;
89 COLOR ctmp;
90 FVECT ldx;
91 double lddx[3], pt[MAXDIM];
92 double vldx[4];
93 register char **sa;
94 register int i;
95
96 setcolor(cval, 0.0, 0.0, 0.0);
97
98 ldot = DOT(np->pnorm, ldir);
99
100 if (ldot <= FTINY && ldot >= -FTINY)
101 return; /* too close to grazing */
102
103 if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
104 return; /* wrong side */
105
106 if (ldot > 0.0) {
107 /*
108 * Compute and add diffuse reflected component to returned
109 * color. The diffuse reflected component will always be
110 * modified by the color of the material.
111 */
112 copycolor(ctmp, np->rdiff);
113 dtmp = ldot * omega / PI;
114 scalecolor(ctmp, dtmp);
115 addcolor(cval, ctmp);
116 } else {
117 /*
118 * Diffuse transmitted component.
119 */
120 copycolor(ctmp, np->tdiff);
121 dtmp = -ldot * omega / PI;
122 scalecolor(ctmp, dtmp);
123 addcolor(cval, ctmp);
124 }
125 if (ldot > 0.0 ? np->rspec <= FTINY : np->tspec <= FTINY)
126 return; /* no specular component */
127 /* set up function */
128 setbrdfunc(np);
129 sa = np->mp->oargs.sarg;
130 errno = 0;
131 /* transform light vector */
132 multv3(ldx, ldir, funcxf.xfm);
133 for (i = 0; i < 3; i++)
134 lddx[i] = ldx[i]/funcxf.sca;
135 /* compute BRTDF */
136 if (np->mp->otype == MAT_BRTDF) {
137 if (sa[6][0] == '0') /* special case */
138 colval(ctmp,RED) = 0.0;
139 else
140 colval(ctmp,RED) = funvalue(sa[6], 3, lddx);
141 if (!strcmp(sa[7],sa[6]))
142 colval(ctmp,GRN) = colval(ctmp,RED);
143 else
144 colval(ctmp,GRN) = funvalue(sa[7], 3, lddx);
145 if (!strcmp(sa[8],sa[6]))
146 colval(ctmp,BLU) = colval(ctmp,RED);
147 else if (!strcmp(sa[8],sa[7]))
148 colval(ctmp,BLU) = colval(ctmp,GRN);
149 else
150 colval(ctmp,BLU) = funvalue(sa[8], 3, lddx);
151 dtmp = bright(ctmp);
152 } else if (np->dp == NULL) {
153 dtmp = funvalue(sa[0], 3, lddx);
154 setcolor(ctmp, dtmp, dtmp, dtmp);
155 } else {
156 for (i = 0; i < np->dp->nd; i++)
157 pt[i] = funvalue(sa[3+i], 3, lddx);
158 vldx[0] = datavalue(np->dp, pt);
159 vldx[1] = lddx[0]; vldx[2] = lddx[1]; vldx[3] = lddx[2];
160 dtmp = funvalue(sa[0], 4, vldx);
161 setcolor(ctmp, dtmp, dtmp, dtmp);
162 }
163 if (errno) {
164 objerror(np->mp, WARNING, "compute error");
165 return;
166 }
167 if (dtmp <= FTINY)
168 return;
169 if (ldot > 0.0) {
170 /*
171 * Compute reflected non-diffuse component.
172 */
173 if (np->mp->otype == MAT_MFUNC | np->mp->otype == MAT_MDATA)
174 multcolor(ctmp, np->mcolor);
175 dtmp = ldot * omega * np->rspec;
176 scalecolor(ctmp, dtmp);
177 addcolor(cval, ctmp);
178 } else {
179 /*
180 * Compute transmitted non-diffuse component.
