root/radiance/ray/src/rt/m_brdf.c
Revision: 2.11
Committed: Wed Dec 21 09:51:46 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.10: +11 -3 lines
added -bv option for back face visibility (normally on)
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Shading for materials with arbitrary BRDF's
9 */
10
11 #include "ray.h"
12
13 #include "data.h"
14
15 #include "otypes.h"
16
17 #include "func.h"
18
19 extern int backvis; /* back faces visible? */
20
21 /*
22 * Arguments to this material include the color and specularity.
23 * String arguments include the reflection function and files.
24 * The BRDF is currently used just for the specular component to light
25 * sources. Reflectance values or data coordinates are functions
26 * of the direction to the light source. (Data modification functions
27 * are passed the source direction as args 2-4.)
28 * We orient the surface towards the incoming ray, so a single
29 * surface can be used to represent an infinitely thin object.
30 *
31 * Arguments for MAT_PFUNC and MAT_MFUNC are:
32 * 2+ func funcfile transform
33 * 0
34 * 4+ red grn blu specularity A5 ..
35 *
36 * Arguments for MAT_PDATA and MAT_MDATA are:
37 * 4+ func datafile funcfile v0 .. transform
38 * 0
39 * 4+ red grn blu specularity A5 ..
40 *
41 * Arguments for MAT_TFUNC are:
42 * 2+ func funcfile transform
43 * 0
44 * 4+ red grn blu rspec trans tspec A7 ..
45 *
46 * Arguments for MAT_TDATA are:
47 * 4+ func datafile funcfile v0 .. transform
48 * 0
49 * 4+ red grn blu rspec trans tspec A7 ..
50 *
51 * Arguments for the more general MAT_BRTDF are:
52 * 10+ rrefl grefl brefl
53 * rtrns gtrns btrns
54 * rbrtd gbrtd bbrtd
55 * funcfile transform
56 * 0
57 * 9+ rdf gdf bdf
58 * rdb gdb bdb
59 * rdt gdt bdt A10 ..
60 *
61 * In addition to the normal variables available to functions,
62 * we define the following:
63 * NxP, NyP, NzP - perturbed surface normal
64 * RdotP - perturbed ray dot product
65 * CrP, CgP, CbP - perturbed material color (or pattern)
66 */
67
68 typedef struct {
69 OBJREC *mp; /* material pointer */
70 RAY *pr; /* intersected ray */
71 DATARRAY *dp; /* data array for PDATA, MDATA or TDATA */
72 COLOR mcolor; /* material (or pattern) color */
73 COLOR rdiff; /* diffuse reflection */
74 COLOR tdiff; /* diffuse transmission */
75 double rspec; /* specular reflectance (1 for BRDTF) */
76 double trans; /* transmissivity (.5 for BRDTF) */
77 double tspec; /* specular transmittance (1 for BRDTF) */
78 FVECT pnorm; /* perturbed surface normal */
79 double pdot; /* perturbed dot product */
80 } BRDFDAT; /* BRDF material data */
81
82
83 dirbrdf(cval, np, ldir, omega) /* compute source contribution */
84 COLOR cval; /* returned coefficient */
85 register BRDFDAT *np; /* material data */
86 FVECT ldir; /* light source direction */
87 double omega; /* light source size */
88 {
89 double ldot;
90 double dtmp;
91 COLOR ctmp;
92 FVECT ldx;
93 double lddx[3], pt[MAXDIM];
94 double vldx[4];
95 register char **sa;
96 register int i;
97
98 setcolor(cval, 0.0, 0.0, 0.0);
99
100 ldot = DOT(np->pnorm, ldir);
101
102 if (ldot <= FTINY && ldot >= -FTINY)
103 return; /* too close to grazing */
104
105 if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
106 return; /* wrong side */
107
108 if (ldot > 0.0) {
109 /*
110 * Compute and add diffuse reflected component to returned
111 * color. The diffuse reflected component will always be
112 * modified by the color of the material.
113 */
114 copycolor(ctmp, np->rdiff);
115 dtmp = ldot * omega / PI;
116 scalecolor(ctmp, dtmp);
117 addcolor(cval, ctmp);
118 } else {
119 /*
120 * Diffuse transmitted component.