181 */
182 if (np->mp->otype == MAT_TFUNC | np->mp->otype == MAT_TDATA)
183 multcolor(ctmp, np->mcolor);
184 dtmp = -ldot * omega * np->tspec;
185 scalecolor(ctmp, dtmp);
186 addcolor(cval, ctmp);
187 }
188 }
189
190
191 m_brdf(m, r) /* color a ray which hit a BRDTF material */
192 register OBJREC *m;
193 register RAY *r;
194 {
195 BRDFDAT nd;
196 RAY sr;
197 double transtest, transdist;
198 int hasrefl, hastrans;
199 COLOR ctmp;
200 double dtmp;
201 register MFUNC *mf;
202 register int i;
203 /* check arguments */
204 if (m->oargs.nsargs < 10 | m->oargs.nfargs < 9)
205 objerror(m, USER, "bad # arguments");
206 nd.mp = m;
207 nd.pr = r;
208 /* dummy values */
209 nd.rspec = nd.tspec = 1.0;
210 nd.trans = 0.5;
211 /* diffuse reflectance */
212 if (r->rod > 0.0)
213 setcolor(nd.rdiff, m->oargs.farg[0],
214 m->oargs.farg[1],
215 m->oargs.farg[2]);
216 else
217 setcolor(nd.rdiff, m->oargs.farg[3],
218 m->oargs.farg[4],
219 m->oargs.farg[5]);
220 /* diffuse transmittance */
221 setcolor(nd.tdiff, m->oargs.farg[6],
222 m->oargs.farg[7],
223 m->oargs.farg[8]);
224 /* get modifiers */
225 raytexture(r, m->omod);
226 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
227 if (r->rod < 0.0) { /* orient perturbed values */
228 nd.pdot = -nd.pdot;
229 for (i = 0; i < 3; i++) {
230 nd.pnorm[i] = -nd.pnorm[i];
231 r->pert[i] = -r->pert[i];
232 }
233 }
234 copycolor(nd.mcolor, r->pcol); /* get pattern color */
235 multcolor(nd.rdiff, nd.mcolor); /* modify diffuse values */
236 multcolor(nd.tdiff, nd.mcolor);
237 hasrefl = bright(nd.rdiff) > FTINY;
238 hastrans = bright(nd.tdiff) > FTINY;
239 /* load cal file */
240 nd.dp = NULL;
241 mf = getfunc(m, 9, 0x3f, 0);
242 /* compute transmitted ray */
243 setbrdfunc(&nd);
244 transtest = 0;
245 errno = 0;
246 setcolor(ctmp, evalue(mf->ep[3]),
247 evalue(mf->ep[4]),
248 evalue(mf->ep[5]));
249 if (errno)
250 objerror(m, WARNING, "compute error");
251 else if (rayorigin(&sr, r, TRANS, bright(ctmp)) == 0) {
252 if (!(r->crtype & SHADOW) &&
253 DOT(r->pert,r->pert) > FTINY*FTINY) {
254 for (i = 0; i < 3; i++) /* perturb direction */
255 sr.rdir[i] = r->rdir[i] - .75*r->pert[i];
256 if (normalize(sr.rdir) == 0.0) {
257 objerror(m, WARNING, "illegal perturbation");
258 VCOPY(sr.rdir, r->rdir);
259 }
260 } else {
261 VCOPY(sr.rdir, r->rdir);
262 transtest = 2;
263 }
264 rayvalue(&sr);
265 multcolor(sr.rcol, ctmp);
266 addcolor(r->rcol, sr.rcol);
267 transtest *= bright(sr.rcol);
268 transdist = r->rot + sr.rt;
269 }
270 if (r->crtype & SHADOW) /* the rest is shadow */
271 return;
272 /* compute reflected ray */
273 setbrdfunc(&nd);
274 errno = 0;
275 setcolor(ctmp, evalue(mf->ep[0]),
276 evalue(mf->ep[1]),
277 evalue(mf->ep[2]));
278 if (errno)
279 objerror(m, WARNING, "compute error");
280 else if (rayorigin(&sr, r, REFLECTED, bright(ctmp)) == 0) {
281 for (i = 0; i < 3; i++)
282 sr.rdir[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i];
283 rayvalue(&sr);
284 multcolor(sr.rcol, ctmp);
285 addcolor(r->rcol, sr.rcol);
286 }
287 /* compute ambient */
288 if (hasrefl) {
289 if (nd.pdot < 0.0)
290 flipsurface(r);
291 ambient(ctmp, r);
292 multcolor(ctmp, nd.rdiff);
293 addcolor(r->rcol, ctmp); /* add to returned color */
294 if (nd.pdot < 0.0)
295 flipsurface(r);
296 }
297 if (hastrans) { /* from other side */
298 if (nd.pdot > 0.0)
299 flipsurface(r);
300 ambient(ctmp, r);
301 multcolor(ctmp, nd.tdiff);
302 addcolor(r->rcol, ctmp);
303 if (nd.pdot > 0.0)
304 flipsurface(r);
305 }
306 if (hasrefl | hastrans || m->oargs.sarg[6][0] != '0')
307 direct(r, dirbrdf, &nd); /* add direct component */
308 /* check distance */
309 if (transtest > bright(r->rcol))
310 r->rt = transdist;
311 }
312
313
314
315 m_brdf2(m, r) /* color a ray which hit a BRDF material */
316 register OBJREC *m;
317 register RAY *r;
318 {
319 BRDFDAT nd;
320 COLOR ctmp;
321 double dtmp;
322 /* always a shadow */
323 if (r->crtype & SHADOW)
324 return;
325 /* check arguments */
326 if (m->oargs.nsargs < (hasdata(m->otype)?4:2) | m->oargs.nfargs <
327 (m->otype==MAT_TFUNC|m->otype==MAT_TDATA?6:4))
328 objerror(m, USER, "bad # arguments");
329 nd.mp = m;
330 nd.pr = r;
331 /* get material color */
332 setcolor(nd.mcolor, m->oargs.farg[0],
333 m->oargs.farg[1],
334 m->oargs.farg[2]);
335 /* get specular component */
336 nd.rspec = m->oargs.farg[3];
337 /* compute transmittance */
338 if (m->otype == MAT_TFUNC | m->otype == MAT_TDATA) {
339 nd.trans = m->oargs.farg[4]*(1.0 - nd.rspec);
340 nd.tspec = nd.trans * m->oargs.farg[5];
341 dtmp = nd.trans - nd.tspec;
342 setcolor(nd.tdiff, dtmp, dtmp, dtmp);
343 } else {
344 nd.tspec = nd.trans = 0.0;
345 setcolor(nd.tdiff, 0.0, 0.0, 0.0);
346 }
347 /* compute reflectance */
348 dtmp = 1.0 - nd.trans - nd.rspec;
349 setcolor(nd.rdiff, dtmp, dtmp, dtmp);
350 /* fix orientation */
351 if (r->rod < 0.0)
352 flipsurface(r);
353 /* get modifiers */
354 raytexture(r, m->omod);
355 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
356 multcolor(nd.mcolor, r->pcol); /* modify material color */
357 multcolor(nd.rdiff, nd.mcolor);
358 multcolor(nd.tdiff, nd.mcolor);
359 /* load auxiliary files */
360 if (hasdata(m->otype)) {
361 nd.dp = getdata(m->oargs.sarg[1]);
362 getfunc(m, 2, 0, 0);
363 } else {
364 nd.dp = NULL;
365 getfunc(m, 1, 0, 0);
366 }
367 /* compute ambient */
368 if (nd.trans < 1.0-FTINY) {
369 ambient(ctmp, r);
370 scalecolor(ctmp, 1.0-nd.trans);
371 multcolor(ctmp, nd.mcolor); /* modified by material color */
372 addcolor(r->rcol, ctmp); /* add to returned color */
373 }
374 if (nd.trans > FTINY) { /* from other side */
375 flipsurface(r);
376 ambient(ctmp, r);
377 scalecolor(ctmp, nd.trans);
378 multcolor(ctmp, nd.mcolor);
379 addcolor(r->rcol, ctmp);
380 flipsurface(r);
381 }
382 /* add direct component */
383 direct(r, dirbrdf, &nd);
384 }
385
386
387 setbrdfunc(np) /* set up brdf function and variables */
388 register BRDFDAT *np;
389 {
390 FVECT vec;
391
392 if (setfunc(np->mp, np->pr) == 0)
393 return(0); /* it's OK, setfunc says we're done */
394 /* else (re)assign special variables */
395 multv3(vec, np->pnorm, funcxf.xfm);
396 varset("NxP", '=', vec[0]/funcxf.sca);
397 varset("NyP", '=', vec[1]/funcxf.sca);
398 varset("NzP", '=', vec[2]/funcxf.sca);
399 varset("RdotP", '=', np->pdot <= -1.0 ? -1.0 :
400 np->pdot >= 1.0 ? 1.0 : np->pdot);
401 varset("CrP", '=', colval(np->mcolor,RED));
402 varset("CgP", '=', colval(np->mcolor,GRN));
403 varset("CbP", '=', colval(np->mcolor,BLU));
404 return(1);
405 }