121 */
122 copycolor(ctmp, np->tdiff);
123 dtmp = -ldot * omega / PI;
124 scalecolor(ctmp, dtmp);
125 addcolor(cval, ctmp);
126 }
127 if (ldot > 0.0 ? np->rspec <= FTINY : np->tspec <= FTINY)
128 return; /* no specular component */
129 /* set up function */
130 setbrdfunc(np);
131 sa = np->mp->oargs.sarg;
132 errno = 0;
133 /* transform light vector */
134 multv3(ldx, ldir, funcxf.xfm);
135 for (i = 0; i < 3; i++)
136 lddx[i] = ldx[i]/funcxf.sca;
137 /* compute BRTDF */
138 if (np->mp->otype == MAT_BRTDF) {
139 if (sa[6][0] == '0') /* special case */
140 colval(ctmp,RED) = 0.0;
141 else
142 colval(ctmp,RED) = funvalue(sa[6], 3, lddx);
143 if (!strcmp(sa[7],sa[6]))
144 colval(ctmp,GRN) = colval(ctmp,RED);
145 else
146 colval(ctmp,GRN) = funvalue(sa[7], 3, lddx);
147 if (!strcmp(sa[8],sa[6]))
148 colval(ctmp,BLU) = colval(ctmp,RED);
149 else if (!strcmp(sa[8],sa[7]))
150 colval(ctmp,BLU) = colval(ctmp,GRN);
151 else
152 colval(ctmp,BLU) = funvalue(sa[8], 3, lddx);
153 dtmp = bright(ctmp);
154 } else if (np->dp == NULL) {
155 dtmp = funvalue(sa[0], 3, lddx);
156 setcolor(ctmp, dtmp, dtmp, dtmp);
157 } else {
158 for (i = 0; i < np->dp->nd; i++)
159 pt[i] = funvalue(sa[3+i], 3, lddx);
160 vldx[0] = datavalue(np->dp, pt);
161 vldx[1] = lddx[0]; vldx[2] = lddx[1]; vldx[3] = lddx[2];
162 dtmp = funvalue(sa[0], 4, vldx);
163 setcolor(ctmp, dtmp, dtmp, dtmp);
164 }
165 if (errno) {
166 objerror(np->mp, WARNING, "compute error");
167 return;
168 }
169 if (dtmp <= FTINY)
170 return;
171 if (ldot > 0.0) {
172 /*
173 * Compute reflected non-diffuse component.
174 */
175 if (np->mp->otype == MAT_MFUNC | np->mp->otype == MAT_MDATA)
176 multcolor(ctmp, np->mcolor);
177 dtmp = ldot * omega * np->rspec;
178 scalecolor(ctmp, dtmp);
179 addcolor(cval, ctmp);
180 } else {
181 /*
182 * Compute transmitted non-diffuse component.
183 */
184 if (np->mp->otype == MAT_TFUNC | np->mp->otype == MAT_TDATA)
185 multcolor(ctmp, np->mcolor);
186 dtmp = -ldot * omega * np->tspec;
187 scalecolor(ctmp, dtmp);
188 addcolor(cval, ctmp);
189 }
190 }
191
192
193 m_brdf(m, r) /* color a ray which hit a BRDTF material */
194 register OBJREC *m;
195 register RAY *r;
196 {
197 BRDFDAT nd;
198 RAY sr;
199 double transtest, transdist;
200 int hasrefl, hastrans;
201 COLOR ctmp;
202 register MFUNC *mf;
203 register int i;
204 /* check arguments */
205 if (m->oargs.nsargs < 10 | m->oargs.nfargs < 9)
206 objerror(m, USER, "bad # arguments");
207 nd.mp = m;
208 nd.pr = r;
209 /* dummy values */
210 nd.rspec = nd.tspec = 1.0;
211 nd.trans = 0.5;
212 /* diffuse reflectance */
213 if (r->rod > 0.0)
214 setcolor(nd.rdiff, m->oargs.farg[0],
215 m->oargs.farg[1],
216 m->oargs.farg[2]);
217 else
218 setcolor(nd.rdiff, m->oargs.farg[3],
219 m->oargs.farg[4],
220 m->oargs.farg[5]);
221 /* diffuse transmittance */
222 setcolor(nd.tdiff, m->oargs.farg[6],
223 m->oargs.farg[7],
224 m->oargs.farg[8]);
225 /* get modifiers */
226 raytexture(r, m->omod);
227 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
228 if (r->rod < 0.0) { /* orient perturbed values */
229 nd.pdot = -nd.pdot;
230 for (i = 0; i < 3; i++) {
231 nd.pnorm[i] = -nd.pnorm[i];
232 r->pert[i] = -r->pert[i];
233 }
234 }
235 copycolor(nd.mcolor, r->pcol); /* get pattern color */
236 multcolor(nd.rdiff, nd.mcolor); /* modify diffuse values */
237 multcolor(nd.tdiff, nd.mcolor);
238 hasrefl = bright(nd.rdiff) > FTINY;
239 hastrans = bright(nd.tdiff) > FTINY;
240 /* load cal file */
241 nd.dp = NULL;
242 mf = getfunc(m, 9, 0x3f, 0);
243 /* compute transmitted ray */
244 setbrdfunc(&nd);
245 transtest = 0;
246 transdist = r->rot;
247 errno = 0;
248 setcolor(ctmp, evalue(mf->ep[3]),
249 evalue(mf->ep[4]),
250 evalue(mf->ep[5]));
251 if (errno)
252 objerror(m, WARNING, "compute error");
253 else if (rayorigin(&sr, r, TRANS, bright(ctmp)) == 0) {
254 if (!(r->crtype & SHADOW) &&
255 DOT(r->pert,r->pert) > FTINY*FTINY) {
256 for (i = 0; i < 3; i++) /* perturb direction */
257 sr.rdir[i] = r->rdir[i] - .75*r->pert[i];
258 if (normalize(sr.rdir) == 0.0) {
259 objerror(m, WARNING, "illegal perturbation");
260 VCOPY(sr.rdir, r->rdir);
261 }
262 } else {
263 VCOPY(sr.rdir, r->rdir);
264 transtest = 2;
265 }
266 rayvalue(&sr);
267 multcolor(sr.rcol, ctmp);
268 addcolor(r->rcol, sr.rcol);
269 transtest *= bright(sr.rcol);
270 transdist = r->rot + sr.rt;
271 }
272 if (r->crtype & SHADOW) /* the rest is shadow */
273 return(1);
274 /* compute reflected ray */
275 setbrdfunc(&nd);
276 errno = 0;
277 setcolor(ctmp, evalue(mf->ep[0]),
278 evalue(mf->ep[1]),
279 evalue(mf->ep[2]));
280 if (errno)
281 objerror(m, WARNING, "compute error");
282 else if (rayorigin(&sr, r, REFLECTED, bright(ctmp)) == 0) {
283 for (i = 0; i < 3; i++)
284 sr.rdir[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i];
285 rayvalue(&sr);
286 multcolor(sr.rcol, ctmp);
287 addcolor(r->rcol, sr.rcol);
288 }
289 /* compute ambient */
290 if (hasrefl) {
291 if (nd.pdot < 0.0)
292 flipsurface(r);
293 ambient(ctmp, r);
294 multcolor(ctmp, nd.rdiff);
295 addcolor(r->rcol, ctmp); /* add to returned color */
296 if (nd.pdot < 0.0)
297 flipsurface(r);
298 }
299 if (hastrans) { /* from other side */
300 if (nd.pdot > 0.0)
301 flipsurface(r);
302 ambient(ctmp, r);
303 multcolor(ctmp, nd.tdiff);
304 addcolor(r->rcol, ctmp);
305 if (nd.pdot > 0.0)
306 flipsurface(r);
307 }
308 if (hasrefl | hastrans || m->oargs.sarg[6][0] != '0')
309 direct(r, dirbrdf, &nd); /* add direct component */
310 /* check distance */
311 if (transtest > bright(r->rcol))
312 r->rt = transdist;
313
314 return(1);
315 }
316
317
318
319 m_brdf2(m, r) /* color a ray which hit a BRDF material */
320 register OBJREC *m;
321 register RAY *r;
322 {
323 BRDFDAT nd;
324 COLOR ctmp;
325 double dtmp;
326 /* always a shadow */
327 if (r->crtype & SHADOW)
328 return(1);
329 /* check arguments */
330 if (m->oargs.nsargs < (hasdata(m->otype)?4:2) | m->oargs.nfargs <
331 (m->otype==MAT_TFUNC|m->otype==MAT_TDATA?6:4))
332 objerror(m, USER, "bad # arguments");
333 nd.mp = m;
334 nd.pr = r;
335 /* get material color */
336 setcolor(nd.mcolor, m->oargs.farg[0],
337 m->oargs.farg[1],
338 m->oargs.farg[2]);
339 /* get specular component */
340 nd.rspec = m->oargs.farg[3];
341 /* compute transmittance */
342 if (m->otype == MAT_TFUNC | m->otype == MAT_TDATA) {
343 nd.trans = m->oargs.farg[4]*(1.0 - nd.rspec);
344 nd.tspec = nd.trans * m->oargs.farg[5];
345 dtmp = nd.trans - nd.tspec;
346 setcolor(nd.tdiff, dtmp, dtmp, dtmp);
347 } else {
348 nd.tspec = nd.trans = 0.0;
349 setcolor(nd.tdiff, 0.0, 0.0, 0.0);
350 }
351 /* compute reflectance */
352 dtmp = 1.0 - nd.trans - nd.rspec;
353 setcolor(nd.rdiff, dtmp, dtmp, dtmp);
354 /* check for back side */
355 if (r->rod < 0.0) {
356 if (!backvis && m->otype != MAT_TFUNC
357 && m->otype != MAT_TDATA) {
358 raytrans(r);
359 return(1);
360 }
361 flipsurface(r); /* reorient if backvis */
362 }
363 /* get modifiers */
364 raytexture(r, m->omod);
365 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
366 multcolor(nd.mcolor, r->pcol); /* modify material color */
367 multcolor(nd.rdiff, nd.mcolor);
368 multcolor(nd.tdiff, nd.mcolor);
369 /* load auxiliary files */
370 if (hasdata(m->otype)) {
371 nd.dp = getdata(m->oargs.sarg[1]);
372 getfunc(m, 2, 0, 0);
373 } else {
374 nd.dp = NULL;
375 getfunc(m, 1, 0, 0);
376 }
377 /* compute ambient */
378 if (nd.trans < 1.0-FTINY) {
379 ambient(ctmp, r);
380 scalecolor(ctmp, 1.0-nd.trans);
381 multcolor(ctmp, nd.mcolor); /* modified by material color */
382 addcolor(r->rcol, ctmp); /* add to returned color */
383 }
384 if (nd.trans > FTINY) { /* from other side */
385 flipsurface(r);
386 ambient(ctmp, r);
387 scalecolor(ctmp, nd.trans);
388 multcolor(ctmp, nd.mcolor);
389 addcolor(r->rcol, ctmp);
390 flipsurface(r);
391 }
392 /* add direct component */
393 direct(r, dirbrdf, &nd);
394
395 return(1);
396 }
397
398
399 setbrdfunc(np) /* set up brdf function and variables */
400 register BRDFDAT *np;
401 {
402 FVECT vec;
403
404 if (setfunc(np->mp, np->pr) == 0)
405 return(0); /* it's OK, setfunc says we're done */
406 /* else (re)assign special variables */
407 multv3(vec, np->pnorm, funcxf.xfm);
408 varset("NxP", '=', vec[0]/funcxf.sca);
409 varset("NyP", '=', vec[1]/funcxf.sca);
410 varset("NzP", '=', vec[2]/funcxf.sca);
411 varset("RdotP", '=', np->pdot <= -1.0 ? -1.0 :
412 np->pdot >= 1.0 ? 1.0 : np->pdot);
413 varset("CrP", '=', colval(np->mcolor,RED));
414 varset("CgP", '=', colval(np->mcolor,GRN));
415 varset("CbP", '=', colval(np->mcolor,BLU));
416 return(1);
417 }
